查看: 8887|回复: 4
时间序列达人们来讨论一下matlab中predict函数
    2016-2-29 16:07
    发表于 2010-9-28 11:13:27 | 显示全部楼层 |阅读模式
    打开程序也看不懂,600多行代码,请达人们帮助解读一下,先谢谢各位仁兄了~~
    发表于 2010-9-28 12:40:43 | 显示全部楼层
    贴代码上来哇
    发表于 2010-9-28 13:03:22 | 显示全部楼层
    你想自己编一个predict函数?
    发表于 2010-9-28 17:53:25 | 显示全部楼层
    恩,贴代码上来大家看看
    2016-2-29 16:07
     楼主| 发表于 2010-10-1 20:42:36 | 显示全部楼层
    回复 4# climber 3 B% ?4 p4 U. S6 \+ J/ e7 h
      C0 s; `, V) k
    6 z9 ]' A, N2 |+ j* S    谢谢大家的关注~~
    , v  q3 i( x1 n8 _7 n. Ufunction [yhat,xi,thpred]=predict(varargin)
    9 d- T+ n. G, ?5 Z%PREDICT Computes the k-step ahead prediction.4 S( u  Z) n2 u( s8 \! O4 w
    %   YP = PREDICT(MODEL,DATA,K)4 h6 `. l% @3 T* r! M( J
    %  S- K$ _2 k8 I# A
    %   DATA: The output - input data as an IDDATA object, for which the6 g) h, P0 S% I3 W
    %   prediction is computed.( j0 h0 g; s& E& i# {7 r3 A
    " T( o- g( {# W6 O; u%   MODEL: The model as any IDMODEL object, IDPOLY, IDSS, IDARX or IDGREY.
    & p& W0 ^# ^  m5 w%5 Y% o8 ~# q- `; T
    %   K: The prediction horizon. Old outputs up to time t-K are used to' n0 o( }+ n* c9 T( Z
    %       predict the output at time t. All relevant inputs are used.
    ' _1 i6 Z. L/ X# I2 j, E8 Q4 H%       K = Inf gives a pure simulation of the system.(Default K=1).
    # q/ a& `# m. k; A! O: v/ I%   YP: The resulting predicted output as an IDDATA object. If DATA
    6 |! O; S. j& a$ C. g5 }) X( q# B%       contains multiple experiments, so will YP.
    * W1 C& M( S& o1 ~/ ]% B%' [) v+ w4 ^3 _+ ], t
    %   YP = PREDICT(MODEL,DATA,K,INIT)  or
    2 s# X8 f$ F8 @& Q5 M%   YP = PREDICT(MODEL,DATA,K,'InitialState',INIT) allows the choice of3 J/ C) B" m3 I; f  l( j0 e
    %   initial state vector:. A# [) V/ M8 |- [- s- W
    %   INIT: The initialization strategy: one of
    8 g3 u5 x4 W7 l/ z) `, ]  J%      'e': Estimate initial state so that the norm of the
    / c- v1 O! X4 Y  }) `, Z6 v%           prediction errors is minimized.
    . u& O$ W4 L4 g%           This state is returned as X0e, see below. For multiexperiment8 D" K. x* N& u2 A4 |" G
    %           DATA, X0e is a matrix whose columns contain the initial states
    & N, J& s: o" @: J%           for each experiment.
    " ?7 {8 s( j# D2 l& F4 g+ U%      'z': Take the initial state as zero# m9 X4 T& b3 z( g  p9 f; D
    %      'm': Use the model's internal initial state.- e. c/ S. [# s$ Z& _) c6 g1 e
    %      'd': Same as 'e', but if Model.InputDelay is non-zero, these delays
    3 s+ V. v+ k+ ^' P4 S) ~6 \  u%            are first converted to explicit model delays, so that the are4 M/ u& @) T$ ]! Q, N7 }: m* P
    %            contained in X0 for the calculation of YP.9 }9 Z' \8 Q, H
    %       X0: a column vector of appropriate length to be used as initial value.* |: a& [9 [, R% }/ t# Y' K: c
    %           For multiexperiment DATA, X0 may be a matrix whose columns give
    ' u: ]3 n8 \5 z7 Y: h" X& I%           different initial states for each experiment.
    ) U0 A( [9 o) F" R9 \& L%   If INIT is not specified, Model.InitialState is used, so that: G, E; A& j2 f' J0 l. \' ?
    %      'Estimate', 'Backcast' and 'Auto' gives an estimated initial state,
    8 z/ _1 b; J5 G. I6 x. M$ T%      while 'Zero' gives 'z' and 'Fixed' gives 'm'. If Model is an IDARX
    ; a# y+ t5 Q7 s+ w9 j8 ?; x+ j%      model the default initial state is 'z'.
    * b* l7 F- a/ w( e# i4 r' E%7 S  _# Z: w2 I% U. {9 S
    %   With [YP,X0e,MPRED] = PREDICT(MODEL,DATA,K) the initial state(s) and the- U; x4 H: }8 h# P
    %   predictor MPRED are returned.  Note that if MODEL is continuous time, X0e1 Z- w! H% G" [: f& ]  W
    %   is returned as the states of this model. These may differ from the initial- [% X$ P" Q/ A
    %   states of the discrete time model that has the sampling interval(s) of- m, R0 x5 `/ O! r0 j) ^9 e
    %   DATA. Also when INIT = 'd' only the states of MODEL are returned in' J  t! c/ E# _% G  p! X& s# M
    %   X0e. (To obtain the full X0, apply first INPD2NK to a discrete time
    4 S4 y3 X: ]: E  p- P/ W0 F%   version of the model.)3 F% k3 I( G/ Y. z
    %   MPRED is a cell array of IDPOLY objects,: K; Z: V" u. S! I5 s, `
    %   such that MPRED{ky} is the predictor for the ky:th output. The matching
    ( g! P* M) Z. A2 R! Y6 v; W: N' R4 r%   the channels of MPRED with data follows from its InputNames.
      Q" [! Q1 {+ O( b: H%   See also COMPARE and IDMODEL/SIM.6 |+ v1 }+ q, M; g: \
    %   L. Ljung 10-1-89,9-9-94$ E2 `9 L( |1 O. ?, j
    %   Copyright 1986-2008 The MathWorks, Inc./ g! a( a7 W! s1 H8 m: k; J. ]# L3 k1 {; T
    %   $Revision: 1.1.8.9.2.1 $  $Date: 2008/08/01 15:32:39 $% N) O0 [% f1 g( h* a" I
    & r" @% K8 @! x& V2 j$ o3 r% First find if there is any pair 'InitialState', init in the argument
    : V+ f  P- h" z/ s% list:
    % R' A; V, t9 C" a* n8 `6 l' W/ enr = find(strncmpi(varargin,'in',2));
    1 p3 z2 c3 _0 j, sinit =[]; xi = [];$ A* L! t) G4 \/ D
    if ~isempty(nr)
    8 d" |0 K1 r  f" ?5 e/ |3 X! t    if length(varargin)<nr+1
    3 b5 q0 G5 K. N+ U: G        error('Ident:general:optionsValuePair',...* }3 k  I9 {$ q3 j, |2 j# X2 |
                    'The "%s" option of the "%s" command must be specified using a name/value pair. Type "help %s" for more information.',...
