Partial Description of the IEEE Common Data Format for the - [( g, H# ~" t; Q7 _Exchange of Solved Load Flow Data \2 }& m. z: F2 U8 H# c |% tThe complete description can be found in the paper "Common Data# J4 }/ _- Y1 S" {" |: c
Format for the Exchange of Solved Load Flow Data", Working Group on a' r2 {9 A* v+ ^% D& `
Common Format for the Exchange of Solved Load Flow Data, _IEEE + O7 X+ q% [/ B6 GTransactions on Power Apparatus and Systems_, Vol. PAS-92, No. 6, # f3 X+ v8 o6 c1 ?5 C. _November/December 1973, pp. 1916-1925. + p% w# p) J/ r3 s$ p0 v' a. qThe data file has lines of up to 128 characters. The lines are grouped% G$ i! }& ~% z9 U* r
into sections with section headers. Data items are entered in specific ; i0 o; A* y; }6 B5 C' o% z/ {columns. No blank items are allowed, enter zeros instead. Floating point* y) J8 @0 `, d+ x" j' ]( q- I
items should have explicit decimal point. No implicit decimal points l2 Z& n# E3 C& i1 nare used. c6 C P( H& x. q8 k3 ?* j6 p$ L
Data type codes: A - Alphanumeric (no special characters) - _* @$ V; M( a$ l+ T, K L I - Integer 5 W8 I8 l5 l* i5 ?: ` F - Floating point7 H3 u9 _' r7 Y4 \( Z0 \/ u" H
* - Mandatory item ; j0 k! Z0 T: @! \1 OTitle Data 7 Z1 i; K) W, M* g========== 3 {7 M ?! o, c% G/ DFirst card in file. W" K/ ?; x8 F% ^$ OColumns 2- 9 Date, in format DD/MM/YY with leading zeros. If no date 4 a1 d2 ]) g1 x2 {; [# B provided, use 0b/0b/0b where b is blank.8 x9 {1 U, j0 ^" t+ i- _
Columns 11-30 Originator's name (A) 1 w6 w9 U6 q- E7 w3 A. k/ z( yColumns 32-37 MVA Base (F*)6 h( {7 \# \' Y9 D
Columns 39-42 Year (I)0 A' Y% ?1 a, n/ { }1 L
Column 44 Season (S - Summer, W - Winter) 7 Q6 [* L- @; b6 o: uColumn 46-73 Case identification (A) 1 ?5 Z+ J* Y& O& U0 `Bus Data *5 @- f; x7 Z& ]# _9 G/ K
========== % j0 \% |% d( k |7 u X2 VSection start card *: , c2 a8 B' W6 E* K% O/ R5 T---------------------: Y* k( X) h2 b2 c1 Z
Columns 1-16 BUS DATA FOLLOWS (not clear that any more than BUS in/ C+ H) c9 Y9 O4 S) z
1-3 is significant) * 3 X$ n9 |' `' E+ vColumns ?- ? NNNNN ITEMS (column not clear, I would not count on this) ! H1 e) e7 _7 a2 EBus data cards *: ; a6 ^& H* _8 T i8 O-----------------2 b( q% z" _9 w0 U# J/ i& ?
