实验中需要把几个信号源加减操作,应用ATPDraw的TACS的Fortran statements中math中元件连接电路,但运行出现问题,没明白什么意思。急需大家的帮忙!谢谢啦! 2 r' @( X. ~: {, T" l0 U " t+ A" ~" H: c" l8 H! h5 H1 lYou lose, fella. The EMTP logic has detected an error condition, and is now going to terminate program execution. The following , \5 v- T: k$ u/ a5 ^message summarizes the circumstances leading to this situation. Where an otherwise-unidentified data card is referred to, or wherethe "last" card is mentioned, it is the most recently read card of the input data that is meant. The 80-column image of this card is generally the last one printed out prior to this termination message. But possibly this last-read card has not yet been 8 D9 M$ i3 O& G8 Wdisplayed, so a copy follows: $ }; s- f' M5 z' L5 \ " & _8 B# v$ w2 [ N; { " * S' l! c* A& v6 K KILL code number Overlay number Nearby statement number # m. G6 f0 P1 F( t8 G2 ~ 143 2 21146 G7 |3 Y! i2 P% m* l
KILL = 143. TACS name "XX0008" is associated with a supplemental variable or device for which the input "XX0006" is undefined.The purported input name is neither the output of a TACS function block, nor is it the name of a TACS source. The name does not identify any other supplemental variable or device, either, at least not any that has been defined prior to the one now being considered (as would be required by TACS ordering rules).
