6 p' X' l# q6 \+ I# N! ] XX0005 -11739.96572792 11739.969852465 -5.869994505896 5.8704633843495 34457.132233536 2 W; i* q8 v2 [+ W -9.840933953513 -179.9519723 -.0741946611597 -179.2758401 -406.6382754849 % W5 f4 `4 r% \ Z ) T: b8 i8 a5 F: z! X XX0006 4.2444868775879 74.505595921869 -.0012956034874 .00129986432335 .00116159796287 .00100320278347 ; X* w3 ]$ U, G. N: g+ w 74.384596220043 86.7341658 .10516112642E-3 175.3596074 -.0484096486471 -0.02420859 a( O, m7 G' b- Q( Q1 b
4 \0 k1 L" X+ |) x' Y
XX0007 6.1872099859972 74.476565829985 .64729984272E-3 .64991369084E-3 -.1583951794E-3 * h4 `3 |2 y& F& X6 P% R7 x3 f 74.219116745063 85.2346076 -.5822988199E-4 -5.1403847 .024201151551638 m" P6 x# H( |6 A# E7 v' A7 f8 R
0 q9 H' p y# b" O# m XX0003 149886.95534862 149892.66102285 0.0 0.0 0.0 0.05 x W* @* D1 g8 R$ e+ m
-1307.839756983 -0.4999221 0.0 0.0 0.0 0.0% u0 E A5 _' j9 ?) B! \. P
$ v: M) A; L# m1 ~ T3 X XX0008 149886.95534862 149892.66102285 0.0 0.0 0.04 R4 A: t1 n& ?" x3 w3 T$ D
-1307.839756983 -0.4999221 0.0 0.0 0.05 d- l" D: C$ t! F
9 K. z* N8 X s5 h T
XX0007 6.1872099859972 74.476565829985 -.6472998427E-3 .64991369084E-3 .1583951794E-3 .1583951794E-3& V' n8 `7 Y* D x
74.219116745063 85.2346076 .58229881992E-4 174.8596153 -.0242011515516 -0.02420122 n! w) f' w3 o( v6 [# U
! R% Y! U' e$ k: K: @. Y& H
XX0009 6.8344457064696 74.474449233014 -.285397164E-18 .3019492227E-17 -.112437082E-15! d& X( I- b: x! c9 B4 j. @$ z
74.160191076116 84.7346155 -.300597435E-17 -95.4235936 -.310469864E-18 " T4 {0 ~' B+ J4 j/ h - l D2 J5 b a
XX0006 4.2444868775879 74.505595921869 .00194445829654 .0019499653913 -.0013201166475 .00522868898108 + l- P. e4 D9 Z1 W1 M4 X, F- N 74.384596220043 86.7341658 -.1464478074E-3 -4.3071274 .07262967052585 -0.0242678 : l* f- b6 l% t. ~ . E1 i! o$ y# q XX0004 -.2945521752439 74.70160613923 -.0025949263561 .0026001733368 .00654880562858& F: M, G9 i$ N3 {+ s8 b, t
74.701025419982 90.2259207 .16510175041E-3 176.3594729 -.0968975143038 , K, v5 [0 | v4 k" s : }" ~- t, Z! X5 @+ ]8 W9 \ XX0010 4.8932957767493 74.503478499874 -.109637827E-18 .2107872404E-17 -.785145561E-16 .15851868463E-3 2 @, d: n) u2 y4 F9 p( B 74.342612040622 86.2341737 -.210501915E-17 -92.9814996 .1074859433E-17 -0.0242200 5 f. c# l v8 M X7 x3 ~2 n% A - z$ A4 \/ ~: }0 F* t% e0 C XX0006 4.2444868775879 74.505595921869 -.6488548091E-3 .65016701958E-3 .15851868463E-3 2 T7 D1 O8 Y; i/ b 74.384596220043 86.7341658 .41286680954E-4 176.3591735 -.0242200218787( N! u; e6 F; \' m6 u1 Y% r* [
$ T8 b J* _7 `% P1 B8 Y7 u XX0004 -.2945521752439 74.70160613923 -5.867004816876 5.8670504264591 -.68358947E-16 -.68358947E-16) v# q B1 y: X( R3 [
74.701025419982 90.2259207 -.0231340737461 -179.7740793 -219.1390450782 -219.1390451 8 E7 C7 i0 O' E - T$ E- K- ~5 B) n. h ]