    & l; K% E: ^/ o! Q( m* J0 M                'InitialState','predict','predict')
    6 b& E- a+ G+ K- Y3 ^& g6 h; }- X    end
    $ e* E- S- K' d5 X- C    init = varargin{nr+1};5 L3 a4 A( k( J+ C8 e" O
        if ~isa(init,'char') && ~isa(init,'double')
    " L- n+ L. J) T# j8 a$ ]        error('Ident:analysis:IniSpec2',...
    " S) L9 d1 M: s9 {* x' g            'The "InitialState" option of the "%s" command must be set to a valid character or a vector/matrix. Type "help %s" for more information.','predict','predict')6 ]4 T2 a7 B% E. G. I  R% R
        end
    + v+ u. e! D1 l# s. J0 d! t8 ?    varargin(nr:nr+1)=[];%0 a0 E0 s. L. y) r* P8 k
    end
    ! @9 M0 ?- G7 P. Q% Y0 Pif length(varargin)<2
    ! U& o9 e" N8 \9 v# B  q    disp('Usage: YP = PREDICT(MODEL,DATA)')- K9 d3 e4 J7 h: I
        disp('       YP = PREDICT(MODEL,DATA,M)')5 s* x8 p8 P7 I6 U: {
        yhat = []; xi=[];
    & ~' D, v9 R7 W2 ]& @5 O; |    return; ^2 {. P4 Y' H7 @9 u
    end, W* k9 h  Y; N9 B7 V5 \9 K6 `
    data = varargin{1};
    ) V8 g6 N( K- J/ I3 Jtheta = varargin{2};% C, U$ `  x. D* Y. K# f* e) R
    if length(varargin)>2- n6 S, O' h2 G* x% A
        m = varargin{3};
    ( h. v( n) f' L' v7 a    if ~isnumeric(m) || ~isscalar(m) || ~isreal(m) || round(m)~=m || m<1
    # X: f+ i5 q% J+ w# f        error('Ident:analysis:predictInvalidHorizon',...2 s) `* F$ B, @2 ]% o1 S+ i0 e
                'In the "predict(MODEL,DATA,K)" command, the prediction horizon K must be a positive integer.')% [# b* }4 ]6 I$ r: z1 S( R
        end    8 Q' @/ s0 Z! d( S  {) T  d: ~4 I
    else
    ( l! X) S$ q, C, b% h    m = 1;
    : T% [# W% S# M4 _1 f- \/ _+ vend
    ! M- O( C! T, \if length(varargin)>3 && isempty(init)1 y$ i9 }8 l/ M/ K. f
        init = varargin{4};) K6 K% s% `4 h
    end
    6 c, S1 |2 M5 s# _! jthpred = [];
    " e, L7 [- `4 x( q& U: l. Iyhat = [];
    ( z: H, z6 {: ^  ]if isa(data,'idmodel') % Forgive order7 y$ e! @! X: V+ A+ Z/ p# x# ~
        data1 = theta;- r2 n" C7 m, c& n, M; u
        theta = data;
    , O2 n: ]6 T+ |9 j    data = data1;
    , ]' T' L1 U8 M4 _; l% }  C+ jend
    2 u, O0 Y- I4 p; K* k8 v0 r' Onxorig = length(ssdata(theta));: d7 _( E6 f0 h: ]2 u( `4 ^
    [nym,num] = size(theta);) o) z" U! g/ P
    if isa(data,'frd') || isa(data,'idfrd')
    ( v. p2 W8 k3 k- k, a. B6 P    error('Ident:analysis:predictIDFRD',...
    * @0 z( I$ D3 M' B        'The "predict" command is not applicable to frequency response data (IDFRD object).')* L% R* F/ l! l- Y6 c5 I' `- Q
    end
    0 _9 s1 T9 e( ]1 lif isa(data,'iddata')
    8 P/ u4 _: U5 O6 w0 }" A4 |    [Ncap,ny,nu] = size(data);
    + G" Y& q3 U. t* i! ]+ _    if ny~=nym || nu~=num0 k& V* C& ^7 k1 H; R* A: S5 h
            error('Ident:general:modelDataDimMismatch',...6 l4 J; a; a  B2 `  c
                'The number of inputs and outputs of the model must match that of the data.')
    4 \5 v  ?( c7 @. w" ], ]" b+ d0 g0 P0 X    end
    " A& P2 U& Y5 h' nend
    ) l* o7 R" q8 xif isempty(m), m=1; end5 s8 n2 ]; Z2 [8 f& ^) B& G
    if ~isinf(m),
    . H. A2 g: O! R6 Q' h    if m<1 || m~=floor(m)
    0 R( k5 A2 G' |5 |, m        error('Ident:analysis:predictInvalidHorizon',...
    * W, X4 z7 c+ n7 z* `            'In the "predict(MODEL,DATA,K)" command, the prediction horizon K must be a positive integer.')
    ; t6 j8 f4 R) [' |    end* r+ h3 B) ?4 m8 y7 Z7 v
    end3 t/ x+ q" W" Z9 ?0 T
    % First deal with the special case of continuous time data and continuous
    8 `6 s# R& y) {$ K, l# H% model:
    4 W& J1 C$ Z2 [8 K  t1 bif isa(data,'iddata') && any(cell2mat(pvget(data,'Ts'))==0)  Y, n; L. `6 s2 O. G9 f7 _9 D
        if ~isinf(m)
    " O" [) j3 C* S9 O2 K        error('Ident:analysis:predictCTData',...6 b# H5 W0 G0 A
                'The "predict" command cannot be used with continuous time data.')
    & B0 F8 V8 |  V  Y  ]7 a" D    end
    + ]0 Q+ N) K, l$ U    yhat = sim(data,theta);%没懂  K; B6 q' T5 O2 q  M) F, O/ S
        if nargout == 07 S$ c5 F* F- W( Q
            utidplot(theta,yhat,'Simulated')1 U& Y" U0 R$ C4 m" Q
            clear yhat# T1 w" |' g8 ~: R( C
        end0 d! w+ p9 {. l( ^; J& U
        return) K; v+ {3 d4 d. D
    end
    / k; C6 X  n/ K. ~; u( n, oif isempty(init)
    : s! k' ]8 g0 Q2 D6 k0 z) h    if isa(theta,'idarx')
    1 g- c: c; u0 @  i& y$ m: [        init='z';
    9 R  L, a+ U9 S% R2 q6 m1 R    else2 @9 m* F0 [, e( p* F: Q
            init=pvget(theta,'InitialState');
    6 a% e# w$ C% k5 y3 Z  H9 E1 w    end
    4 k. M' U# k/ f$ o9 D$ r    init=lower(init(1));
    0 [/ }5 k  k( F: c  |& R    if init=='d'
      A8 q" j2 O. |& {) t: ?% y: C- N  G        inpd= pvget(theta,'InputDelay');
    3 E( j: G5 r* X1 h        if norm(inpd)==04 U/ r/ C. O; `* \' @# D' f
                init = 'e';
    ! X" d8 U. X7 H2 H4 }        end% T/ v  l- c- N; B$ `
        end! N+ J* [; H4 ~4 Z* Z+ N
        if init=='a' || init=='b'2 b+ N7 {* r5 c! v+ w
            init = 'e';( `/ V' \5 H* Y9 Z: g( v; B
        elseif init=='f'1 }, H) Z7 a- A8 ]4 f* z/ m: N
            init = 'm';
    0 ^- e1 T) M$ u# I7 z7 u$ X  ?    end
    % m+ b1 _, d& H1 l9 I5 x- A2 R# welseif ischar(init)
      f' x- a( ^0 w* ]! P    init=lower(init(1));
    / u: i3 @. K# [) L5 b& W% s    if ~any(strcmp(init,{'m','z','e','d'})). I& D4 C& u) W* s: K  ^! T
            error('Ident:analysis:predictIni3',...