Columns 1- 4 Bus number (I) * ! i7 a( U, J* T1 l. r# m- b wColumns 7-17 Name (A) (left justify) *3 F" U9 |$ V: p/ U" |
Columns 19-20 Load flow area number (I) Don't use zero! * 5 [- B( d3 P% |* gColumns 21-23 Loss zone number (I)3 C3 k. L7 V, @* i1 Z5 ?. i4 s
Columns 25-26 Type (I) *6 y. b, V- d: x9 Q$ E) Z; n
0 - Unregulated (load, PQ) - q# I, {. Y" W8 x+ y. V 1 - Hold MVAR generation within voltage limits, (PQ): v0 D8 u% O( J4 n8 T0 B
2 - Hold voltage within VAR limits (gen, PV) 0 \+ X3 p; M0 {9 l3 P 3 - Hold voltage and angle (swing, V-Theta) (must always 2 U, c% }2 r. Q' I: Z have one) 6 L' o; {6 l; {' z/ T$ U/ O" uColumns 28-33 Final voltage, p.u. (F) * ( R; c# w+ E5 E# d/ ]' WColumns 34-40 Final angle, degrees (F) *7 o- |7 U% w: |$ g
Columns 41-49 Load MW (F) *3 r- o5 K4 e- v9 \% B
Columns 50-59 Load MVAR (F) * , {, l6 z( ]+ C* ?5 B# rColumns 60-67 Generation MW (F) *! a T( e4 d7 t; S; j( G
Columns 68-75 Generation MVAR (F) *6 W% Q: {/ D: _, L$ p/ a
Columns 77-83 Base KV (F)5 _ D6 Y1 }1 y; i
Columns 85-90 Desired volts (pu) (F) (This is desired remote voltage if+ e4 G) t" G' t3 K+ W @6 B% \' _
this bus is controlling another bus.! c6 f1 |5 ]4 N# E5 N
Columns 91-98 Maximum MVAR or voltage limit (F): f, {6 V: [7 {$ j& F
Columns 99-106 Minimum MVAR or voltage limit (F), i" r9 V) I2 [: T' Y* k
Columns 107-114 Shunt conductance G (per unit) (F) * 1 i0 m; a3 s) o3 [! B9 ?Columns 115-122 Shunt susceptance B (per unit) (F) * $ V2 c. R, }' u) n6 HColumns 124-127 Remote controlled bus number1 r. M. x' P" K( _
Section end card:! y/ s5 {* V4 g9 c3 a
----------------- 1 x- E1 `# L0 U4 r [8 ]6 V AColumns 1- 4 -999+ T$ x" Y( e5 Q0 U8 \5 k
Branch Data * 0 ~ @( M! h4 H5 F7 m0 a% J8 M============= ! T' V* `8 f, A& hSection start card *:# ~/ K; V2 u( }1 o) C
--------------------- $ W: B, y* a" _7 |1 z0 P% G$ zColumns 1-16 BRANCH DATA FOLLOWS (not clear that any more than BRANCH 6 p' }4 j, y2 B0 v5 k# E; o is significant) *, @: x7 h. K: g+ o X* Q; \
Columns 40?- ? NNNNN ITEMS (column not clear, I would not count on this) * K# q7 w q3 |Branch data cards *: 3 b9 R7 t5 P' c; Y- h- J% V P! Y, J-------------------- . `" O4 z$ G: I r7 FColumns 1- 4 Tap bus number (I) *$ h% S5 `( F# r0 j
For transformers or phase shifters, the side of the model + ^: `# j7 Q7 L0 Q. K the non-unity tap is on : I( q& h! S9 z5 u# a, HColumns 6- 9 Z bus number (I) * 4 D2 ~) Q" f1 y! Z/ [5 u7 N' G3 ]5 B. g For transformers and phase shifters, the side of the model3 J; Y1 k: ^! {
the device impedance is on., m9 S: d. b: R. h0 I f) _
Columns 11-12 Load flow area (I)! T6 `6 Q& d. Q% |0 ?
Columns 13-14 Loss zone (I)3 u' j0 v/ x: `, S3 }$ Z% }. A
Column 17 Circuit (I) * (Use 1 for single lines) 1 ^9 T9 n% q; I( B) XColumn 19 Type (I) *! l' t* T6 W6 l0 b. q+ C( l& ?
0 - Transmission line& k1 B5 u# w3 [7 w8 _ k. m
1 - Fixed tap0 S p0 z5 G* w
2 - Variable tap for voltage control (TCUL, LTC)/ [1 s, S; k; C! x0 g- \
3 - Variable tap (turns ratio) for MVAR control: m( F, h6 K% a: T+ d8 `+ J: e
4 - Variable phase angle for MW control (phase shifter)% b' {% r6 i A4 w. E5 R4 O
Columns 20-29 Branch resistance R, per unit (F) ** f7 s( R* X+ P+ F* s: h7 ^
Columns 30-40 Branch reactance X, per unit (F) * No zero impedance lines7 |& F# H+ L# y, d3 E o
Columns 41-50 Line charging B, per unit (F) * (total line charging, +B) " `5 d! y5 i4 F8 p# a4 B8 V" X- F9 Y% {Columns 51-55 Line MVA rating No 1 (I) Left justify!6 }/ F8 Y" X6 Q" k0 U* B
Columns 57-61 Line MVA rating No 2 (I) Left justify!' X/ M& Q& k5 e# M) q% ^0 G
Columns 63-67 Line MVA rating No 3 (I) Left justify!; e$ Y6 u/ j9 m1 o* e* ?; d0 u. `8 ?
