查看: 1793|回复: 2
跪求Electric Power Systems Research上的文献
发表于 2010-4-9 10:33:11 | 显示全部楼层 |阅读模式
# Q! g! i9 _! K6 }
7 R* T0 J' A- p( qDistribution system load flow calculation with microcomputer implementation * B- I' H! ^5 E. |
% n; ^7 p0 R. ^% g+ f# B
. z6 q. S; `9 @) t& ]
: b; \8 A. Q% l1 R9 ~' u4 z. RAbstract
: o" y  x" o* v6 Q9 P0 mIn this paper, a load flow calculation method for a radial distribution system is developed. The proposed method, which is derived from a Z-loop analysis, is very straightforward and simple without unnecessary mathematical approximations. It requires the same storage size as the Gauss-Seidel method, but less computation time than the conventional Newton-Raphson program. It is attractive for accurate or approximate off-line and on-line routines and contingency calculations for radial systems. The proposed solution algorithm can be implemented directly and efficiently into microcomputers with limited storage capacities. To examine the effectiveness, three normal radial distribution systems for 13-, 22-, and 58-bus systems were studied by the proposed method, and the convergence characteristics of a 43-bus ill-conditioned system are compared with the Newton-Raphson method. The proposed method is recommended for distribution system load flow analysis.
    2020-4-27 20:29
  • 签到天数: 84 天
    累计签到:84 天
    发表于 2010-4-9 13:16:13 | 显示全部楼层
    把作者、发表时间登出来
     楼主| 发表于 2010-4-9 15:59:00 | 显示全部楼层
    回复 2# zhpy . V0 C4 X* {( a$ O# B
    ! a7 y& L7 F+ O, a6 D1 a& n: _- w5 v" G$ H- {
        你好,
    + m3 @* K& O7 k2 m& i    作者是:C. E. Lin          Institute of Aeronautics and Astronautics, Cheng Kung University, Tainan, 70101, Taipei, Taiwan, PRC* j5 d. c9 g' p3 M3 b/ N
                    Y. W. Huang   Institute of Electrical Engineering, Cheng Kung University, Tainan, 70101, Taipei, Taiwan, PRC
    ; g% k. q- k" F( p0 Y3 q                C. L. Huang    Institute of Electrical Engineering, Cheng Kung University, Tainan, 70101, Taipei, Taiwan, PRC
    : `/ ?5 V* f  `# D+ Q0 c   发表在   Electric Power Systems Research上面,Volume 13, Issue 2, October 1987, Pages 139-145 。! s3 [2 K7 G. ]$ Z" a
      如果能找到,麻烦你发到我邮箱,yasibeiersi@yahoo.cn.在此谢过。
    GMT+8, 2026-11-17 04:54