    # \' k' p5 R  d; ?            'The "InitialState" option of the "idmodel/predict" command must be set to ''E(stimate)'', ''Z(ero)'', ''M(odel)'', ''D(elayconvert)'', or a vector.')! u3 T/ O% `/ X0 d" D1 X1 I
        end: m6 m+ s" A: y  I- P
        if init=='m' && isa(theta,'idpoly')/ A9 p, l* J7 R  u; V1 C* b- u9 Z* m5 j
            warning('Ident:analysis:predictIni4',...' l3 G3 g+ z- t/ `8 C. V) ^$ u7 _
                'Setting the "InitialState" option to ''m'' in the "predict" command is same as setting it to ''zero'' for IDPOLY models.')
    & |$ n3 r( V6 `) b- G& i) g    end4 n  a3 O9 z9 x0 w8 |
    end7 p0 K. x% v- P0 o& [
    %% Now init is either a vector or the values 'e', 'm', 'z' 'd'
    ( d; s) B" A' G* z% k8 cif isa(data,'iddata');
    2 ^8 m& l3 @+ G* `. R, C+ b' ~) _    if strcmp(pvget(data,'Domain'),'Frequency')
    - X8 |; p" v9 T2 x        if m<inf
    , _% M$ B8 e: l' b5 G0 [/ z            error('Ident:analysis:predictFreqDataFiniteK',...
    ' d2 w3 E# V$ `$ z                'Prediction with finite horizon is not applicable to frequency domain data.'). F6 `8 i( s+ \& i
            end+ \6 |0 Q5 W; g" G! F3 c1 F  N
        end
    6 |2 B. X  M  D- z, c# F: \end
    $ S& v0 q9 t8 r% Pif isa(data,'iddata')2 A/ i. ^$ O  Q0 C! e# y
        [uni,Tsd,inters] = dunique(data);) a. s2 z& W8 \7 e! S1 q& W
        iddflag = 1;
    & D6 [# J* ?9 f& {else
    ' f7 Y* P! l9 F' r  J4 B1 A    iddflag = 0;
    - U' v1 ~, \5 @' S    uni = 1;4 b# `4 K6 B8 g- m) e& X* t
        Tsd = 1;
    7 U6 v! w- ?% v* K) A: T+ o    inters = 'z';
    1 J: ^! w6 |4 {, ^, @+ Tend
      ~: L. O6 a  Z0 m6 N7 V%% Do away with continuous time right away:
    , ]. s. ]1 Q% ~5 dTs = pvget(theta,'Ts');9 a' z! \7 Q" N, D  B# V7 k8 N- N
    if Ts == 08 N4 A. K5 \* I- \
        theta = pvset(theta,'CovarianceMatrix',[]); % Less calculations4 n6 [& o. ?& e
        ms = idss(theta);
    ; b1 I2 V6 y1 ]3 Y, H8 r    nc = size(ms,'nx');' F# b  k# B4 F
        if ischar(init)
    + t% c3 M8 L0 G( M; O( ^) Q  D- T! O5 x        if init=='m';+ v7 g( B, w. y4 u
                init=pvget(ms,'X0');
    2 B; P3 D- q0 m, X% N& l9 j        end3 ^8 O' U" C$ f1 A8 q; m: R
            if init=='z'
    ; t0 |; o2 {8 G- A. @            init=zeros(nc,1);9 [* ^! d. _# s5 q' s
            end
    $ {; U2 b, q( M7 c. Z- {    end
    3 U2 X1 Q, J5 E5 @0 G3 w9 i, A    if ~isa(data,'iddata')
    - L( J1 i8 l! u$ F. P9 J2 g: f7 e        error('Ident:analysis:predictDataFormat',...
    5 {. W7 H" i6 l/ c! z            ['For a continuous time model, data must be specified using an IDDATA object.',...( V$ d4 w, U- ]5 |8 M% H
                'Type "help iddata" for information on how to create the IDDATA object.'])
    ) F$ i6 ]2 `" E$ A8 S$ l3 [    end& _7 H. h$ `9 |. }! h
        Nex = size(data,'Ne');  |  Y8 O6 V2 s& x
        u = pvget(data,'InputData');
      p# U% z2 G% k+ X$ h' m& h$ ^8 [5 s    u1 = [];" b- k4 V  Y2 m  G0 u' o
        for kexp = 1:length(u);
    4 p( G/ @9 ?" u  t3 g        u1 = [u1,u{kexp}(1,:).'];; L- u5 z- _6 z- Q4 ]# b4 I
        end
      L: S, m, b* q$ A5 Q9 B7 q2 V, a    nu = size(data,'nu');/ o6 w$ o+ R7 Z+ I4 |0 X9 e$ p5 y
        if uni" o# ~# K. G1 W$ M% Q9 j
            nc = size(ms,'Nx');
    ' w; O* i- _7 N% d1 Y, d* W        [md,Gll] = c2d(ms,Tsd,inters);0 w* y$ P5 C/ a/ W8 J0 s
            if init=='d', md = inpd2nk(md); init='e';end
    - E3 e7 `( j5 U; r) P        % First work on init
    * d$ d" s5 X5 W8 z        if isa(init,'double')
    7 d0 D% a' L1 C- r7 b7 [& l  u            [nxi,mexp]=size(init);
    2 o4 V- a. Z$ ^8 b) P! V  ?0 ]* O0 |            if nxi~=nc
    , M/ |, g8 q8 R                error('Ident:analysis:IniRows',...: M% E1 H. r8 P: R3 \
                        'The value of the "InitialState" option should have %d row(s).',nc); b- Z$ G# c# R& T
                end5 P, a8 F$ x; m7 T. a( _3 G
                if mexp==1 && Nex>17 y2 M: w( [. T- T( l& q
                    init = init*ones(1,Nex);% G- G1 x. p/ P/ @
                    mexp = Nex;2 q3 }. a* e* X3 g. c
                end4 g  a% f; a4 I" @$ f* r
                if mexp~=Nex
    0 [4 Z! X! y: i                error('Ident:analysis:IniSize',...+ q4 y! Z4 q. a) k
                        'The "InitialState" option value must have either 1 or Ne columns, where Ne = no. of data experiments.');
    6 |9 M( r: d5 l            end, V, e/ q- r) X! [4 }- T
