查看: 2975|回复: 1
不错的双馈电机低压穿越文章,ieee英文
    2017-10-15 18:45
    发表于 2009-10-22 10:15:16 | 显示全部楼层 |阅读模式
    论文文献
    标题: analysis on DFIG wind power system low voltage ride through
    作者:
    所属专业方向: 风力发电低压穿越
    摘要: Due to the double fed induction generator’s (DFIG)
    advantage of controlling active and reactive power
    independently and partial power converter, DFIG is becoming
    a popular type of wind power generation system. Nowadays,
    the grid code demands that the wind power generator
    possesses the ability of riding through the grid voltage sags,
    only when the grid voltage drops below the specific curve, the
    wind turbine is allowed to disconnect. DFIG wind power
    system has serious problems with the corresponding voltage
    sag as its partly power converter: depending on the depth and
    the conditions at the start of the sag, current, power and
    reactive power peaks may exceed rated values and may lead to
    a system shut down. The experiment system includes a DC
    motor, a DFIG, a 3-phase diode rectifier, a converter, a
    crowbar and a voltage sags generator. The DC motor simulates
    the behavior of wind turbine, the 3-phase diode rectifier and
    the converter controls the DFIG, the crowbar is connected to
    the rotor of DFIG and the converter. The voltage sags
    generator provides the voltage sags event for the experiment
    system. The controller of the converter and crowbar includes
    DSP and FPGA. It judges the moment of voltage sags and trigs
    the crowbar, so is the key part of the LVRT system.The
    simulation and experiment result shows that the dynamic
    response of inner current loop of rotor side converter is
    important for damping the transient current during voltage
    sags. The converter in the rotor side with crowbar using the dq
    transfer voltage measure method could reduce the transient
    current in rotor and stator. The DFIG system with crowbar
    could quickly recover from the voltage sags and provide
    reactive power to support the grid. So crowbar is important
    for improving LVRT capability of DFIG.The converter with
    crowbar in the rotor side implement the LVRT of DFIG, it
    could send reactive power during voltage sags.
    关键字:
    来源:
    - Q; P# ~/ U8 N- P  J- z9 I6 G( q& X1 K/ A
    [attach]38853 dfig lvrt.rar (260.94 KB, 下载次数: 8) 比较概括的写了双馈风机的抵押穿越仿真,控制方法
    发表于 2012-10-18 16:38:15 | 显示全部楼层
    下来看看吧
    GMT+8, 2026-10-30 14:32
