raw 文件 复制粘贴到raw文件就可以了,潮流结果还是很准的
2 X& G* k7 e0 H4 S, F0, 100.00, 32, 0, 1, 60.00 / PSS瓻-32.0 THU, MAR 03 2011 20:52' p. K5 W$ H+ T! G9 e3 X7 H
PSS(R)E PROGRAM APPLICATION GUIDE EXAMPLE' \& K. \, j+ q0 I
BASE CASE INCLUDING SEQUENCE DATA
$ O- T( K# U! w( \; Q# h 1,'G1 ', 20.0000,2, 1, 1, 11,1.03000, 27.0697% W h3 {* K8 Y! d& m6 _ L
2,'G2 ', 20.0000,2, 1, 2, 11,1.01000, 17.3055( S2 ?2 _: v- v' Z* ~* c
3,'G3 ', 20.0000,3, 2, 3, 2,1.03000, 0.0000( I& n% M5 g+ z4 Z( g* _) _0 Y
4,'G4 ', 20.0000,2, 2, 4, 2,1.01000, -10.19177 g8 M$ ^0 m$ M
5,'TOU ', 230.0000,1, 1, 5, 11,1.00646, 20.6079
4 z4 ]8 f7 Q' ?8 y3 O6 r Y$ b 6,'MID1 ', 230.0000,1, 1, 5, 1,0.97814, 10.5234! p$ G* W" ?4 j7 V; V! r8 {( I
7,'CON1 ', 230.0000,1, 1, 5, 5,0.96102, 2.1144( J& ~; l; R( k1 l" P' P
8,'CONMID ', 230.0000,1, 5, 5, 5,0.94862, -11.7550
8 M8 h9 k4 W: n+ L& L 9,'CON2 ', 230.0000,1, 2, 5, 5,0.97138, -25.35173 e+ ~& j# r3 r9 A2 }; c1 `
10,'MID2 ', 230.0000,1, 2, 5, 22,0.98347, -16.9368
4 ^6 X# s k- u! V: |' @5 c 11,'TOU ', 230.0000,1, 2, 5, 2,1.00826, -6.6269
: w+ R3 s! F7 s0 / END OF BUS DATA, BEGIN LOAD DATA- `/ s3 S7 Q/ g( A" z: \' ~
7,'1 ',1, 5, 5, 967.000, 100.000, 0.000, 0.000, 0.000, 0.000, 5,1
/ g* b+ E5 d* d( Y4 g 9,'1 ',1, 5, 5, 1767.000, 100.000, 0.000, 0.000, 0.000, 0.000, 5,1. ]" W+ W& n( n& V
0 / END OF LOAD DATA, BEGIN FIXED SHUNT DATA i4 Y; ~( V+ c/ j9 L0 `8 G
7,'1 ',1, 0.000, 200.000
& K( w% t- s+ A/ x7 Y I 9,'1 ',1, 0.000, 350.000
# O+ p& S/ J( m5 t3 V0 / END OF FIXED SHUNT DATA, BEGIN GENERATOR DATA/ Y i! p4 s$ u
1,'1 ', 700.000, 185.000, 9999.000, -9999.000,1.03000, 0, 900.000, 2.50000E-1, 2.50000E-1, 0.00000E+0, 0.00000E+0,1.00000,1, 100.0, 9999.000, -9999.000, 1,1.00001 ^# y; M6 q* v- s0 C) m! G
2,'1 ', 700.000, 234.575, 9999.000, -9999.000,1.01000, 0, 900.000, 2.50000E-1, 2.50000E-1, 0.00000E+0, 0.00000E+0,1.00000,1, 100.0, 9999.000, -9999.000, 1,1.0000
8 ~3 a: K& H+ K4 ]7 W! S 3,'1 ', 719.083, 175.991, 9999.000, -9999.000,1.03000, 0, 900.000, 2.50000E-1, 2.50000E-1, 0.00000E+0, 0.00000E+0,1.00000,1, 100.0, 9999.000, -9999.000, 1,1.0000