                if ~isempty(Gll)
    5 p( d8 ^3 ]. z3 c, m                init = Gll*[init;u1];3 Q' C7 ?/ t! j% ~" {; f3 |& u& S
                end
    / V9 p( W# }* L1 C) x- i" q. g# h        end
    9 q' z/ q: k' z4 E. l; L# E. g6 q        if init == 'e'
    " e3 _- r* C1 c% H9 d* N' i            inite = x0iniest(md,data);2 b$ P  }  K! Y4 Z! J) }4 s
            else) u3 N0 {. f! O
                inite = init;4 ]* z( s8 ]+ T; N8 o- J
            end
    4 G- S6 ^8 Y2 d        yhat = predict(md,data,m,inite); %Check XIC!+ z; }/ K  C. V+ H2 w1 o
            if ~isempty(Gll)
    ! D: J" G/ n7 j            xi = inite(1:nc,:)-Gll(1:nc,nc+1:nc+nu)*u1;1 v/ S& H- z2 c: [' X5 `: W
            else
    ) }2 f+ f: c% L% R4 U7 q6 f            xi = inite(1:nc,:);
    " w- ~' g4 Z3 V+ r        end5 w9 o1 N/ I  |$ J
        else % Different sampling intervals
    # l9 B8 ?! M9 B* E; l# ~        Tsd = pvget(data,'Ts');
    7 B( A6 r: y' k) t        ints = pvget(data,'InterSample');
    : n' z% h, A$ `5 ]        %xic=zeros(nc,Nex);
    9 a0 i& B/ B7 o( x- V- X1 s9 A        for kexp = 1:Nex/ w/ L7 z0 v8 _0 o1 o9 N& J
                [md,Gll] = c2d(theta,Tsd{kexp},ints{1,kexp});* S% y) ?" e) Z# z
                if init == 'd', md = inpd2nk(md); init = 'e';end" r" ?) u0 H; [$ V3 Q' ^+ C
                if isa(init,'double'); m$ n- d4 I  N; d! X9 Q7 R
                    if ~isempty(Gll)
    $ h/ ^; v  U9 q' H( c9 S; y                    if size(init,2)==1. T- F8 l. E, W  u$ }( y
                            initk = Gll*[init;u1(:,kexp)];
    8 R$ S: U8 K, v( b* S* L5 c                    else  h/ J0 v, ?4 m. [  ^$ o! W
                            if size(init,2)~=Nex. `) [# y% V8 Z9 L: P
                                error('Ident:analysis:IniSize',...+ F7 Q: p0 ]& |6 V( C4 O
    4 h# o- Z. @0 _1 S: I                        end
    * V* z1 z$ x0 q5 G  y" v0 z                        initk = Gll*[init(:,kexp);u1(:,kexp)];, o. M  y) F2 a3 R* I8 s8 I
                        end/ h3 w3 ^- H. X' K* R
                    end7 P( x+ h5 y+ c, X% [
                else
    & B6 w8 ]$ X6 F3 g" x9 w                initk = init;" |* d' z; \- T$ X# r/ l
                end
    & U& U. a3 B! K1 d4 Q8 l& n8 F            if init == 'e'
    / ?- L3 _/ |" v: z/ I                initk = x0iniest(md,getexp(data,kexp));
    ; u4 K. r5 N8 y; j  H: w6 ~            end
    7 T4 t$ h/ E" R            if ~isempty(Gll)1 [* j3 _" |. ^- i3 A
                    xi(:,kexp) = initk(1:nc)-Gll(1:nc,nc+1:nc+nu)*u1(:,kexp);6 m2 \7 \/ p; f8 J* |/ z* ?
                else
    , V$ G' Y* E! ^6 H: u                xi(:,kexp) = initk(1:nc);
    4 {7 E1 }9 `/ D! b            end6 ?  \6 D/ C8 e1 s
                yhatk = predict(md,getexp(data,kexp),m,initk);+ n+ Z" V* Y. \7 U( U
                if isempty(yhat)
    * W7 ^5 f* P2 k9 `1 a, q1 X- P                yhat = yhatk;
    9 V' `% [9 t0 n4 `0 `# {1 k9 O# T            else2 ^5 ~2 T; ~. y! ~# |$ D) ~
                    yhat=merge(yhat,yhatk);
    , \/ H, B' G, v9 J            end% j+ t( _& C6 h" l; ]
            end9 B. c: F( O' U2 F/ S3 i
        end' y- ^# J/ I( m' \7 _
        if nargout == 0
    " G4 j: X; x) q/ J7 A        utidplot(md,yhat,'Predicted')
    1 }6 O4 Y; D, m9 `9 n        clear yhat3 H* K0 O/ e! W1 J3 q8 w: I9 y  N/ C
        end
    5 F) q- C- g/ k. s7 i1 ^    return
    ( T: o+ J! h1 }+ N0 melse %Ts>0
    " T6 v; I: Q6 |+ K    if init=='d'# Q, a$ Y+ |2 K) v
            if any(pvget(theta,'InputDelay')>0)
    ' ~  n( S2 G! k. l( z7 L  `; p            theta = inpd2nk(theta);
    - e# V2 k: \0 b, J; k# V        end
    ! S, |$ R( ?  Q+ J+ T( @# w. A, K        init = 'e';
    % q# {# }* r! A6 K    end
    & C$ ?% q- W) Hend5 l* v$ r0 K3 _# f& ^5 w! D
    if isinf(m)
    + h" U8 a  U+ j    if ischar(init) && init=='e'
    7 M( p) |/ t* f        X0 = x0iniest(theta,data);( ~7 [: o# O7 o* F6 J, c- T
            init = X0;  % Note the difference with COMPARE, which fits
    . y( y, u8 U3 P1 S: S        % X0 with K = 0;
    9 c! j9 Y! j$ v% ^: j* a. {    end
    6 N/ S- V& z, G) _+ G    if ~isa(data,'iddata'): u6 e& G: o5 A# f; P% A
            data = data(:,nym+1:end);
    0 q7 n5 y: ?* u, W- }  c' r1 f/ D8 N    end+ y3 U5 ~# H! B3 ~2 ~. D5 _' N
        [lw0,id0] = lastwarn; was = warning('off','Ident:analysis:unstableSim');$ c& q. }$ {3 _) E
        try0 G  T: K4 F1 f( d, ]" ?
