查看: 2482|回复: 6
Control Design Techniques in Power Electronics Devices
发表于 2009-12-27 03:21:55 | 显示全部楼层 |阅读模式
电子图书
电子图书名: Control Design Techniques in Power Electronics Devices
编者: Hebertt Sira-Ramírez and Ramón Silva-Ortigoza_
所属专业方向: Power Electronics
内容简介: This book is intended for researchers, teachers, and students willing to explore
conceptual bridges between the fields of Automatic Control and Power
Electronics
出版社: Springer
来源:
5 z! F0 F5 m5 d3 m0 [& u, j
# O0 X- K# P  n1 bPart I Modelling
$ U% l2 q9 C+ r( z% ^, D* v2 Modelling of DC-to-DC Power Converters . . . . . . . . . . . . . . . . . 11
7 S/ b. r5 u+ B- T6 i0 `2.1 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
1 B, M' d  u: _/ L6 N2.2 The Buck Converter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
2 C! n8 ^9 ?1 N# X2.2.1 Model of the Converter . . . . . . . . . . . . . . . . . . . . . . . . . . . . 147 O( I" O% Z- E- E! O0 l1 [
2.2.2 Normalization. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15# |9 {0 ]7 ^" g& v2 _, N
2.2.3 Equilibrium Point and Static Transfer Function . . . . . . . 16# G: f2 }$ I/ l0 y2 \
2.2.4 A Buck Converter Prototype . . . . . . . . . . . . . . . . . . . . . . . . 18
! t5 q% k8 F+ {% ?, a! e5 ]8 g2.3 The Boost Converter. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20: q9 @2 Y  S# K% t% W4 g
2.3.1 Model of the Converter . . . . . . . . . . . . . . . . . . . . . . . . . . . . 22
- R7 O" a% w7 }& ]& f# c2.3.2 Normalization. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 236 z) f3 B3 |8 _( j! _- D% U
2.3.3 Equilibrium Point and Static Transfer Function . . . . . . . 23, o% x4 y7 c3 ?2 w* Z
2.3.4 Alternative Model of the Boost Converter . . . . . . . . . . . . 247 }5 X7 R) K/ ~/ n* g; x
2.3.5 A Boost Converter Prototype . . . . . . . . . . . . . . . . . . . . . . . 252 Y) J& \' D+ ?; e3 v$ Q
2.4 The Buck-Boost Converter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 27$ H: S+ g" r4 h9 R: b5 E, h* L2 S. z
2.4.1 Model of the Converter . . . . . . . . . . . . . . . . . . . . . . . . . . . . 277 F2 I! v" M0 {6 t/ s
2.4.2 Normalization. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 28
8 a' W3 m# W( P/ u2.4.3 Equilibrium Point and Static Transfer Function . . . . . . . 29' w5 \/ x# p- Z% b+ Z! o5 C) T
2.4.4 A Buck-Boost Converter Prototype . . . . . . . . . . . . . . . . . . 30
9 o7 F, m# E, m. J0 y- g2.5 The Non-inverting Buck-Boost Converter . . . . . . . . . . . . . . . . . . . 311 C3 K( A# u( s  c7 [; l
+ L: z: W- r7 t
1 E* |  Q" M  I- c0 JPart II Controller Design Methods
9 `* f2 D8 c( B: F2 ?* t8 ^4 T; O3 Sliding Mode Control . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 61
& X3 `$ b3 p  {4 c' j, W3.1 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 61
! \1 N; u7 ~* d- m9 R) \3.2 Variable Structure Systems . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 623 f. g1 \" ~9 x. F. ~. o' i% O5 D
3.2.1 Control of Single Switch Regulated Systems . . . . . . . . . . 62  a& Z1 R* D1 r' |  {) x! `
3.2.2 Sliding Surfaces . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 64+ l# V& T: J' D( n, ]2 n
3.2.3 Notation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 65
3 a% i5 i' P, G! G& V3.2.4 Equivalent Control and the Ideal Sliding Dynamics . . . . 65/ a. w, Y1 D) i
3.2.5 Accessibility of the Sliding Surface . . . . . . . . . . . . . . . . . . . 67
) d) \% J; c& P9 V; c7 {3.2.6 Invariance Conditions for Matched Perturbations . . . . . . 69
# f6 d; ?% n0 n6 {$ C9 [- V, o3.3 Control of the Boost Converter . . . . . . . . . . . . . . . . . . . . . . . . . . . . 71
* n, g( h. I4 @6 d4 F( [3.3.1 Direct Control . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 71( Y5 ?; a$ O& B7 v
