查看: 9570|回复: 22
--ATP运行仿真雷电过电压出现的问题
 火 [复制链接]
发表于 2010-11-1 17:13:57 | 显示全部楼层 |阅读模式
ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/# l: }" ~) H" B. J! v
3 `+ X6 D- ?/ t  t------------------------------------------------------------------------------------------------------------------------------------
6 p" {3 y; m6 x# D. B2 H9 A3 `You lose, fella.   The EMTP logic has detected an error condition, and is now going to terminate program execution.  The following
" @( B8 s3 v" u# C0 b# r$ Qmessage summarizes the circumstances leading to this situation.  Where an otherwise-unidentified data card is referred to, or where- }( c1 l: L. l- m- F/ V
the "last" card is mentioned, it is the most recently read card of the input data that is meant.  The 80-column image of this card
2 Z, Y  ?5 h) j% t: H- Ris generally the last one printed out prior to this termination message.  But possibly this last-read card has not yet been( \0 q& e* u  f) c0 U, J7 N
displayed, so a copy follows:
$ o5 C- ]6 w$ t7 w! {  b "        ". G9 f& f6 m7 n. H; F
              KILL code number                Overlay number               Nearby statement number# H2 c  P9 R* A: F
                        212                         18                               3522
6 G; ?1 t. `* K3 H/ W; B4 {" U1 eKILL = 212.   A Newton solution for  1   coupled nonlinear elements has failed to converge within the iteration limit  MAXZNO = 50.
, F/ i7 E7 w0 \+ K" NThe current residual is  1.24294193E+04,  which exceeds the sloppy convergence tolerance  EPSTOP = 1.00000000E-01.   The first of3 m9 N! l8 l- f7 s$ Q/ R
the coupled, true, nonlinear elements (in order of data input) is located in row  1   of the nonlinear element table, and it2 i3 ], U/ |6 t$ A
connects node  "X0001A"  with node  "B     ".   The final coupled element is in row  1,   and the matrix rank is  1.   Finally, the4 P$ o0 I3 c9 C8 F# j( Y1 b$ a$ S  r
simulation time is  T = 4.05000000E-07.   Possible corrective actions include a decrease in the time-step size  DELTAT,  an increase
/ D4 c% X8 I0 c  t0 b- Win the iteration limit  MAXZNO,  an increase in the divergence tolerance  EPSTOP,  and artificial splitting of the subnetwork  in3 `' u+ n/ T7 h0 q7 e9 @( ~
question by distributed-parameter lines (to reduce the number of coupled elements).   In addition, it is possible for the user to
9 L+ Z; ^. I, _$ \9 G- r$ r6 imake a solution impossible by unrealistically limiting the Newton corrections.  The user should remember that there can be no
$ Y& t  Z, G$ V& d- ]6 V, _1 P8 Gsolution if his bound on arrester voltage is less than the true solution voltage.  The bound has a default value of 1.5 per unit,; K% [1 Y' u  W# H  q/ A% ]& y
although it can be changed by a"ZINC OXIDE"  special request (columns 57-64, variable  ZLIN(2)).& {* d: A4 p" E* Z
% U4 U/ q, ?4 W; T( xERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/