Columns 69-72 Control bus number : Q. y8 r$ W% y: k# V, XColumn 74 Side (I)" n4 y3 n# c( M' } f" T
0 - Controlled bus is one of the terminals$ E4 J) _# v4 b+ Y/ T$ T6 E
1 - Controlled bus is near the tap side- h( l, Y) O5 g: I$ K4 [" B4 k
2 - Controlled bus is near the impedance side (Z bus) # V n0 a g1 v! M1 n' A# gColumns 77-82 Transformer final turns ratio (F) . s0 |1 k/ e0 H7 i( m+ w1 KColumns 84-90 Transformer (phase shifter) final angle (F) $ }( L7 Q/ @. yColumns 91-97 Minimum tap or phase shift (F) * Z C. a, e ?/ fColumns 98-104 Maximum tap or phase shift (F) c e8 K C+ I7 E& n2 m
Columns 106-111 Step size (F)" l k# y( Z1 |
Columns 113-119 Minimum voltage, MVAR or MW limit (F) F* A9 y( T( p2 O: _% y" \2 |' GColumns 120-126 Maximum voltage, MVAR or MW limit (F) Y4 u* ~$ w, c. y f
Section end card: 8 l6 L# l$ K% M----------------- ( q% e; d' H% f9 ]) @5 j2 K3 qColumns 1- 4 -999 4 t6 R# \, p: m, v& w. XLoss Zone Data 7 n' d) E& q# e+ F5 ?5 ^============== 6 b8 T" R/ M3 N8 P9 |Section start card; g1 l9 [) o; K/ \+ R! G# s z
------------------9 \" _' k0 c3 W# G& G; _# t
Columns 1-16 LOSS ZONES FOLLOWS (not clear that any more than LOSS . e- `- }7 X* ]) @2 o# u is significant) 0 l* E$ _" p8 c& H A9 p2 `Columns 40?- ? NNNNN ITEMS (column not clear, I would not count on this)/ ~' V. @5 H/ F$ I
Loss Zone Cards:* C: j" t- C) q9 Q: e0 a
----------------, |. h, \$ Z4 {" G; O4 ^5 _, ?
Columns 1- 3 Loss zone number (I)( h R* j. U4 \6 l; ?7 o( t
Columns 5-16 Loss zone name (A) 4 J6 o6 z6 r& F7 _# f% H2 ESection end card: 3 ^& L+ ?& ~7 r" Z-----------------2 q, \, c$ I- |- H' f
Columns 1- 3 -99 5 R8 K, f: ]+ {! f2 SInterchange Data * 8 k# A% H: |, j+ l; ~ B5 y==================- F$ O) y- M- e* \
Section start card 2 p; f! N, V3 t% \) y# R+ C------------------! r% @% i2 j* V) G8 b
Columns 1-16 INTERCHANGE DATA FOLLOWS (not clear that any more than # Z; B; G+ v/ _& P" T; ~& U- J) e# a first word is significant). & S- }) b0 y. r$ m" Z$ X+ oColumns 40?- ? NNNNN ITEMS (column not clear, I would not count on this) - d/ u; O) ~8 o# n# ~8 E' JInterchange Data Cards *: ! }& P0 U' A9 o' M2 I5 G: L-------------------------2 V0 i. P# J+ U6 V) t- `$ E8 J
Columns 1- 2 Area number (I) no zeros! *0 F% G" i( h, h" Z
Columns 4- 7 Interchange slack bus number (I) *: Q. c4 Y& |3 q( j" z7 R
Columns 9-20 Alternate swing bus name (A)1 w! [/ |' ]& w4 q. E, V
Columns 21-28 Area interchange export, MW (F) (+ = out) *8 p0 U% K- @( [1 Z
Columns 30-35 Area interchange tolerance, MW (F) * ! `1 a9 \" r3 p: h2 u5 F3 ZColumns 38-43 Area code (abbreviated name) (A) * ! ]2 h5 D9 G$ B1 rColumns 46-75 Area name (A)" Q* c% e8 O: \5 l3 p5 E
Section end card: 2 H5 Y6 i' p2 g9 k+ X-----------------5 w1 Q2 w- L) b% B- N
Columns 1- 2 -9 2 S+ d( A. J( j3 d1 I* S. c5 {Tie Line Data1 ], J( Z: V( i$ a7 W; ?7 H
=============1 @* ?$ M* x- i$ R/ o4 |9 H) N
Section start card4 G, o7 o3 E: g& i3 m+ a
------------------9 @* u7 u& i7 o0 P9 f% L
Columns 1-16 TIE LINES FOLLOW (not clear that any more than TIE1 O3 x: O" x3 B t
is significant) - I Q- S5 N1 I" q; E4 {Columns 40?- ? NNNNN ITEMS (column not clear, I would not count on this)5 U4 p! L$ m5 E" i' }* N) g
Tie Line Cards:2 [2 z* {: `4 ]' ?