3.3.2 Indirect Control . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 721 b6 _1 ]8 u* n
3.3.3 Simulations . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 74' s& \( y3 t" h( s
3.3.4 Experimental Implementation . . . . . . . . . . . . . . . . . . . . . . . 75; u0 r6 n) I6 u0 n9 m9 M
3.4 Control of the Buck-Boost Converter. . . . . . . . . . . . . . . . . . . . . . .
5 O+ z* b3 _" o4 Z( Q3 `, R% e
3 M$ K/ j) y' p: _5 l2 nPart III Applications
1 {6 N& S1 Z) u  J+ v6 DC-to-AC Power Conversion . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 361' G7 k* m; Z3 X3 R  E8 k* w
6.1 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 361) p7 t6 ?5 M: j' E; ^! H$ `
6.2 Nominal Trajectories in DC-to-AC Power Conversion . . . . . . . . 363
; j; N  b6 O5 y/ b0 v! A6.2.1 The Buck Converter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 363, d$ T' R' o4 d5 F+ o9 w; v( M- k; }
6.2.2 Two-Sided Σ − Δ Modulation . . . . . . . . . . . . . . . . . . . . . . 365
2 |. x; R2 z- u: \4 \4 |! a6.2.3 The Boost Converter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3661 K. _, ~8 m" V5 i
6.2.4 The Buck-Boost Converter . . . . . . . . . . . . . . . . . . . . . . . . . 370
7 ]9 n4 Y  |8 P3 q- Z6.3 An Approximate Linearization Approach . . . . . . . . . . . . . . . . . . . 371; z% Z' c8 f5 A* A+ i' X7 M
6.3.1 The Boost Converter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 371# [. ]+ ?4 K" |9 _- Q8 I7 e  O
6.3.2 The Buck-Boost Converter . . . . . . . . . . . . . . . . . . . . . . . . . 373( `# V: d( z- S; }7 ?* r
6.4 A Flatness Based Approach. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 374
& T/ q+ W3 J) @8 k$ X* M6.4.1 The Double Bridge Buck Converter . . . . . . . . . . . . . . . . . . 374
, k6 d4 y4 p3 k! o! K6.4.2 The Boost Converter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 375
2 l+ W! s) a# ]' z; h6.4.3 The Buck-Boost Converter . . . . . . . . . . . . . . . . . . . . . . . . . 376
) \! |0 X* E" ~( z" S4 D& ]6 t6.5 A Sliding Mode Control Approach . . . . . . . . . . . . . . . . . . . . . . . . . 378
* @0 z0 N1 L8 G' i6.5.1 The Boost Converter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 378# R. L' ]( Q! e4 X: u% j- r: G) w% L
6.5.2 A Feasible Indirect Input Current Tracking Approach . . 378( Q; h' N' D8 @  ^& [2 q" _
6.6 Exact Tracking Error Dynamics Passive Output Feedback& W6 C: [2 T. p# }
Control . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 380
7 O2 i# @2 Z2 |6.6.1 The Double Bridge Buck Converter . . . . . . . . . . . . . . . . . . 380
) P4 B" s# n' R1 A: }6.6.2 The Boost Converter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 381; f/ n4 v9 [( q/ p3 t
6.6.3 The Buck-Boost Converter . . . . . . . . . . . . . . . . . . . . . . . . . 383
/ X) n6 d# x$ ?% C0 ~" \& u' i) O+ X  o! }
3 i0 D8 h. p; L, q2 j3 |
HOPE it helps!
Control Design Techniques in Power Electronics Devices.rar
11 MB, 下载次数: 0, 下载积分: 威望 -2 点, 学分 -5 点
发表于 2010-4-28 18:01:59 | 显示全部楼层
哇,都是英文的啊~有难度哦~哈哈
发表于 2010-6-6 16:27:03 | 显示全部楼层
挺好的书,梦寐以求
    2017-11-9 18:03
    发表于 2010-6-6 21:19:35 | 显示全部楼层
    已经有这本书了很好的书
    发表于 2010-9-27 20:36:05 | 显示全部楼层
    这本书没看过,楼上的感觉咋样
    发表于 2011-2-27 19:27:42 | 显示全部楼层
    这本书如何?请指教
    发表于 2011-12-8 22:37:04 | 显示全部楼层
    谢谢楼主
    GMT+8, 2026-11-20 09:33