            yhat = sim(theta,data,init);
    , i' ~; }( c0 G" P1 |6 W* z    catch E: J; I7 x/ l- j! \% ]$ D
            warning(was)
    # r) R$ K, }9 Y% @' h, y, d" P/ q        lastwarn(lw0,id0);
    ! w' ]" m$ h# t& z        throw(E)
    2 V: I6 H, `$ x* w    end
    / G- E2 B0 r, u# M; j/ q    warning(was)- }5 q/ {7 _* w4 j5 X* J
        lastwarn(lw0,id0);& Y; G" I5 A% r8 D; c' s
        2 T5 Z, C" J' `- n1 z2 k5 n7 Y0 l
        thpred = theta;
    1 `0 n& Y9 x0 o  F, x8 H0 l    if nargout == 0- Z8 n4 @1 B( U; \5 L
            utidplot(theta,yhat,'Predicted')) V* P6 x  E0 G6 l/ A8 Z4 [9 _
            clear yhat* L! H4 B# i$ Q, t' x2 ^: Q) i
        elseif nargout>1' Q* i1 y- |" C7 w+ ^/ m% W
            xi = init;- g. l: x% f2 y
        end
    ; `7 U$ Q/ ~  f/ T7 G; n5 }/ J    return9 i1 b5 V/ L6 x/ H' H/ A
    end
    1 [- T7 U% C# D3 S. S% D% N%Inpd = pvget(theta,'InputDelay');
    # n& I& ~: G6 _  k* ?nu = size(theta,'nu');% r' S, {% W! i) h* P! C
    if ~uni
    8 s5 Y9 s. R) h& c3 Q    Tsd = pvget(data,'Ts'); Tsd = Tsd{1};! P  h1 M( ]; N/ I/ h% L
        warning('Ident:estimation:nonUniqueDataTs',...) f7 y8 P  N: n
            ['The data set contains experiments with different sampling intervals.\n',...# v. H4 ~( a, j" t+ s- C# M
            'Sampling interval from the first experiment (=%g) will be used.'],Tsd), ?5 K5 C, n! [5 d
    end
    # s- g( Q: k5 f  Rif iddflag && any(abs(Ts-Tsd)>1e4*eps)
    ) o6 F; [$ v: g    warning('Ident:analysis:dataModelTsMismatch',...! o2 P1 i! i* y, R6 v+ z
                'The data and model sampling intervals are different. The data sampling interval will be used.')
    ) L  n- }1 \4 Q2 b; g8 X# r, v) send  _# f$ H6 k6 i9 ]$ |
    Inpd = pvget(theta,'InputDelay');: U( {, ?7 t  D% e
    if init=='d') w' M+ A9 D/ x  s$ C
        init = 'e';
    5 X! m7 r1 r- b+ Q: l6 n0 K    theta = inpd2nk(theta);
    2 ]5 {* c. h* |5 q5 g! n$ z6 {    Inpd = zeros(size(Inpd));3 r% F0 A/ R& T* n$ M* U* Q
    end
    % i" D' S  {5 V' D" |' V' Vif isa(data,'iddata')# z4 J/ r4 u) V
        if isnan(data)
    9 [0 {9 L5 g# T, x# m        error('Ident:general:idprepMissingData',...
    & u7 U& }$ f/ g" R+ I1 \, D+ q8 z            'Data contains NaNs which represent missing values. Use the "misdata" command to fill in the missing values before using.');
    ) v1 T: K0 }2 |' a$ o0 c* w    end# y$ a8 |- N. J/ [) S& \( x. a
        data = nkshift(data,Inpd,'append');/ w! ^$ n  L! K8 v: n, d* k
        theta = pvset(theta,'InputDelay',zeros(nu,1));5 ~% c: f2 A7 P1 L
        [ze,Ne,ny,nu,Ts,Name,Ncaps,errflag] = idprep(data,0,'dummy');
    8 }& X1 D2 ?% t5 ]' X1 g" W    %if ~isempty(errflag.message), error(errflag), end6 [) q1 o7 g9 p% X
        if ~isempty(Name), data.Name = Name; end
    3 m/ @# C% G! b. B  i    iddatflag = 1;# m! r6 j4 J- d# Z. I2 a& _
    else. f0 e  k9 F2 |1 r. K- n
        if norm(Inpd)>eps
    ; j7 Q* P8 D% J: d        if iscell(data)
    ' ~* ~1 ?# Y- ^            data = data{1};4 b) l, u4 I. W! d$ w. [4 {
            end
    2 M! c0 s' D: I        [Ncap,nudum] = size(data);
    . f% n' a3 T) h  K1 c& K9 N$ V        nk1 = Inpd;
    $ a. P# A/ r, d' l        ny = nudum - length(nk1);
    3 T, e5 l  ]7 I! l        Ncc = min([Ncap,Ncap+min(nk1)]);" S8 _# q3 Q' A3 x' A4 N
            for ku = 1:length(nk1)8 u! i4 Y; X/ M- E9 \* Y* I. s
                u1 = data(max([nk1(:);0])-nk1(ku)+1:Ncc-nk1(ku),ny+ku);
    + ]% P4 K$ Y0 e2 o: I/ A& ]            newsamp = Ncap-length(u1);; D, U. Q; U+ J; M  B7 z6 Z
                if nk1(ku)>0
    9 m8 q: S% G1 W% a, e2 O6 k* N                u1= [zeros(newsamp,1);u1];* n, h3 c5 T- b2 Y
                else
    & Z5 D" q) D. r( @8 {2 {                u1 = [u1;zeros(newsamp,1)];
    4 c: j9 a: q* E+ ^2 z            end$ S/ T0 \8 G: F2 r. j) {6 c' e
                data(:,ny+ku) = u1;* A* ~* E- u3 |# `, D
            end2 c; r8 ]& d4 W+ q
        end
    ; B% P- c+ e& |& V" D9 _' R9 g$ }    iddatflag= 0;
    : Q  j" N7 @% I    if ~iscell(data), ze ={data};else ze = data;end
    # m$ M- R' B" h9 C5 {0 Z    Ne = length(ze);
    . [: h. |2 n8 J+ E! G- s8 L    nz = size(ze{1},2);
    9 \% w" x" \4 r! W    for kexp = 1:Ne
    ' g. o# M0 m; W& k; P        Ncaps(kexp) = size(ze{kexp},1);
    * \: R. L, k/ p; g    end# H0 r& E2 @6 p, ?; s3 f/ x
        %Ts =[];
    + h2 D* O( L* o. Mend
    ) c7 u. C8 }* M  i$ i5 Q+ rif m>=min(Ncaps)+ l/ o% \+ I; z: _, f7 d
        error('Ident:analysis:predictLargeK',...+ m; c) a! k( ^0 I
            'Prediction horizon must be smaller than the number of data samples.')* k7 M, `. [5 ?; b' Z
    end6 `0 i, D, Z7 V7 u
    [A,B,C,D,K,X0]=ssdata(theta);% x( e  F' m- Q5 U
    [nyt,nx]=size(C);nut=size(B,2);
    * U) w8 l' E4 @! Zif iddatflag- Z, o  @1 K6 Q1 A& _3 o& ~) w3 ?
        if ny~=nyt || nu~=nut
    & n' G# S( n' {4 o  h; z        error('Ident:general:modelDataDimMismatch',...# j+ A2 g. }5 ?, m0 R) k& G7 v4 e
    . o9 c. L1 i/ H1 S    end
    ) o  ^) T: o7 U2 V) Oelse
    9 ^. O* g7 B, x" e    if nz~=nyt+nut0 D2 s  E8 D2 `7 ~$ P- u
    ( n( t! ^& `) t: s3 J            'The number of inputs and outputs of the model must match that of the data.')
