发表于 2009-9-1 01:36:42
10# 白夜风起
2 z1 r. ]4 s- S, N; i" S$ U* Q. n2 N6 f0 ^- e" |4 k% y4 z( P
I haven't used ATP for a long while so cannot give you any materialized advices. However, I would like to comments as following and wish it may help you a bit.
# \ v n$ R5 w! t. f7 O
+ S6 C) n9 J: z/ H; A9 {$ [As far as I can see, there are some possible which mixed up you case:0 [ @# x& a! C9 P5 W- N x. X
1) The 2 resisters are too big, which cause the voltage at the nonlinear reactor to be too small to reach the knee point of the BH curve;
* r" w7 F- P& T2 l2) You may vary the angle of the source and see what happens;: D9 w+ [, _! j" b1 Y+ j
3) Change the nonlinear reactor to a similar size linear reactor, then you should see the transient current and decay;
: h+ u9 g/ p- O! X2 n* v4 L4)If the above all cannot work, the your input data must be wrong.
2 T" D: j8 a# n, @( B) V5) Please understand the saturation curve data, and compare to the soruce voltage also see whether the voltage is too low. |