TERRA 0.0 0.0 5.867004816876 5.8670504264591 0.0 " t- J# K. |6 i 0.0 0.0 .02313407374613 0.2259207 0.0 1 R3 s3 Y- E Y , t/ J/ R1 K' h7 O8 i* u XX0005 -11739.96572792 11739.969852465 6.1832411625641 7376.4406083741 .2248867759E-11 .2248867759E-111 T5 ~" G% p% q
-9.840933953513 -179.9519723 -7376.438016848 -89.9519723 -.4329959518E8 43299595.1804063& c5 A/ _" n; c& n' t: H2 K
7 ^" Z$ S" S" q/ o# P. y6 g5 e. T0 i, H TERRA 0.0 0.0 -6.183241162564 7376.4406083741 0.0 1 H" s8 ?" q$ _! w* _9 Q% w 0.0 0.0 7376.4380168479 90.0480277 0.0 - I: a8 M( K1 | ) [2 @* \' _# z; A2 D
XX0005 -11739.96572792 11739.969852465 -.3132466566685 7376.5122181602 -34457.13223354 -.643041176E-129 w" _' s7 I1 v! g- K5 k) L& E5 n
-9.840933953513 -179.9519723 7376.5122115091 90.0024331 .433000018187E8 54716345.08468040 t- g: I6 G. D& c0 ?! W! R
! H3 R' o: w8 g4 O6 N
XX0011 220000. 220000. .31324665666851 7376.5122181602 34457.132233536 " T% w- y( J$ f j 0.0 0.0 -7376.512211509 -89.9975669 .811416343266E9 . W: O, _; J9 c. d$ u+ ] Total network loss P-loss by summing injections = 3.509876731190E+04 5 E9 h0 `3 b: L6 k/ ] ' d2 l9 |9 I" l, w+ J, mOutput for steady-state phasor switch currents. ( e0 n* k$ k6 _1 G! I" ] Node-K Node-M I-real I-imag I-magn Degrees Power Reactive4 u" f# t$ `' N& x
XX0008 XX0007 Open Open Open Open Open Open " d; A& f$ Y0 T5 ~. D9 [6 y : S2 P$ [4 L5 pSolution at nodes with known voltage. Nodes that are shorted together by switches are shown as a group of names, with the printed% i2 ~* y6 |4 }+ |) d" Z
result applying to the composite group. The entry "MVA" is SQRT( P**2 + Q**2 ) in units of power, while "P.F." is the , n- {$ Q' ]$ G0 ^ w& Qassociated power factor. 9 y2 _$ |2 {* p' }/ q* V) H e Node Source node voltage Injected source current Injected source power 1 [* r: b9 B# }( ]- \) F name Rectangular Polar Rectangular Polar P and Q MVA and P.F. & F# T& c: ]; [& Y. h " [5 V2 J. ]% h1 \
XX0002 -220000. 220000. -.005833046167 11774.184683562 641.63507836944 .12951603152E10 0 g: k! `$ @" Y0 Z1 o# J 0.0 180.0000000 11774.18468356 90.0000284 .12951603152E10 0.00000052 i) P( t Q# e
9 ]+ _, c4 G$ _: Y" ]- z
XX0011 220000. 220000. .31324665666851 7376.5122181602 34457.132233536 .811416343998E9. N8 y. w% Z) w, f- M8 \) y: S9 Y
0.0 0.0 -7376.512211509 -89.9975669 .811416343266E9 0.0000425 " s: j7 U3 J- n8 W, N; i % @; j9 x" F) ~9 x: J- }5 A 2 G5 y& I5 @% u3 R3 |------------------------------------------------------------------------------------------------------------------------------------ " I9 N$ L& N z* M8 w* j% LERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ ( }3 X; e( c) {6 K/ s2 QERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ 3 B0 l/ D7 {9 O* r; ^9 K------------------------------------------------------------------------------------------------------------------------------------% T8 d' e) \) m