    , o7 r9 [; \  @$ J% J    end
    : H4 Y6 q- ~% K$ @* u7 w/ D    ny = nyt; nu = nut;; \! \7 u- }; G) e
    end
    ! b8 H+ ^: l7 u* Uif strcmp(init,'e')1 [8 O' |  ]. p
        X0 = x0iniest(theta,ze);: F; J( H& Y) m! y' y
    elseif strcmp(init,'z')
    & T, Q. R- V( |* a- M    X0 = zeros(size(X0));1 V2 D) D* P) u3 {
    end
    9 B& s- l$ v: V/ N  t9 \5 Gif ~ischar(init)( W! A6 G( N& m0 E5 j6 \; F1 V
        X0 = init;
    & k8 D* ?5 d8 c6 Nend
    2 T/ F; h/ `: T. R2 jif nargout>1
    + `" m" k5 _* R3 h0 N* K    xi = X0;3 a3 c' p6 \* z( D/ X. b# L! t
    end
    ; ?0 ?) ?) w  X[xnr,xnc]= size(X0);
    % F! k- }/ d0 _  Z+ x$ Uif xnc~=1 && xnc~=Ne* |! x; i( i, }  N  d2 o5 w$ N
    1 ~1 l! o! K- r" }6 [        'The "InitialState" option value must have either 1 or Ne columns, where Ne = no. of data experiments.');
    ( A8 N$ X# D$ p" [4 L/ A  O# w5 D, C4 rend
    . X* o: _" o3 D. |0 E; xif xnr~=nx! F8 ~; P, e& @/ M9 |
        error('Ident:analysis:IniRows',..." s0 b0 C+ m% s4 z
            'The value of the "InitialState" option should have %d row(s).',nx); ]) x& b' w3 w# n' m0 I
    end
    4 z/ j8 }. S! q1 B. \. wif xnc==1 && Ne>1' Z" x# S7 ?+ ]( n, Z  o( m
        X0= X0*ones(1,Ne);  Y2 o& _* s; X& j$ {
    end; J# M7 L- {! N3 D+ G/ E
    for kexp = 1:Ne! H' Z1 q( e" u* l" y( ]4 M
        z = ze{kexp};
    # J6 c) I1 n; }2 Y! @    u = z(:,1+ny:end);
    7 W+ M, H1 v0 B8 h    Ncap = Ncaps(kexp);) u8 i# \- g+ W$ {+ V. d
        if m==inf," a2 q% k3 q. @  }5 _, t
            yhat=sim(theta,u,X0(:,kexp));( \# i' r  S) `* u4 A2 s
        else  H# h1 r! s/ D
            x=ltitr(A-K*C,[K B-K*D], z, X0(:,kexp));3 e( S0 ]. P8 Y$ k( G1 p
            if m==1,( C& x' H. f6 y- k9 u6 e+ T
                yhat=(C*x.').';1 D& ~, R3 d: w
                if ~isempty(D),yhat=yhat + (D*u.').';end
    9 c1 h; c, w5 h        else
    . n. [  I+ J; \0 Y, ~9 O            F=D;Mm=eye(length(A));
    4 V7 w8 {) I% w" L9 V% p* v            for km=1:m-1
    / N: M2 d# I) ?. w                F=[F C*Mm*B];$ `$ j- T( ~3 L* y6 {' b
                    Mm=A*Mm;
    5 G$ Z# G* v7 r3 T3 \: R) t2 O" Y/ E  _            end
    ' @1 s4 v, K% B' L6 s& Q            yhat=zeros(Ncap,ny);%corr 911111
    : B! K# ~5 h& q1 h) |; I            for ky=1:ny
    3 Y! ~4 |& m, q/ C; L6 p                for ku=1:nu
    % @6 |. G! e4 \- `8 X                    yhat(:,ky)=yhat(:,ky)+filter(F(ky,ku:nu:m*nu),1,u(:,ku));+ M: Y- V; k; n* w
                    end
    " k. |" N/ }9 }- b" f5 M            end
    % v7 ?3 @( L' M% j            if isempty(yhat),yhat=zeros(Ncap,ny);end
    & K, V4 @, E, v' c6 n9 B            yhat(m:Ncap,:)=yhat(m:Ncap,:)+(C*Mm*x(1:Ncap-m+1,:).').';
    . J# W& c: `1 e' ?! {            if nu>09 ?3 O$ t7 ?7 r) w/ r
                    x=ltitr(A,B,u(1:m,:),X0(:,kexp));0 E8 S' h  T" Z. X
                    yhat(1:m,:)=(C*x.').';, Z2 G( P8 Y, `2 {+ H! w( x' I1 R2 x- k
                end& M4 s! ?* L: R' P0 ?# N9 z
                if ~isempty(D),yhat(1:m,:)=yhat(1:m,:) + (D*u(1:m,:).').';end
      [! ^, ^, z$ I        end
    4 _+ t1 Q' g3 _7 E" q, S% C( h& J    end6 X8 K4 L2 c" v8 c( Y" m
        yhatc{kexp} = yhat;, J, f% v- [* z
    end
    / t5 n7 C# ~0 kif iddatflag
    ' ~$ ^1 c% u2 O% [$ _6 p    yhat = data;5 @9 d5 X' Y& v3 d/ W3 D
        yhat = pvset(yhat,'OutputData',yhatc,'InputData',[]);6 s! V' i+ L( F) w
    else
    ( k/ `: u! b2 k% W# e    yhat = yhatc;
    $ r, p! E5 t+ r) G3 N, D# C* rend' D1 X9 E. x1 W% p) L& k
    if nargout >2( \; e  y* i" F9 c+ f+ k
        thpred = polypred(theta,m);
    . a$ ?  D& T' x2 V0 d; |/ T, `" Bend9 C  ?( E3 \9 c, V9 r7 d5 A
    if nargout > 10 ]3 A) |: c9 ]+ L: R
        try
    ) G! [5 x% P* R/ x; P2 o2 k        xi = xi(1:nxorig,:);
    1 o4 Z  U0 @5 X! o* u. a3 D    end$ ?$ v1 Z7 j: A
    end$ M. v6 \9 O- d% z, b- ]
    if (nargout == 0)4 d; m% q- D  w7 l
        % Plot y and yhat.+ [; G9 c" |5 O; E% F$ c
        utidplot(theta,yhat,'Predicted');
    2 K  C$ R) o" d3 S5 l' }: T    clear yhat x0;
    8 N. H6 D8 L0 W1 C' i2 mend- _: F3 Q6 U0 k4 x7 ?5 }; Z0 o3 F
    / l9 S& j4 l: Y% u%%%%% LOCAL FUNCTIONS
    6 t( M. ]6 |7 v" i1 W/ h3 i# v# O& H& v%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%3 I6 `; I" O9 P0 Z* i# I3 A
    function xi = x0iniest(m,data)# n( [4 \+ n- ~; @! Y" Y
    if isa(data,'iddata') && strcmpi(pvget(data,'Domain'),'frequency')
    / K% `6 @' x; ]6 m) V3 }3 \% q    [dum,xi] = pe_f(m,data);
    ; j& P8 j/ O4 }2 n4 F6 Z    return
    4 K" M! W, K  F' R- [end
    3 l6 O8 x* e" G7 XInpd = pvget(m,'InputDelay');
    1 b8 F! B2 W& cif isa(data,'iddata')5 Y. L* ]4 u( ]' [6 W
    & R1 M  j" j2 ?8 a0 ^    [ze,Ne,ny,nu,Ts,Name,Ncaps,errflag] = idprep(data,0,'dummy');+ d- e2 O. w6 h
    % h- ?: H- e  F) ?9 {6 y' _, ~    if ~isempty(Name)' Q' Y5 ~' A/ E( b2 m2 J. ?