--------------- 4 q: Q* \7 c& b7 g5 |/ C; ]Columns 1- 4 Metered bus number (I) : Y$ i2 k7 x) E& h: `Columns 7-8 Metered area number (I)5 \1 m, L( Z3 q M9 n3 ~
Columns 11-14 Non-metered bus number (I) S; }! c3 t4 i t; P# ?2 O9 SColumns 17-18 Non-metered area number (I), }9 w6 e5 s; j9 w* f' f
Column 21 Circuit number @. ]9 k6 j( H" E" r3 MSection end card: , K% H0 P( P/ |* H2 j- P----------------- $ J1 m3 E' l. C0 g6 N1 c6 {Columns 1- 3 -999 1 s: t' B9 Y+ u2 LEND OF DATA6 s! h8 u- T( } q0 G3 i9 b4 ~
J) d( C) b1 s* u0 L @
PSAP File Format, D1 i H/ @) e9 |' A4 @4 v
May 20, 1993 - X7 O& i' A( I1 PThe PECO PSAP File Format is fully described in the _PJM Power System 9 G5 o, f. k7 L1 P" qAnalysis Package Use's Guide_, available from the Philadelphia - a& n! c1 O |, x6 `: ?Electric Company. The following is a rough description of the& M1 z6 _- A8 b* m3 o
most important parts of the format. ! J8 Y4 C9 Y$ L% v2 \3 D% V( [; k( fA PSAP data file is divided into sections by code cards. The code is5 C' | k% j4 w/ C0 X6 M$ x0 B
in the first three columns. There are something like 60 codes, of9 V/ d! a6 _. H B
which only four are described in this document. ' ?, Q5 J r$ ^5 k9 x+ Z* ?0 h: F3 jThe 1 code indicates that the next card is the case title. Only one 0 N# q3 p- S7 U% r8 Ytitle is allowed per case.2 s1 d; b) ^# [/ b7 w2 J' i
The 4 card indicates that line data follows. The line data ends with: G2 e k1 P% c; |& V& [
a 9999 card.6 ]. w7 Q; I4 B, \8 f- m+ D3 X3 D
The 5 card indicates that bus data follows. The bus data ends with . l8 m- t/ d0 d6 t0 f+ Za 9999 card. x% L* P% `' J0 @
The 15 card indicates that area interchange data follows. The data ends with! Q# [: ~' Z. t, c$ T
a 9999 card. 2 {% M6 e* F/ W6 aLine Data Card (Code 4 cards) z$ U# ~$ ^' A6 S: s! \=============================( h5 c5 U6 r6 K$ O0 L# F
Cols Data: ~: h! [/ Y P7 U
1-4 From bus number2 @' X1 n* I& Y' H! t* Q# }
6 Change code (blank in 4 section)& `; _; W) v( v& K( n5 g: s4 g
7 'C' if second card present for same line. Used for transformers.3 b8 t" l9 j" Y, M- J" ?
