发表于 2008-5-2 06:28:47
有说明书阿,具体的接口(C++)如下:
2 [: P/ a) f6 A" Y# \$ Mextern "C" _declspec(dllexport) int _stdcall LF_UP0(
+ l+ C" D0 T# m$ @9 q h int &Markend,const int &NTime, const int *Npar,+ g! ?% t% q' a8 Z7 b
const double * varin,const int &nvarin,
% v3 k; l4 u& Q3 P double * varout,const int &nvarout,
) q6 F( ]/ T( a( E double * varprn,const int &nvarprn,
# R( U0 p' K7 h8 `: S& w3 i' _" U const double * vector,const int &nvector,7 O" e p0 N2 a+ ]1 g) B9 h, i
const int *vp,const int *nvp,const int &nnvp)7 \- C8 N k0 U; k( y0 o8 ~3 S
/******* Arguments description **************************************** + E, k8 M) ~1 j5 t; u4 e* u) v
Markend: mark of computing end given by UP -
: A* J8 Y8 `0 W$ p% w0 h ( 0: end of compution; 1: continuing) -
% a" F8 }0 L+ S! }5 f Ntime : times, the UP called by LF, provided by LF -! A8 ?& N0 G( w7 z8 L
NPar : Group no. of parameter -2 F0 Z; A; y! J+ |, U$ w
F1 : Array of input variavles provided by LF, dimension nf1 -2 l% d4 T1 z; X7 p; I
F2 : Array of output variavles, provided by UP, dimension nf2 -
2 z, z# [* j( z: [7 l7 M& P F3 : Array of print variavles, provided by UP, dimension nf3 -
& z5 c/ h" ]& F; c, o V1 : Array of input vectors,provided by LF, dimension nv1 -
, [0 ?5 H1 v5 t% j6 [0 s IVP : start position pointer of each vector in V1, dimension nnvp-& R1 p5 d6 ?; n ~) F0 |# R
NVP : dimension of each vector in V1, dimension nnvp -8 s# U8 e9 @0 ?- C# C6 _% u7 t