8 {& Q4 D. x: O  ZERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/) ^) i% ~1 @/ A0 W$ Y0 ^; f4 e
$ h+ }! r) z+ P! f. \& q * c8 Q, ?. h; |- J0 a, [
Actual List Sizes for the preceding solution follow.       01-Nov-10  17:02:189 S$ I) T& @1 I' {8 |6 S
   Size  1-10:    56    78   128     7   276     1    73 13840     1     3+ @1 I! u2 {# m& N; a( T
   Size 11-20:     0     6 -9999 -9999 -9999     0     0     0    23  3590
- o1 o6 G# l- {9 X  Z   Size 21-30:   126   375   253     1 -9999    25 -9999 -9999 -9999     0
. D' ]" a  r2 Q( w1 P) V  E' ASeconds for overlays  1-5  :     0.047     0.000     0.047  -- (CP: Wait; Real); J) v/ X2 S; q
Seconds for overlays  6-11 :     0.000     0.000     0.000# ]/ Q3 G! T, j1 v  m- q5 F
Seconds for overlays 12-15 :     0.016     0.000     0.016
% {* H" H" h6 C! pSeconds for time-step loop :     0.000     0.000     0.000( j' ]* [" X! p6 m1 ~# ]; O) d) |1 E
Seconds after DELTAT-loop  :     0.000     0.000     0.0005 E8 s$ Y$ B; j
                               ---------------------------" ]- k; l% T! S) \- e. }7 Y& [0 P
                   Totals  :     0.063     0.000     0.063
 楼主| 发表于 2010-11-3 08:42:10 | 显示全部楼层
未命名.jpg 未命名1.jpg 未命名2.jpg 我做的是输电线路防雷  加的是线路避雷器  可是运行时出现这问题  一直没解决,所以请教各位,我将我的仿真图形附上,请大家看看
回复 推荐 1 踩下 0
使用道具 举报
    2016-10-25 19:07
  • 签到天数: 32 天
    累计签到:32 天
    发表于 2016-2-22 11:47:45 | 显示全部楼层
    我的理解是Vref是一个初值,emtp拟合伏安特性曲线用的是牛顿拉夫逊法,你初值隔太远就不会收敛。
    [发帖际遇]: 帮助老师傅注册上研学论坛,liushuaige0919受奖励威望1 点. 幸运榜 / 衰神榜
    2020-5-19 19:34
  • 签到天数: 235 天
    [LV.7]常住居民III
    累计签到:237 天
    发表于 2010-11-1 17:54:50 | 显示全部楼层
    避雷器参数设置的问题, I  Y; i/ l: G7 g4 p& ?
    我也遇到了同样的问题+ `# N  J0 y# i& c) P' M) w
    但也没有很好的解决9 d- ?; n& A% i! l
    我输入的时伏安特性点0 N" w  V( `3 ^' C% S
    可能输入指数好一点
    ! i% {+ C/ X/ B8 a. S期待高手指点啊
    2020-5-19 19:34
  • 签到天数: 235 天
    [LV.7]常住居民III
    累计签到:237 天
    发表于 2010-11-1 17:56:44 | 显示全部楼层
    可以将参数ErrLim调大一点- X8 R3 N' p8 A, i
    但是是否合理就不清楚了
    2016-8-5 14:45
  • 签到天数: 6 天
    累计签到:6 天
    发表于 2010-11-1 20:23:00 | 显示全部楼层
    本帖最后由 guozh07 于 2010-11-1 20:59 编辑 8 r! V+ q1 `$ E  ?) D
    ! F) `* |2 i! m/ O, o3 x
    至少要检查:. G. Z: A+ Y3 C% G+ s
    1)计算步长是  T = 4.05000000E-07.   要看看你的元件设置,特别是最短的线路单元有多长,如果线路分段很短,减小计算步长。
    2 Y& Q. O$ E9 v7 m* [1 C( \2)避雷器参数设置有问题,残压是否太低?
    2020-5-19 19:34
  • 签到天数: 235 天
    [LV.7]常住居民III
    累计签到:237 天
    发表于 2010-11-2 12:12:59 | 显示全部楼层
    报错的信息里说是残压低$ L- y6 ^# D& v0 x
    但是输入的是实际的避雷器的伏安特性时也会出现这种情况啊
    1 m9 O6 V- `0 T2 }* b5 x( e还有如何修改MAXZNO = 50?这个参数啊
    6 }8 n  h1 ~8 V4 }) |/ E/ E# u5 x请斑竹指点啊
     楼主| 发表于 2010-11-3 08:44:18 | 显示全部楼层
    我是按照特高压避雷器的参数输入的  就是不知道如何改
     楼主| 发表于 2010-11-3 08:52:19 | 显示全部楼层
    版主  EPSTOP = 1.00000000E-01  MAXZNO = 50.  这两个是什么意思啊?, |% ]! y  F2 v/ F5 A3 h0 t  s, K
    应该怎么改啊
     楼主| 发表于 2010-11-3 09:49:09 | 显示全部楼层
    版主,请问避雷器参数设置中,Vref这个参数是指避雷器的额定电压吗?
    发表于 2011-1-8 15:21:28 | 显示全部楼层
    加个好友吧,qq543245091,一起学习学习
    GMT+8, 2026-11-19 06:47