You lose, fella. The EMTP logic has detected an error condition, and is now going to terminate program execution. The following % l# P# S$ c- Umessage summarizes the circumstances leading to this situation. Where an otherwise-unidentified data card is referred to, or where & j- N' |" ~6 c4 r. ?5 H+ rthe "last" card is mentioned, it is the most recently read card of the input data that is meant. The 80-column image of this card 7 d* Z5 k) j7 j9 P. ^3 G( Z6 `% J) `is generally the last one printed out prior to this termination message. But possibly this last-read card has not yet been 0 P$ \; S. j" k% U3 Hdisplayed, so a copy follows:4 Z- l1 ?# W6 L& V; {& N
" XX0001XX0003XX0008XX0007XX0006XX0009XX0005XX0004 "1 ^$ _ B; L7 ?% @
KILL code number Overlay number Nearby statement number; e+ G) X/ q$ ^: R& p! U
102 12 1536 ) l! @9 Q% l. L5 P L* E2 tKILL = 102. The total resistance for one particular mode of a constant-parameter, distributed transmission line is too large./ E% j- a2 H" A* k/ ]
This is for linear branch number 2 (in order of data input) which connects bus "XX0001" with bus "XX0003". Resistance is to/ D K% @& {1 v* E
be lumped, with half in the middle and a quarter at each end (variable IPUNCH of columns 53-54 is equal to -1). The total modal ' b) \0 c# Q, {9 l, ^resistance of 2.00000000E+03 Ohms is unreasonably large when compared with the surge (characteristic) impedance of! _2 _5 k/ ]* i8 m1 g- J8 t
6.00000000E+01 Ohms. Program logic can not handle any resistance that exceeds four times the characteristic impedance. For , j8 d" I* y$ o2 a7 o3 ?normal power lines, such values are absurd, anyway, so no sympathy is accorded. ( O0 N1 z4 h. W* p. ?9 L' S) i1 s------------------------------------------------------------------------------------------------------------------------------------ ' r' [0 |, P* S9 U) gERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ 0 ? W4 E: m0 ^0 kERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/! c {% U" \1 ~0 ^6 l
------------------------------------------------------------------------------------------------------------------------------------: Z4 G; f- b" n# @3 d% x
; a. j: w* i, R% I. _( X
Actual List Sizes for the preceding solution follow. 02-May-19 23:52:54- }! }$ @, E1 ]; J! i+ `* A8 C
Size 1-10: 12 12 12 2 -9999 1 -9999 -9999 0 0 - e# v* }8 M% z/ x. d) |% r Size 11-20: 0 -9999 -9999 -9999 -9999 0 0 0 23 09 N* x- K7 j7 N
Size 21-30: 1 -9999 14 -9999 -9999 1 -9999 -9999 -9999 0 6 ?( B6 ^5 g0 JSeconds for overlays 1-5 : 0.016 0.000 0.016 -- (CP: Wait; Real)/ n* e3 Z) \; d/ q6 ~& o4 A
Seconds for overlays 6-11 : 0.016 0.000 0.016 B5 b2 b# |! @" b- R- J' V# b
Seconds for overlays 12-15 : 0.000 0.000 0.000 P: V) G3 E- B3 pSeconds for time-step loop : 0.000 0.000 0.000- r7 {5 k! D! u1 J1 ?, F
Seconds after DELTAT-loop : 0.000 0.000 0.000 ) E9 m) B: v& O8 W; Z# Z --------------------------- 4 R: s8 @% G% q0 F9 E Totals : 0.031 0.000 0.031
