TA的每日心情 | 郁闷 2018-7-18 16:57 |
签到天数: 21 天 连续签到: 1 天 [LV.4]偶尔看看III 累计签到:21 天 连续签到:1 天
楼主 |
发表于 2010-4-6 08:10:39
其中运行报告的错误如下:请大家看看,有解决方法吗?" X% l( N( R- e/ Y4 s0 q
--- 8 cards of disk file read into card cache cells 1 onward.+ D6 y6 Z! w9 o; x
Comment card is ignored. |C RAM TABLES
7 ]* t- k8 A: v Default multiplier = 3.000 |DEFAULT 3.0
+ `% y5 V, k, K0 L# N& ] 1st card (Lists 1-10). |BLANK; K* ^! R$ R3 I( y9 Q9 U
2nd card (Lists 11-20). |BLANK- Y1 ^- X2 t. f( g$ Z
3rd card (Lists 21-29). | 3000
2 U& O7 _5 A8 z, i, x' t/ {: m% X Supplemental offsets. | 240000 7423 h+ F4 s4 n: n. L& w4 d6 C% F
Alternative Transients Program (ATP), Watcom translation. All rights reserved by Can/Am user group of Portland, Oregon, USA.4 B, D7 V2 D1 k5 w6 P
Date (dd-mth-yy) and time of day (hh.mm.ss) = 06-Apr-10 08.12.06 Name of disk plot file, if any, is E:\ATP\ATP\EXA
3 M* j; T* s- w' T9 _; i4 q* L% lConsult the 860-page ATP Rule Book of the Can/Am EMTP User Group in Portland, Oregon, USA. Program is no older than December,: [6 n) r& g! {! ?) K
`97.
^. G: W' N2 u/ ~4 k$ gTotal size of LABCOM tables = 244116 INTEGER words. VARDIM List Sizes follow : 752 900 1500 150 7500 120
( u% [" @9 X. F$ z 2100 5250 225 480 150 150 15000 60 10800 120 12 15 4800 2580 3000 1050 12000 9 1200 252 76 21000
0 p: p! ~. W, i. J--------------------------------------------------+--------------------------------------------------------------------------------
& Z, R* m( e/ P/ U2 GDescriptive interpretation of input data cards. | Input data card images are shown below, all 80 columns, character by character! G2 C4 h j' F! C
0 1 2 3 4 5 6 7 8
( m$ Z: [! Z0 y9 R( a7 J6 f 0123456789012345678901234567890123456789012345678901234567890123456789012345678907 o" j: q7 u) L0 \, m5 N
--------------------------------------------------+--------------------------------------------------------------------------------9 Q4 S! W) L1 T3 Y
Comment card. NUMDCD = 1. |C data:E:\ATP\ATP\EXA_9.ATP
1 h( h* P2 U x5 j1 y+ [% U2 X; h5 O. R6 P( }8 F
------------------------------------------------------------------------------------------------------------------------------------1 d* A/ P- T& x+ p9 |
ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/
$ J7 q( h+ r5 X/ F! NERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/1 o7 I0 B: E; U3 ~! k
4 N0 B, N, Q* M3 w) m m! a# L8 W3 [You lose, fella. The EMTP logic has detected an error condition, and is now going to terminate program execution. The following# _6 i. S z6 i; S6 X/ ]7 y
message summarizes the circumstances leading to this situation. Where an otherwise-unidentified data card is referred to, or where8 e$ V/ f3 G4 K/ S1 [
the "last" card is mentioned, it is the most recently read card of the input data that is meant. The 80-column image of this card# J3 @) z$ N" q- D8 l
is generally the last one printed out prior to this termination message. But possibly this last-read card has not yet been
, S4 n/ V1 O- V- R0 S% Ldisplayed, so a copy follows:7 j* J$ y# p$ H: Q
" --- 1 cards of disk file read into card cache cells 1 onward. "! `1 \) |# p6 e" B
KILL code number Overlay number Nearby statement number9 b- @% k8 i: a0 d0 D
22 1 2843/ y9 K' ]' O5 i" p$ o
KILL = 22. The last-read data card is not recognized as either a comment card or a special-request card that can precede
; K( f& E/ V, F" o' i) } a9 Xmiscellaneous data cards. Hence, it is taken to be the floating-point miscellaneous data card. But the presence of an alphabetical
. I; I, V7 k4 S/ v" kletter other than "E" on the card makes it illegal as a miscellaneous data card, too. Try again.
% N% |8 E, ?" w, y------------------------------------------------------------------------------------------------------------------------------------
7 s7 c( j5 C8 G/ hERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/
7 [2 G; x, x3 g5 }* w2 W" cERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/
$ i% R9 ?( V- q3 ]1 G------------------------------------------------------------------------------------------------------------------------------------
+ h: k; @: S4 f2 f1 t3 I/ y g r: {2 q# M$ Y) Q
Timing figures characterizing central processor (CP) solution speed. ---------------------------- CP sec Wait sec Real sec
- h b' q' |/ [8 A4 y Totals 0.094 0.000 0.094+ s) z+ n, ?! l( i$ p
. V% f* V; _# [2 \: Z3 @: {2 V
Comment card. NUMDCD = 1. |C data:E:\ATP\ATP\EXA_9.ATP |
