发表于 2014-8-26 19:20:04
关于 Number of Cables Number of Conductors具体说明以及为何Number of Conductors选项为灰色不可修改详见pscad user guide 原文如下:( Y& ~0 i# n1 |3 k8 W) v4 D; A
Number of Cables: The Number of Cables parameter in the Cable Interface components specifies how many individual cables there are in the system. Each of these cables however, could contain different numbers of conducting layers, and so the total number of conductors is arbitrary (this is why the Number of Conductors parameter is disabled in the Cable Configuration component). The user is required to specify the number of conducting layers for each cable in the Cable Interface components. This data must8 G r. ^- I9 t J+ L- }
match what is defined within the Cable Segment Cross-Section.(翻译不好,原文解释的简单清楚) |
