设置了两个mov ,出现以下问题。 2 c$ S r0 Y# U2 dYou lose, fella. The EMTP logic has detected an error condition, and is now going to terminate program execution. The following * u# Z( Q% Q1 k, m4 z0 _. \6 ^' E9 N0 N6 H. V' d$ j3 C
message summarizes the circumstances leading to this situation. Where an otherwise-unidentified data card is referred to, or where; U& Z: ? L; ]' n+ D
the "last" card is mentioned, it is the most recently read card of the input data that is meant. The 80-column image of this card 6 \/ {, K& H6 l+ F$ z. ]3 u8 ~is generally the last one printed out prior to this termination message. But possibly this last-read card has not yet been ) a3 i& Y; b1 fdisplayed, so a copy follows:# M* }5 j$ D3 d$ M& o
" "/ r% P: K5 j' s# M
KILL code number Overlay number Nearby statement number# H" q8 S3 b* x, f7 _) K8 F
209 18 35019 P2 a) Q) D" i: X; m$ v1 E# D- K
KILL = 209. ZnO solution by Newton`s method of 2 coupled arresters has failed due to singularity of the Jacobian matrix. This' ]; h) e! B+ q. m# i- F+ I+ X$ z/ A
is measured by tolerance EPSILN, which is defined by the floating-point miscellaneous data card. The iteration count is 2, and a. U' J( z/ G4 ~6 I. d. F
the coupled group of arresters can be identified from the knowledge that the first (in order of input) connects bus "XX0035" with# h/ y9 b; o: M: y
bus "XX0010". The simulation time is T = 1.00000000E-06.( g9 ?7 P' `/ Z5 |6 j
) E4 t! Q0 d; U) m5 L N* R: \ E