9-12 To bus number 2 ]. V8 r1 o$ q% O14 Circuit number (blank in 4 section) ( B1 ]" Q6 X2 W% t* }16 'T' or 'F' - Load flow area of bus at this end of line gets losses.# B: ?5 h" O: X9 |3 x
18-23 Line resistance in percent of base. (NOT per unit.) ; U; i& Y6 J" @" u4 e (percent = 100 x per unit) Two default decimal places. & @+ v9 O. i H24-29 Line reactance, in percent. Two default decimal places. 7 M& ]" p3 R% O9 U0 W+ t' F+ Y30-35 Line charging MVAR (total). Three default decimal places. 8 @( _" N- s4 c8 ^36-40 Transformer tap (per unit turns ratio). Three default decimal7 ^6 n. }3 C* r7 R, J# V2 S
places, 1000 = 1.000. . L! L. }1 ?3 Y8 S& Q41-45 Min tap, for OLTC. Three default decimal places. 4 b8 {' m' ?4 q; e4 d/ v0 Y5 s46-50 Max tap, for OLTC. Three default decimal places. ) D4 C3 E s3 z b" k51-55 Phase shift angle, for OL phase shifter. Two default decimal places.+ y6 y3 k. |% M. B; a
56-60 Remote voltage control bus number. Negative if lower tap increases2 ]* m: u D3 a% x
voltage of this bus.0 F L1 I0 _: {* y. r' |5 N, H- i
61-64 Normal MVA rating# i: M5 u: f: B' ~
65-68 Emergency MVA rating 1 M$ K) Y8 l+ c2 a% ?& p3 v" a69-72 MVA Base. Default value 100 MVA if blank.% J+ _0 V/ V2 v5 E0 K/ f5 Y9 ]
Second Line Card (follows 'C' in first card) . V2 g$ N+ X# v, o/ ?' Y5 H============================================2 n4 P0 w" l0 Z6 O& g$ E
1-17 Same as first card, except no 'C'. Can be left blank.3 K; N& R1 F/ [ \- j
35-40 Desired MVAR flow or Min voltage setpoint for OLTC. ; w7 x7 N e0 x$ W; `/ ?; T41-45 Min phase shifter degrees. Two default decimal places. ^ j- f& \- ^" G8 g46-50 Max phase shifter degrees. Two default decimal places. 0 T' n- R" C3 I8 F51-55 Desired MW flow for phase shifter. * ~6 w h/ p" Z' a3 g# [2 Y# K57-60 Controlled line from bus.) Q, e! a0 [$ X$ J9 B! \7 R
62-65 Controlled line to bus.- u% G8 ?+ n; n# N/ b: Q( b+ f" ^
67-70 Available taps (number of taps)5 S0 `+ m; w* \' O
71-75 Maximum voltage setpoint. Three default decimal places.# _: o: Z& Z- o: S
Bus Cards (Code 5 cards) 8 M! `# A2 D0 u9 \. r& e9 }: i+ [, Z========================+ Z) G3 l( v& A$ G1 {/ D, _1 n
1-4 Bus number# z J5 Z( g# I0 W F
6 Change code (blank in 5 section)2 G2 M0 q) S; t+ ]% F& e& h
7 Continue code (blank in 5 section) 2 f8 r* }; J4 b8 Regulated bus code: 5 b% z' y+ I/ Z6 f" c* `2 A7 L Blank - load (PQ) bus . c) g" N N6 M8 t% X 1 - gen (PV) bus. E* x1 b c7 C5 C
2 - swing (V-Theta) bus$ Q) U) [! a3 S7 G' g
10-21 Name 5 ~) q" C$ ^5 N5 @23-26 Bus voltage (control setpoint or solved value). " [ h t$ G: J0 q% \ Three default decimal places. . V, W* w5 N2 ^5 e27-30 Bus angle4 W: [+ C; O6 F7 |$ W1 R
31-35 Generation MW' M. `& m% D2 Y/ j# t+ h
36-40 Generation MVAR (from solution) " E2 q) I+ R: y& ~; T41-45 Generation MVAR low limit+ G- D- z& L: y- U# H6 ^, a
46-50 Generation MVAR high limit # u2 J9 n- @- o& b51-55 Bus at which generation controls voltage 4 _. l7 U5 p" Z5 |5 t56-60 Load MW # t- T9 \# }4 u* i8 a, |+ f& M61-65 Load MVAR 8 t. m8 | w; I, k* O, x& H' V; D! ]66-70 Shunt MVAR. Reactors are minus.1 i- s' g8 ?0 Q
71-72 Load flow area. (Used for area interchange and losses). & S0 ^* Z X/ g' uArea Interchange Cards (Code 15 cards)( F# B$ G: S' _5 [) ?2 M
====================================== 2 L6 _( O3 X/ {; ^5 _& k3-4 Load flow area number / B. v* l+ M0 _$ r, @) U5-8 Swing bus for area interchange. Adjusts generation at this bus W) Y5 k6 W3 w+ ? u* ~. V, R* y! ?
