查看: 5194|回复: 18
现代电力系统分析(第3版)(Modern power system analysis
 火 [复制链接]
    2020-12-8 11:59
  • 签到天数: 105 天
    累计签到:223 天
    发表于 2010-4-14 10:04:43 | 显示全部楼层 |阅读模式
    电子图书
    电子图书名: Modern power system analysis
    编者: (印度)科萨里(Kothari.D P)
    所属专业方向: 电自
    内容简介: Preface to First Edition
    1. Introduction
    1.1 A Perspective
    1.2 Structure of Power Systems
    1.3 Conventional Sources of Electric Energy
    1.4 Renewable Energy Sources
    1.5 Energy Storage
    1.6 Growth of Power Systems in India
    1.7 Energy Conservation
    1.8 Deregulation
    1.9 Distributed and Dispersed Generation
    1.10 Environmental Aspects of Electric Energy Generation
    1.11 Power System Engineers and Power System Studies 3!
    1.12 Use of Computers and Microprocessors
    1.13 Problems Facing Indian Power Industry and its Choices
    References
    2. Inductance and Resistance of Transmission Lines
    2.1 Introduction
    2.2 Definition of Inductance
    2.3 Flux Linkages of an Isolated Current-Carrying Conductor
    2.4 Inductance of a Single-Phase Two-Wire Line
    2.5 Conductor Types
    2.6 Flux Linkages of one Conductor in a Group
    2.7 Inductance of Composite Conductor Lines
    2.8 Inductance of Three-Phase Lines
    2.9 Double-Circuit Three-Phase Lines
    2.10 Bundled Conductors
    2.11 Resistance
    2.12 Skin Effect and Proximity Effect
    Problems
    References
    3. Capacitance of Transmission Lines
    3.1 Introduction
    3.2 Electric Field of a Long Straight Conductor
    3.3 Potential Difference between two Conductors of a Group of Parallel Conductors
    3.4 Capacitance of a Two-Wire Line
    3.5 Capacitance of a Three-Phase Line with Equilateral Spacing
    3.6 Capacitance of a Three-Phase Line with Unsymmetrical Spacing
    3.7 Effect of Earth on Transmission Line Capacitance
    3.8 Method of GMD (Modified)
    3.9 Bundled Conductors
    Problems
    References
    4. Representation of Power System Components
    4.1 Introduction
    4.2 Single-phase Solution of Balanced Three-phase Networks
    4.3 One-Line Diagram and Impedance or Reactance Diagram
    4.4 Per Unit (PU) System
    4.5 Complex Power
    4.6 Synchronous Machine
    4.7 Representation of Loads
    Problems
    References
    5. Characteristics and Performance of Power Transmission Lines
    5.1 Introduction
    5.2 Short Transmission Line
    5.3 Medium Transmission Line
    5.4 The Long Transmission Line——Rigorous Solution
    5.5 Interpretation of the Long Line Equations
    5.6 Ferranti Effect
    5.7 Tuned Power Lines
    5.8 The Equivalent Circuit of a Long Line
    5.9 Power Flow through a Transmission Line
    5.10 Methods of Voltage Control
    Problems
    References
    6. Load Flow Studies
    6.1 Introduction
    6.2 Network Model Formulation
    6.3 Formation of YBus by Singular Transformation
    6.4 Load Flow Problem
    6.5 Gauss-Seidel Method
    6.6 Newton-Raphson (NR) Method
    6.7 Decoupled Load Flow Methods
    6.8 Comparison of Load Flow Methods
    6.9 Control of Voltage Profile
    Problems
    References
    7. 0 ptimal System Operation
    7.1 Introduction
    7.2 Optimal Operation of Generators on a Bus Bar
