查看: 7727|回复: 16
请问区域潮流断面的热稳极限,暂稳极限,动稳极限以及静稳极限怎么求取
 火 [复制链接]
发表于 2010-1-17 11:16:47 | 显示全部楼层 |阅读模式
发表于 2010-3-19 15:59:07 | 显示全部楼层
连续潮流计算
发表于 2010-3-19 23:48:03 | 显示全部楼层
回复 1# yongzhe578 : u* l+ S4 z6 x$ x' e
* R# [7 r% [& c# U4 j8 g+ ~% S, f
4 \8 R  N# Y$ a; c0 i) B- K "热稳极限" is a kind of conductor property. You should be able to find it from conductor manuals. Try to not exceeding a conductor's "热稳极限" by running a normal power flow analysis and any other contingency analysis. In simple, don't burn your conductor.1 t8 Z4 D. r6 e! x) N
1 B# A3 [8 \% C$ t  b$ O6 ]
"静稳极限" could be calculated by ignoring any dynamic models like exiter, governor, stabilizer, etc. Typically this value could be calculated without doing a real time simulation and then it could be provided by an on-line analysis software. 5 Q3 r( }9 [5 J; a( e
( e& S; S/ G' J# C) z- _
"动稳极限", similar to "静稳极限", with control devices like exciter modeled. Both "静稳极限" and "动稳极限" apply to small disturbance.  * e% A. D$ d& U' ~
* p" K; @" ]5 q1 g% M6 l. W* ]6 {9 H1 S. ]"暂稳极限" is used to make sure the system will come back to previous stable state or changed stable state after a big disturbance like a fault, generator disconnection, reclosing. It needs a real time simulation and it is not possible for an on-line analysis software to provide such analysis currently.
1 P' f/ p* ]$ I' B
# m0 L7 l) @( x3 PMost popular stability analysis software should be able to provide these analysis for you. For theoretical understanding, I would recommend you to read page 133 of professor Ni-Yi-Xin's book "Dynamic Power System Theory and Analysis" which could be found here:
' R+ w* [+ l! ]! q* Z( [' |1 g. E2 [' N8 D+ m, r
"倪以信-动态电力系统的理论和分析.高清晰PDF"
6 V1 M2 K2 B, N' _ https://tech.cepsc.com/viewthread.php?tid=39421&extra=&highlight=%B6%AF%CC%AC%B5%E7%C1%A6%CF%B5%CD%B3%B5%C4%C0%ED%C2%DB%BA%CD%B7%D6%CE%F6&page=1
发表于 2010-3-25 20:26:36 | 显示全部楼层
请问区域潮流断面的热稳极限,暂稳极限,动稳极限以及静稳极限# w5 X. T% k. G9 z4 J( ~
1 热稳极限 考虑的主要是断面输电线路自身的传输容量极限 只要不损害输电线 就OK
% f& q6 Q1 ^7 I! v+ h2 暂稳极限 是发生断面一天线路继电保护装置跳开 断线 或者发生短路断开后 其它输电线路能否保证断面传输的要求 N-1 校验算法! k. D- u/ P; Q  e
3 静态稳定极限 是断面承担的功率逐渐增加,应用连续潮流计算 到潮流方程雅可比矩阵奇异 即SNB点
1 @( _; f% W  f+ S$ ~# P# G4 动态稳定极限 接触不多/ {) h; ?6 g# J0 }" `2 Y9 U
应当是考虑了各种控制装置的调节作用 时的极限点
发表于 2010-4-2 14:48:38 | 显示全部楼层
对不起我的大学是在国外读的,所以中文术语不是太好,断面是不是只的是因为一些情况而断开某根输电线?
) |/ i1 o/ R. J9 x! _$ Y动态稳定应该是dynamic stability吧,应该是用一个small signal analysis的工具(小信号研究?)来研究,研究模型中generator control system也需要包括。这个analysis就是对所研究电网的state space matrix做eigenvalue study。所得的eigenvalue即表明震荡的damping和频率。damping需为负值。我猜你的问题就是看当某条输电线被断开后,是否有某个震荡的damping不够而引发发电机组的tripping吧。
发表于 2010-4-2 18:10:28 | 显示全部楼层
大家都挺专业的啊,为什么我就不知道呢,得加强了
发表于 2010-4-5 08:00:34 | 显示全部楼层
学习学习!
发表于 2010-10-22 17:26:03 | 显示全部楼层
谢谢啊~!~!~!~!~!~!~!
发表于 2011-12-19 20:08:01 | 显示全部楼层
学习学习,受教了
发表于 2012-1-28 13:41:04 | 显示全部楼层
看了大家的讨论,挺有用的,学习了呀
GMT+8, 2026-11-20 07:59
