发表于 2009-6-29 09:31:16
I would like to comment on your discussion on https://tech.cepsc.com/thread-38403-1-2.html, which is attached below.
- X- |8 N4 } W) K' E# |* |8 _5 }; m+ f" e, X: M$ E
Luiz Marti is younger brother of Jose Marti, they are both students of Prof. Dommel in UBC. ATP has a problem that is all the development is volunteer based. There is no sufficient fund to support the work of ATP. The work of ATP was support by the US government, that is tax payer of US, so it is free to everyone. DCG is a supported by EPRI so it still goes forward. DCG was lead by Ontario Hydro, where L Marti is a leading engineer in the EMTP group. In fact there is another EMTP version called UBC version which is lead by J Marti.
7 I6 a; a$ G: b8 l0 a2 E( S/ P" |7 ^9 e: h$ f# Q
I did not read the paper of Noda, since I did not used ATP for a long while. I think Noda's method must be a type of phase domain model which avoid the frequency dependent transformation matrix. Gustavson's work is more popular in this area. In fact he is still work on this thing now. There is two difficulties now on the phase domain model, one is the accurate representation of DC resistor, the other is the non passivity of the fitting. I met Gastvson earlier this year and had a short discussion on this issue. He himself is trying to develop better fitting algorithms, which naturally can reduce the probability of non passivity. Current passivity enforcement is used once the problem appears, however, it bring tolerance. Chance is there in future a good fitting approach will be found and it reduce the chance of non passivity to a very low.! [/ s$ {% `$ t- q: a( I5 r! |) k
5 U7 r0 t" H5 M- M2 |3 ]& E2 eThere are some tip to use the fitting, such as you can vary the weighting factor on the frequency. For DC, it is good to set the working frequency to 0.5. Don't use 0, it will bring numerical problems. I expect those phase domain line model will give use the option to choose the weight factor on the fitting. You may play several time and get a good number.( ^* J* N8 V7 I- {+ r7 K
0 `4 z' S* w+ f# H
# [% H4 M* z7 `8 F V2 [. y' G$ \. c/ I
其实,我感觉ATP在发展电缆模型上有所失策。L.Marti(不知道和JMarti是什么关系)在88年的时候其实已经提出了适合电缆模拟的模型,不过这个模型被EMTP的另一个版本DCG/EPRI所采用,ATP里并没有采用,一直到了96年,Noda (Ametani的学生,Ametani是cable constants/parameter 的作者,EMTP的牛人之一)提出了直接在时域计算的Noda模型,不知道究竟是因为这个模型很先进,还是因为Ametani教授的权威地位,反正ATP 决定引进这个模型了,没过3年,Gustava又提出了计算更稳定的模型,这个模型马上就被pscad所引入。ATP却一直就只保留着Noda模型了,操作比较复杂,据说计算有时也不稳定,没用过,但是感觉影响力不如那两种模型 |
