TA的每日心情 | 郁闷 2019-12-23 14:39 |
签到天数: 281 天 连续签到: 1 天 [LV.8]以坛为家I 累计签到:281 天 连续签到:1 天
楼主 |
发表于 2018-11-10 15:43:18
https://software.intel.com/en-us ... c-os-x/topic/559950
, _9 D2 d! J# q& J$ Z6 F4 [+ k) ~5 |1 }5 l6 V/ C
The interesting (to me, anyway) part of this question is that the do-variable in an io-implied-do does NOT have "statement scope" the way a DATA implied-do or array constructor implied-do variable do. With statement scope, the implied-do variable is a new, different variable that inherits only the type of any outer-scope variable (but that type must be integer.)The "i" in the I/O implied DO is the same variable as the line 1 DO control variable and ifort is absolutely correct in complaining about this., pgf90 could support this as an extension, but would need to have the ability to diagnose it (perhaps through a standards checking switch), or else risk being a nonconforming implementation.
' I9 W* G0 T3 d5 q7 O l7 w5 ?. V4 G5 r
The other interesting part is that we do, sort-of, allow changing DO variables, as an extension, but you have to do it by passing the variable to a procedure which then changes it. ifort recognizes the possibility and generates an explicit test rather than a loop count if it sees this." {3 f+ Q) @; _
2 R2 o* K L; T' A( G2 g
# p" ^3 l0 t$ I5 V s6 R( M这个问题的有趣(对我来说,无论如何)部分是io-implied-do中的do-variable没有DATA隐含的方式或者数组构造函数暗示-do变量的方式。 对于语句范围,implied-do变量是一个新的,不同的变量,它只继承任何外部作用域变量的类型(但该类型必须是整数。)I / O暗示DO中的“i”是相同的变量 作为第1行DO控制变量和ifort在抱怨这一点时绝对正确。,pgf90可以支持这作为扩展,但是需要能够诊断它(可能通过标准检查开关),否则冒险成为 不合格的实施。
$ F9 V. w1 \. K4 T7 ~7 J
: i* u2 X8 V, K5 H另一个有趣的部分是我们这样做,排序,允许更改DO变量,作为扩展,但你必须通过将变量传递给一个程序然后更改它来完成它。 如果它看到这个,ifort会识别出这种可能性并生成一个显式测试而不是一个循环计数。 |