- S$ A9 ^- Q6 Y! l' d; ] 4,'2 ', 700.000, 202.036, 9999.000, -9999.000,1.01000, 0, 900.000, 2.50000E-1, 2.50000E-1, 0.00000E+0, 0.00000E+0,1.00000,1, 100.0, 9999.000, -9999.000, 1,1.00009 l" a- G* E- n
0 / END OF GENERATOR DATA, BEGIN BRANCH DATA c. u9 \: F. W( P
5, 6,'1 ', 2.50000E-3, 2.50000E-2, 0.04375, 100.00, 0.00, 0.00, 0.00000, 0.00000, 0.00000, 0.00000,1,1, 0.00, 11,1.00006 R% F2 |' B# A0 C
6, 7,'1 ', 1.00000E-3, 1.00000E-2, 0.01750, 100.00, 0.00, 0.00, 0.00000, 0.00000, 0.00000, 0.00000,1,1, 0.00, 1,1.0000& Y3 a% {; i1 _ f# ~
7, 8,'1 ', 1.10000E-2, 1.10000E-1, 0.19250, 100.00, 0.00, 0.00, 0.00000, 0.00000, 0.00000, 0.00000,1,1, 0.00, 5,1.0000- j# i; ]8 l: B9 g0 S6 `; a0 j
7, 8,'2 ', 1.10000E-2, 1.10000E-1, 0.19250, 100.00, 0.00, 0.00, 0.00000, 0.00000, 0.00000, 0.00000,1,1, 0.00, 5,1.0000% t& x+ R5 x! m. F. l
8, 9,'1 ', 1.10000E-2, 1.10000E-1, 0.19250, 100.00, 0.00, 0.00, 0.00000, 0.00000, 0.00000, 0.00000,1,1, 0.00, 5,1.0000, f$ \& L4 L u" p" `# R" }6 ]
8, 9,'2 ', 1.10000E-2, 1.10000E-1, 0.19250, 100.00, 0.00, 0.00, 0.00000, 0.00000, 0.00000, 0.00000,1,1, 0.00, 5,1.0000
4 L! k, i v; \) G! t 9, 10,'1 ', 1.00000E-3, 1.00000E-2, 0.01750, 100.00, 0.00, 0.00, 0.00000, 0.00000, 0.00000, 0.00000,1,1, 0.00, 1,1.00005 ?' f# M5 a# a6 N3 S& D
10, 11,'1 ', 2.50000E-3, 2.50000E-2, 0.04375, 100.00, 0.00, 0.00, 0.00000, 0.00000, 0.00000, 0.00000,1,1, 0.00, 11,1.0000- K' A2 R$ H9 f" N
0 / END OF BRANCH DATA, BEGIN TRANSFORMER DATA- C% g# J+ x( k+ Q* W
1, 5, 0,'T1',1,2,1, 0.00000E+0, 0.00000E+0,2,'T1G1 ',1, 11,1.00009 V) V0 N2 l3 x* {: C+ R; ]
0.00000E+0, 1.50000E-1, 900.00
; c4 x l& \% C+ A/ u! {1.00000, 20.000, 0.000, 900.00, 0.00, 0.00, 0, 0, 1.10000, 0.90000, 1.10000, 0.90000, 33, 0, 0.00000, 0.00000, 0.0004 `- e0 ]) h4 Z- t0 F/ \5 T/ j
1.00000, 230.000
! ]/ a. s) O' T. L+ [ 2, 6, 0,'T2',1,2,1, 0.00000E+0, 0.00000E+0,2,'T2G2 ',1, 11,1.0000- m5 k; U" j1 G. J
0.00000E+0, 1.50000E-1, 900.00* t5 y; |& E! y; R
6 C% p5 h8 L6 P# `5 m, z1.00000, 230.000
3 h2 J! g4 r5 B4 X1 |7 J 3, 11, 0,'T3',1,2,1, 0.00000E+0, 0.00000E+0,2,'T3G3 ',1, 11,1.0000