            data.Name = Name;3 q3 R$ H* u5 F% Z
        end
    ' h/ k1 Z$ }) q+ I* z; ielse9 a2 f; r3 D4 c8 C1 i8 v/ d7 M
        if iscell(data)
    ( b, v/ o0 L" G4 z" _+ c        ze = data;
    5 z$ c- K! I7 ?7 j    else! A) d7 }" U& B* [& v& B3 C2 K
            ze = {data};$ n9 B7 Q4 I* v+ n  c- a0 A* J+ |
        end9 u* X* H  X: X% w. e2 a8 L
    end
    " y' L0 D0 }' K% z) ]alg=pvget(m,'Algorithm');
    - D$ C/ k6 @+ y4 O: t) @" |3 Mmaxsize=alg.MaxSize;
    - G% C4 h; U( h6 m2 {& r0 q[A,B,C,D,K,X0]=ssdata(m);8 Z, Q+ @' F2 m* V/ |" G1 b
    nx=length(A);
    . j* s. ^8 f" A" L1 c: ^( k! Kif ischar(maxsize)- S) h$ Y( a; B. s; |
        maxsize = idmsize(length(ze{1}),nx);
      n8 Y# Y" h! t8 Yend
    2 w: n0 d  u  {. j% K6 G& ?AKC=A-K*C;
    $ j: s0 F4 h" b. k5 ]- T4 L[ny,nx]=size(C);0 u" D4 k  L- R6 a; f- b4 r
    nu=size(B,2);3 P+ C5 G4 P2 y( x
    el=zeros(0,ny);
    : A3 T( S; \! y: r7 P8 x, m' }xic = zeros(nx,0);
    * E; A' t8 [- I, MNe = length(ze);3 x% {' y- Z* Q6 ^1 o' Z1 L3 }
    for kexp = 1:Ne
    , B8 K+ c3 O1 e% z6 T& d+ c    z = ze{kexp};! G' F+ L; X  P2 A$ v  Y1 T/ E
        [Ncap,nz]=size(z);
    # y: ?) T" k. v" p1 `" ^0 c+ H0 H    if nu+ny~=nz
    " R' B, O; K: c2 {9 H        error('Ident:general:modelDataDimMismatch',...
    . _, k) D& J8 i$ c" a            'The number of inputs and outputs of the model must match that of the data.')/ I4 h" [7 h) O
        end
    % y1 d2 w' N6 w0 g, D    nz=ny+nu; [Ncap,dum] = size(z); n = nx;
    # h+ h( T: A. l- F7 c    rowmax = nx+nz; X0 = zeros(nx,1);  v; ]; W6 S* _( [
        M=floor(maxsize/rowmax);9 c  o& e- W% }2 V7 m# s
        if ny>1 || M<Ncap$ c" f. n& K9 k& N0 D3 K( i
            R=zeros(n,n);Fcap=zeros(n,1);R1=[];) [7 P  p. ^6 o
            for kc=1:M:Ncap$ H( @' Z$ Z  J$ l% c  h; t
                jj=(kc:min(Ncap,kc-1+M));2 O: o4 }3 [. l% x  n3 x& M
                if jj(length(jj))<Ncap
      [$ w+ R# c: G( k                jjz = [jj,jj(length(jj))+1];
    " J' o& w8 o/ W4 G7 z            else
    - s) c' o( H  W, x1 E  p3 L: W( ^                jjz=jj;8 ^2 X& b1 U' t
                end; P3 D$ M- z/ A
                psitemp=zeros(length(jj),ny);1 t  [& g! F$ f0 b( l2 j
                psi=zeros(ny*length(jj),n);
    $ @# r4 ^. W( ]: S; \2 }  X            x=ltitr(AKC,[K B-K*D],z(jjz,:),X0);
    6 H  n* f( X0 }1 A) x            yh=(C*x(1:length(jj),:).').';, M+ e1 B" U; x9 C% R
                nm=pvget(m,'NoiseVariance');
    ; x( q  N' ~2 l- o            if isempty(nm) || norm(nm)==0 % To handle models without noise1 W; K- ~$ m9 o: U6 n4 y1 ]
                    nm = eye(ny);0 S4 A) L) _& ]+ V! x
                end
    5 Z) e+ k  ?; u            sqrlam=pinv(sqrtm(nm));" `6 O: a9 ?' x  t% C! C
                if ~isempty(D),yh=yh+(D*z(jj,ny+1:ny+nu).').';end' O7 O' a1 Z" O1 b) I* |3 @) p
                e=(z(jj,1:ny)-yh)*sqrlam;) x" i# i& v( e* ]6 G6 @# ]/ U
                [nxr,nxc]=size(x);X0=x(nxr,:).';, I3 v( C% r, x7 L9 S  G
                evec=e(:);
    % r$ G6 z* M' d  ]; ]3 a            kl=1;9 @3 s& v  K- a% e
                for kx=1:nx- z0 d4 [4 R6 X% m+ D9 Z0 y
                    if kc==1
    * }4 n3 `& A0 p                    x0dum=zeros(nx,1);x0dum(kx,1)=1;1 f) D0 h6 Q+ V
                    else
    , E- Y) D. M; e, a+ Y7 G                    x0dum=X00(:,kl);1 {0 }+ n; g; h5 p4 ^! E5 L3 p1 q
                    end
    5 S2 g6 F$ l5 ?% v+ p# `1 l, f                psix=ltitr(AKC,zeros(nx,1),zeros(length(jjz),1),x0dum);- k6 _9 k! O! v$ t
                    [rp,cp]=size(psix);! R) N  R: \9 |* j' Q, {# O
                    X00(:,kl)=psix(rp,:).';
    2 c: |- x2 x7 x; Q                psitemp=(C*psix(1:length(jj),:).').'*sqrlam;
    8 d, e3 t* I$ Z) X2 {6 g1 H                psi(:,kl)=psitemp(:);kl=kl+1;4 w6 i+ w" _- ?4 C* D
                end- [" h+ [5 B9 r& G  b# k5 F
                if ~isempty(R1)# G7 Q3 w( z2 n7 N/ r
                    if size(R1,1)<n+1- F: ~( e6 T8 I: w0 M+ @
                        error('Ident:estimation:predictSmallMaxSize',...