    7.3 Optimal Unit Commitment (UC)
    7.4 Reliability Considerations
    7.5 Optimum Generation Scheduling
    7.6 Optimal Load Flow Solution
    7.7 Optimal Scheduling of Hydrothermal System
    Problems
    References
    8. Automatic Generation and Voltage Control
    8.1 Introduction
    8.2 Load Frequency Control (Single Area Case)
    8.3 Load Frequency Control and Economic Despatch Control
    8.4 Two-Area Load Frequency Control
    8.5 Optimal (Two-Area) Load Frequency Control
    8.6 Automatic Voltage Control
    8.7 Load Frequency Control with Generation Rate Constraints (GRCs)
    8.8 Speed Governor Dead-Band and Its Effect on AGC
    8.9 Digital LF Controllers
    8.10 Decentralized Control
    Problems
    References
    9. Symmetrical Fault Analysis
    9.1 Introduction
    9.2 Transient on a Transmission Line
    9.3 Short Circuit of a Synchronous Machine (On No Load)
    9.4 Short Circuit of a Loaded Synchronous Machine
    9.5 SeIection of Circuit Breakers
    9.6 Algorithm for Short Circuit Studies
    9.7 ZBusFormulation
    Problems
    References
    10. Symmetrical Components
    10.1 Introduction
    10.2 Symmetrical Component Transformation
    10.3 Phase Shift in Star-Delta Transformers
    10.4 Sequence Impedances of Transmission Lines
    10.5 Sequence Impedances and Sequence Network of Power System
    10.6 Sequence Impedances and Networks of Synchronous Machine
    10.7 Sequence Impedances of Transmission Lines
    10.8 Sequence Impedances and Networks of Transformers
    10.9 Construction of Sequence Networks of a Power System
    Problems
    References
    11. Unsymmetrical Fault Analysis
    11.1 Introduction
    11.2 Symmetrical Component Analysis of Unsymmetrical Faults
    11.3 Single Line-To-Ground (LG) Fault
    11.4 Line-To-Line (LL) Fault
    11.5 Double Line-To-Ground (LLG) Fault
    11.6 Open Conductor Faults
    11.7 Bus Impedance Matrix Method For Analysis of Unsymmetrical Shunt Faults
    Problems
    References
    12. Power System Stability
    12.1 Introduction
    12.2 Dynamics of a Synchronous Machine
    12.3 Power Angle Equation
    12.4 Node Elimination Technique
    12.5 Simple Systems
    12.6 Steady State Stability
    12.7 Transient Stability
    12.8 Equal Area Criterion
    12.9 Numerical Solution of Swing Equation
    12.10 Multimachine Stability
    12.11 Some Factors Affecting Transient Stability
    Problems
    References
    出版社: 清华大学出版社
    来源:
    哪位牛人有这本书的电子版的,有的发给小弟分啊!mingyu2009@sina.com.谢谢啊!
    发表于 2010-4-15 10:28:08 | 显示全部楼层
    和王院士的书有什么区别?
    发表于 2010-4-15 10:41:29 | 显示全部楼层
    我晕,全是英文的么???
    发表于 2010-5-7 13:36:48 | 显示全部楼层
    同求这本书啊
    3 O* u+ E1 O# F; J8 U* o( o) u7 R实在不行就自己去买了。
    2020-12-8 11:59
  • 签到天数: 105 天
    累计签到:223 天
     楼主| 发表于 2010-5-9 10:03:31 | 显示全部楼层
    同意楼上的!
    发表于 2010-6-8 11:04:00 | 显示全部楼层
    科萨里科萨里科萨里
    发表于 2010-8-14 14:39:42 | 显示全部楼层
    非常想要的书
    发表于 2010-8-14 15:20:20 | 显示全部楼层
    这么强的书都有啊
    2019-1-25 10:10
  • 签到天数: 3 天
    累计签到:3 天
    发表于 2010-9-6 00:33:23 | 显示全部楼层
    看看能下不?
    2019-1-25 10:10
  • 签到天数: 3 天
    累计签到:3 天
    发表于 2010-9-6 00:35:13 | 显示全部楼层
    买了纸版的,但一直没找到电子版,再等等看,估计最后得自己扫了。
    GMT+8, 2026-11-20 10:26