to meet area interchange requirement.2 ~ \3 b$ ^+ N
9-14 Area exports, MW. (+ = out of area)% t9 \; \* o, k3 r" v% c
15-19 Area Interchange tolerance, MW , x/ s- j7 w1 B. q- h( l# m1 J20-55 Area name; `' p3 w- X; R( D( H% S: I Z
56-60 Area load (usually left blank) 6 f Z d5 f1 E" x6 w; i61-65 Area losses (usually left blank) + R: f: Y1 |, t' f5 e; @$ s. X* D+ b* c- z2 J7 {# f
: R- L* w3 k8 z% g" c1 [1 x # j# r, m, L) b4 S$ V! WDescription of the PTI Load Flow Data Format 2 k6 x7 z5 z+ l k! N============================================ h, Q: S" r8 Y: {Note that PTI reserves the right to change the format at any time.) K5 h# U, w5 ^) o9 ~
For use with the IEEE 300 bus test case in PTI format. : q6 i% v. f$ ]( o6 tCase Identification Data ( {/ z: T4 F$ q/ c3 c) h1 b( U========================1 F% A5 g4 j Z
First record: IC,SBASE4 @+ K. k6 w5 K
IC - 0 for base case, 1 for change data to be added6 ]; y) W) c) x" r- [% g
SBASE - System MVA base + e" f4 ^) H `/ a. ]7 RRecords 2 and 3 - two lines of heading, up to 60 characters per line; J& X* ^4 i. z+ q% T. J! B5 z# V
Bus Data 3 R. U3 O) C$ ?+ b$ t========7 c8 K; s" D$ i; j, i& P6 t: f3 l
Bus data records, terminated by a record with a bus number of zero." G! C: U5 n+ k- ~ l' s, m* M& q+ s+ J
I,IDE,PL,QL,GL,BL,IA,VM,VA,'NAME',BASKL,ZONE 2 w) b/ e, _- j) M4 H I - Bus number (1 to 29997)/ g8 D3 l; e7 t; h3 R2 v
IDE - Bus type 8 Y5 {1 S1 E) ?& F- u; j 1 - Load bus (no generation), m. g1 f V( [6 X3 ^# x- {! w
2 - Generator or plant bus8 M4 [; q9 _. O/ a2 ] a- L) [
3 - Swing bus5 K/ p Q" ^2 e: J) ~# ^. }
4 - Islolated bus # A- c) I, e# ]; A1 \ PL - Load MW ( E% e' ^8 q1 C% s QL - Load MVAR 0 U( X2 `# ]) ]4 K6 s* m GL - Shunt conductance, MW at 1.0 per unit voltage % w# e* z6 @2 K2 \1 Q$ M! F9 q BL - Shunt susceptance, MVAR at 1.0 per unit voltage. (- = reactor) 3 E* n {" A4 O IA - Area number, 1-100 e, }) p6 \( X3 `/ u8 O0 Q5 x VM - Voltage magnitude, per unit* `$ u% p7 M: R( F5 W
VA - Voltage angle, degrees 9 r6 |: Z" [$ E# q! Q. t" c, b' K NAME - Bus name, 8 characters, must be enclosed in quotes & C/ w6 J1 E( O4 v9 ` BASKV - Base voltage, KV8 x' v/ q- d% u; N
ZONE - Loss zone, 1-9999 u$ a3 ^1 ^3 D3 `" G
Generator Data ( E2 S3 m+ w: y% y============== : i# K* B+ M* I: jGenerator data records, terminated by a generator with an index of zero.. u+ ~4 c0 B/ b7 g, X1 F
I,ID,PG,QG,QT,QB,VS,IREG,MBASE,ZR,ZX,RT,XT,GTAP,STAT,RMPCT,PT,PB8 i: B* f6 d q8 w2 [+ \" t
I - Bus number ; t2 {$ q& B; c4 L1 ]6 M2 CID - Machine identifier (0-9, A-Z)$ l. ?; Y" |9 x4 E% e
PG - MW output 9 n, J5 q3 Y1 U1 sQG - MVAR output . f. ^5 A. P/ J# A. s, R, yQT - Max MVAR # Q: s) R% q& G% R' k4 E iQB - Min MVAR- S% N+ I9 S; B5 Q! g0 H
VS - Voltage setpoint3 x2 c. p3 u" `# J. y0 N
IREG - Remote controlled bus index (must be type 1), zero to control own 9 C% z/ r1 N: @ `* B) j voltage, and must be zero for gen at swing bus % |+ J: ~6 g: e6 `5 ~* N# Y0 `7 ^( r tMBASE - Total MVA base of this machine (or machines), defaults to system6 n' f: c% I9 m