    4 n% w  P) d: O                        'The value of the algorithm property "MaxSize" is too small to estimate the initial states. Either increase MaxSize value in the model or set the "InitialState" option of the "predict" command to a value other than ''Estimate''.')
    0 q* f; |. D* O3 a                end
    + ~- d8 v( t4 R. c: V                R1=R1(1:n+1,:);9 y  j1 X+ R2 b3 F
                end( q3 J0 S4 T/ N8 E+ h
                H1 = [R1;[psi,evec] ];R1 = triu(qr(H1));/ e7 G2 d' ~: T7 }! V7 }2 t# `
            end
    7 ]; h% m% F4 f5 g        try
    7 R. @5 x: M- q* E            xi(:,kexp) = pinv(R1(1:n,1:n))*R1(1:n,n+1);4 i# H% p$ P. h! @9 m: ?8 W
            catch0 u2 c" \! m* [' O
                warning('Ident:estimation:X0EstFailed',...7 F$ R1 \) L* A! P& C7 A
                    'Failed to estimate initial conditions. Check model stability. \nThe "InitialState" option has been set to zero.')
    2 ]! A( ~+ Q& o            xi(:,kexp) = zeros(n,1);
    8 P: y7 ^5 D- X; I3 v# s: B        end& _: k1 S0 \, [4 H: w1 `
        else9 b2 l1 R$ d! T
            %% First estimate new value of xi! {* w' w- }5 o% q2 q9 c8 C: W, t
            x=ltitr(AKC,[K B-K*D],z);$ H6 a& C+ O2 z/ o1 w; d
            y0=x*C';) n5 S3 Q" a' P( v$ J, C
            if ~isempty(D),! S( M6 U3 E! L) }
                y0=y0+(D*z(:,ny+1:ny+nu).').';6 z9 A* f; D9 n' k, K3 R8 l# `1 [
            end
    " B$ H6 n: I. Y" N# {        psix0=ltitr(AKC.',C.',[1;zeros(Ncap,1)]);
    $ {6 f- [. c1 |1 b$ c) _        psix0=psix0(2:end,:);
    7 H5 t. R0 i% e4 C- [        try1 H, \1 p* m4 E' W
                xi(:,kexp) = pinv(psix0)*(z(:,1)-y0);5 b/ `! q% b* \. X
            catch
    - m; a) ~. h: |( ?8 ^7 @. |2 I, h            warning('Ident:estimation:X0EstFailed',...7 J3 w/ N+ d7 S) b" l! E1 z: l
    6 N. T2 |+ i! i/ q# b4 d            xi(:,kexp) = zeros(n,1);  P2 a  Z  t5 |8 @2 ^
            end- J5 z# z1 I& J
        end
    7 t  J7 D8 _- x! I: L* S$ E. Jend9 f) m* w; m- x, Z9 t( J& W3 }
    # x7 h6 ~' [+ r& y  m$ c9 }function thpred = polypred(theta,m)
    9 y* a  k# y1 Z0 i, I% Note that cross couplings between output( W! w* G+ g, a- ^% j- E- }8 n  a
    % channels are ignored in these calculations.
    5 Q) T1 Y3 n9 H0 }% ~% O% k[ny,nu]= size(theta);
    . q( G% y$ B, |9 c  e+ F! x8 fyna = pvget(theta,'OutputName');
    7 `: @$ {3 @( P. Huna = pvget(theta,'InputName');
    * F2 Y. ]3 F+ {* W% k" W+ ?, M1 syu = pvget(theta,'OutputUnit');. I6 @* }) p3 N% B
    uu = pvget(theta,'InputUnit');9 h% L# N; T7 L9 F0 L4 o. O& q
    for ky = 1:ny
    ( L4 L- l- c, K; ?8 T' s" s    [a,b,c,d,f] = polydata(theta(ky,:));% @! Q4 a) p" r5 B1 u: ~
        if nu>08 U* t) F6 P$ `5 z2 c
            ff = 1;! V4 x# X4 E+ s' k; O& g( i
            for ku = 1:nu,
    , p; A6 e' T2 B6 G1 ~            bt = b(ku,:);6 a3 e3 O: |7 t# ^& @
                for kku = 1:nu, if kku~=ku, bt = conv(bt,f(kku,:)); end, end
    * K/ v2 I9 H& T9 |            bb(ku,:) = bt;2 o8 _. Y6 X& s/ |0 |5 {# {. X3 B
                ff = conv(ff,f(ku,:));
    4 e. a5 @8 W# R        end% Z2 G( s& V" W9 T& {( T7 {3 U
            a = conv(conv(a,ff),d);c=conv(c,ff);
    - Q  Y' \2 ^5 b$ L, C9 [    else
    4 {% v2 ~5 `/ T2 ~        a = conv(a,d);$ k1 D& j( a4 K1 F! T8 R, w9 ^
        end, `' J/ V9 ^* j6 _
        na = length(a); nc = length(c); nn = max(na,nc);8 A2 {0 L5 {" l2 V" {
        a = [a,zeros(1,nn-na)]; c = [c,zeros(1,nn-nc)];
    7 t; x' i5 ~& s3 h' U5 L2 F: ^/ ]; m    [f,g] = deconv(conv([1 zeros(1,m-1)],c),a);
    & @* d- e: \1 n( b# U5 d' s( L+ U3 j    ng=length(g);# x& {' e7 R: x* k3 q: W5 L
        if nu>0,
    $ c( N7 ~2 H9 c        df=conv(d,f);# U+ I. ]0 O2 ^7 o* A9 @
            for ku=1:nu  H# N- }" Y/ T# r* S6 h4 {  S/ J
                bf(ku,:)=conv(bb(ku,:),df);0 {, s9 l- l2 E+ d
            end) x8 l5 A4 t/ \" O: t5 t+ A
            nbf=length(bf(1,:));nn=max(ng,nbf);
    " E$ D3 M; Z! Z6 G: `9 X0 F        gg=[[g,zeros(1,nn-ng)];[bf,zeros(nu,nn-nbf)]];
    4 C1 c+ k5 N" S$ F# G5 ^0 A    else* \3 G( t! Q' I. w  G
            gg=g;+ X, z* F3 P/ [) Q; J
        end* y9 A' M# ]* S4 T; `2 E9 T/ V- \
        th1 = idpoly(c,gg);/ |9 _5 b- ~% \( R4 ?. U. d
        th1 = pvset(th1,'InputName',[yna(ky);una],'OutputName',[yna{ky},'p'],...
    , Q0 B% F* }  q        'InputUnit',[yu(ky);uu],'OutputUnit',yu(ky),'Ts',pvget(theta,'Ts'),...1 I  _7 G9 F2 M- N% ^/ B1 H& d
            'TimeUnit',pvget(theta,'TimeUnit'),'EstimationInfo',pvget(theta,'EstimationInfo'));. [0 o8 K1 e6 I6 ^8 N
        thpred{ky} = th1;
    , a  s; h0 a7 K( r; n" \8 I7 Tend2 t1 A* Q6 l  O# h2 E
    GMT+8, 2026-11-22 20:44