L( x. T' j; O7 \" \, m8 _ 0.00000E+0, 1.50000E-1, 900.005 v5 [2 m Y! E* k5 H
# q/ d% h' M0 u: R1.00000, 230.0001 y3 M" X2 s7 ?* q- K" b: W) W
4, 10, 0,'T4',1,2,1, 0.00000E+0, 0.00000E+0,2,'T4G4 ',1, 11,1.0000
' i3 P0 i1 I+ @6 k2 l1 w 0.00000E+0, 1.50000E-1, 900.00
% x } t9 T0 ]6 ~/ O3 r1.00000, 20.000, 0.000, 900.00, 0.00, 0.00, 0, 0, 1.10000, 0.90000, 1.10000, 0.90000, 33, 0, 0.00000, 0.00000, 0.000. c6 z: f3 Z; {3 }% r- e
1.00000, 230.000. u2 B1 {( R7 E; I; i* t
0 / END OF TRANSFORMER DATA, BEGIN AREA DATA
+ z: S% S: J3 r/ A, `: J# \ 1, 0, 400.000, 10.000,'AREA1 ': a3 Q- Z' H- R$ Y2 P& p$ Q
2, 3, -400.000, 10.000,'AREA2 '
$ q+ a0 E/ \# K+ ?! T 5, 0, 0.000, 10.000,'CONCT '$ H5 h- Y( p5 ~) z7 b, `/ ^3 b* M
0 / END OF AREA DATA, BEGIN TWO-TERMINAL DC DATA
& T$ C4 S+ L8 v5 ]0 / END OF TWO-TERMINAL DC DATA, BEGIN VSC DC LINE DATA* n% d/ P* R% P* H1 \
0 / END OF VSC DC LINE DATA, BEGIN IMPEDANCE CORRECTION DATA1 J) `, i6 C8 M/ v1 x6 X
0 / END OF IMPEDANCE CORRECTION DATA, BEGIN MULTI-TERMINAL DC DATA
4 B. E1 H2 ^8 h+ a& t3 C0 / END OF MULTI-TERMINAL DC DATA, BEGIN MULTI-SECTION LINE DATA
9 L: a P) W2 z. C# N0 / END OF MULTI-SECTION LINE DATA, BEGIN ZONE DATA
& w {! Y( ]; d 1,'PLANT1 '. Q, g7 P+ N; M: {: H- R$ D7 {
2,'PLANT2 '9 L1 Y9 j! _2 P
3,'PLANT3 '
# X' T$ V* ?% N5 b7 |) K 4,'PLANT4 '' ]7 x4 D" C0 c% ^
5,'THIRD '
3 [9 l. B* T1 h; J9 e0 / END OF ZONE DATA, BEGIN INTER-AREA TRANSFER DATA) F) V$ B3 G* t6 ?
1, 2,'A', 400.00+ L& u; F6 ~- I, x% P3 z
0 / END OF INTER-AREA TRANSFER DATA, BEGIN OWNER DATA3 d5 ^1 Y+ {) z; M: ]
1,'TRAN 1 '% d# u: @) o: {5 ]0 Q* ^3 V
2,'TRAN 2 '$ M4 Y6 Y, ^, z0 G
5,'TRAN 5 ', W6 M. y: x# \% a& C0 D3 i
11,'GEN 1 '
2 T0 h. \9 D8 O/ j) k 22,'GEN 2 '7 j8 c4 H% y, G- e2 k/ B; w
0 / END OF OWNER DATA, BEGIN FACTS DEVICE DATA
: W0 S4 O9 ]4 w1 S* h. P5 X0 / END OF FACTS DEVICE DATA, BEGIN SWITCHED SHUNT DATA
* ~+ c4 N4 M2 z" g1 |4 ^: Y0 / END OF SWITCHED SHUNT DATA, BEGIN GNE DATA
; x+ K0 Z$ T9 Z! [0 / END OF GNE DATA
6 n6 Q$ h7 X& z1 s1 x2 B% {Q |