MVA base.1 y' ^$ X" m6 @$ X5 ]5 B
ZR,ZX - Machine impedance, pu on MBASE! \# |' l/ {2 O7 s- O+ o
RT,XT - Step up transformer impedance, p.u. on MBASE ! X! c7 @; e9 ^, [: t3 bGTAP - Step up transformer off nominal turns ratio4 ` R3 F* ~8 _+ v# _& |: e' a4 y! S
STAT - Machine status, 1 in service, 0 out of service ) u4 X( m4 `$ _RMPCT - Percent of total VARS required to hold voltage at bus IREG 0 F' C2 w/ v5 P+ Y. y) m9 N D- i) j( {5 a to come from bus I - for remote buses controlled by several generators 9 h" A0 |: i4 x7 D$ CPT - Max MW; G* @% t& U) T' _% U |, t
PB - Min MW1 G! J* @1 F6 L3 A, ~4 v, y- u) T7 t
Branch Data 1 k# t, C! |2 N3 w3 O( V |=========== r# M# P; {) v c% Q3 qBranch records, ending with a record with from bus of zero% q. [ n( R. ~, W. j" I! j# k Y8 G0 p
I,J,CKT,R,X,B,RATEA,RATEB,RATEC,RATIO,ANGLE,GI,BI,GJ,BJ,ST0 B! T0 s: w9 U& [0 B6 W4 {- _( ^
I - From bus number , j1 d9 G% E# [% v) dJ - To bus number/ |! x- Z$ v1 K+ y5 \4 k% e
CKT - Circuit identifier (two character) not clear if integer or alpha 6 v- n, ^" e2 b0 g1 `R - Resistance, per unit s1 W, N) u* M# o. t; ]
X - Reactance, per unit 4 ?" g+ a1 P7 x& O) F6 KB - Total line charging, per unit ( |+ H' s' b$ }6 VRATEA - MVA rating A ) V: w% E8 I6 M. VRATEB, RATEC - Higher MVA ratings# Y) l8 _! n0 X! A- F
RATIO - Transformer off nominal turns ratio# ^. G) ^; g. \$ y
ANGLE - Transformer phase shift angle % v6 d H1 O3 e M" Z! S8 qGI,BI - Line shunt complex admittance for shunt at from end (I) bus, pu. : B6 a: g3 W* ]& s$ U( \9 z5 MGJ,BJ - Line shunt complex admittance for shunt at to end (J) bus, pu. - U& z7 f2 u) f% m+ v. o# ~2 D# P pST - Initial branch status, 1 - in service, 0 - out of service 2 c5 w% m. s# {1 a) b3 `9 X! fTransformer Adjustment Data 9 f2 f* l' T* U S' W=========================== . n, c9 ?3 g& l, x0 D: PEnds with record with from bus of zero ! r6 t9 l2 F. [# @! RI,J,CKT,ICONT,RMA,RMI,VMA,VMI,STEP,TABLE2 y" C' o0 w2 m( w1 A
I - From bus number" A5 t0 {$ q1 [, \& h% b) u7 f) F
J - To bus number ; Q6 l1 s [4 @CKT - Circuit number 7 I: d" @- X* u& qICONT - Number of bus to control. If different from I or J, sign of ICONT 1 m8 x4 l- U; B determines control. Positive sign, close to impedance (untapped) bus, Q5 P0 O$ o' q4 ?
of transformer. Negative sign, opposite. ]* J: d: }: eRMA - Upper limit of turns ratio or phase shift3 p$ I' H6 p9 m% c+ H3 b: S% R
RMI - Lower limit of turns ratio or phase shift 3 u2 V" c! M1 \$ oVMA - Upper limit of controlled volts, MW or MVAR2 X0 Y6 @. n! ?% }) L7 k; D
VMI - Lower limit of controlled volts, MW or MVAR7 b' t0 j0 J# x# _4 u+ n
STEP - Turns ratio step increment " x, E0 Q4 B+ ]1 H: XTABLE - Zero, or number of a transformer impedance correction table 1-5$ s/ Q2 e$ ]! a; y, U9 c
Area Interchange Data 1 T8 v4 t0 a$ ?. Z' x6 y1 M% C+ C===================== 2 Z C8 P# u6 P" s( n" |3 }6 F! ]) _$ QEnds with I of zero 2 b) j4 ?2 I* }7 wI,ISW,PDES,PTOL,'ARNAM' , q! r1 j8 a' f$ A+ \4 y2 _I - Area number (1-100), o9 U$ C0 E1 V. r% ?
ISW - Area interchange slack bus number 6 c8 q" ]3 P) ^# _, V' O9 B" }$ VPDES - Desired net interchange, MW + = out.& f2 U: X" x" E+ u& b4 {! j
PTOL - Area interchange tolerance, MW+ X* h& w) H: H* r3 w
ARNAM - Area name, 8 characters, enclosed in single quotes.8 U9 e+ u1 o# G5 J
DC Line Data \( s7 ]& y3 X- m============ & Y; {5 R$ G5 i kEnds with I of zero1 p1 ^& a9 ^( e
Each DC line has three consecutive records) e) G0 p% u+ h3 H2 r4 Z
I,MDC,RDC,SETVL,VSCHD,VCMOD,RCOMP,DELTI,METER & V* u) j- U0 \# H7 R2 x8 F+ }IPR,NBR,ALFMAX,ALFMN,RCR,XCR,EBASR,TRR,TAPR,TPMXR,TPMNR,TSTPR 5 C& v9 }5 A2 L# g9 d( VIPI,NBI,GAMMX,GAMMN,RCI,XCI,EBASI,TRI,TAPI,TPMXI,TPMNI,TSTPI . d6 o9 [! a" ^$ w) \/ I iI - DC Line number2 p+ p/ i; B3 y+ n
MDC - Control mode 0 - blocked 1 - power 2 - current 2 z! ~, @7 ~' c9 ERDC - Resistance, ohms( x& C9 y; W6 X) h; q& w" F
SETVL - Current or power demand / O; e F2 ^- l9 t/ T9 M; MVSCHD - Scheduled compunded DC voltage, KV ( T7 p$ G5 |. ]/ J- u: G- n8 @VCMOD - Mode switch DC voltage, KV, switch to current control mode below this 0 w4 p; A8 W5 w: }. H# U: iRCOMP - Compounding resistance, ohms 1 }: b2 }8 k( DDELTI - Current margin, per unit of desired current ! {: e3 E5 g- \, K! Q: h! M* EMETER - Metered end code, R - rectifier I - Inverter 1 b8 v" a' ]. Y& kIPR - Rectifier converter bus number1 O n2 C9 ^; [5 v$ U+ k/ E
NBR - Number of birdges is series rectifier0 _1 b6 ^; i w2 m; M
ALFMAX - Maximum rectifier firing angle, degrees! k6 O) K, L6 J9 A+ |
ALFMN - Minimum rectifier firing angle, degrees4 g5 N, ?/ F2 A
RCR - Rectifier commutating transformer resistance, per bridge, ohms- n. J! j- F8 j8 L& k/ [
XCR - Rectifier commutating transformer reactance, per bridge, ohms7 R+ X3 |! x9 B7 |
EBASR - Rectifier primary base AC volts, KV 4 k7 w) P( O" l7 L; r$ f- p. XTRR - Rectifier transformer ratio & [; W+ h7 w+ l" xTAPR - Rectifier tap setting ' H; `3 o0 X+ O9 u, ?8 hTPMXR - Maximum rectifier tap setting , O) S) F5 H1 h* t8 l6 m3 t0 _TPMNR - Minimum rectifier tap setting2 F0 }/ {# m8 p3 }7 {
TSTPR - Rectifier tap step 6 [- k+ X; k: {7 i% ]Third record contains inverter quantities corresponding to rectifier: A- ^+ |' W9 h! y# u0 \
quantities above.% E" p' m. \" y, O# @
Switch Shunt Data: O/ J! o+ }5 j7 B' g
================= 9 _$ T9 i6 J+ r6 YEnds with I = 0., r8 X: Y8 s4 I. z
I,MODSW,VSWHI,VSWLO,SWREM,BINIT,N1,B1,N2,B2...N8,B8. e1 k f7 [! W, t/ @
I - Bus number; D# r ^; H: m* F
MODSW - Mode 0 - fixed 1 - discrete 2 - continuous Y5 g! N9 _' ~. UVSWHI - Desired voltage upper limit, per unit % O3 J6 X8 U8 E5 n5 fVSWLO - Desired voltage lower limit, per unit/ T$ c$ l9 g% F
SWREM - Number of remote bus to control. 0 to control own bus.5 D' p& D4 W' L
VDES - Desired voltage setpoint, per unit3 F4 l5 D1 L2 V2 }2 D6 Y; \8 O$ \* G+ V( x
BINIT - Initial switched shunt admittance, MVAR at 1.0 per unit volts ( N) F$ u# W B3 p6 ?" F+ A, t* }N1 - Number of steps for block 1, first 0 is end of blocks 6 N, B- S+ m5 B( ^B1 - Admittance increment of block 1 in MVAR at 1.0 per unit volts.- s' E6 w0 y4 c1 R& A w3 l
N2, B2, etc, as N1, B1
