escriptive interpretation of input data cards. | Input data card images are shown below, all 80 columns, character by character 0 1 2 3 4 5 6 7 8 2 x5 U" H: x" O, w7 ` 012345678901234567890123456789012345678901234567890123456789012345678901234567890 & E# [* J, ^' J4 h2 W2 |2 V$ |& U--------------------------------------------------+--------------------------------------------------------------------------------6 r4 W) V5 g( g2 \, e
Comment card. NUMDCD = 1. |C data:C:\EEUG05\ATPDRAW\ATP\ARC2.ATP , ~" x1 ]5 x' \. ~Marker card preceding new EMTP data case. |BEGIN NEW DATA CASE/ w8 |) `8 n! @2 ^
Comment card. NUMDCD = 3. |C --------------------------------------------------------# j# K; }3 J9 @6 R# S( I
Comment card. NUMDCD = 4. |C Generated by ATPDRAW 三月, 星期四 30, 2017 2 y- l, n. X/ h5 L6 [+ r+ T7 FComment card. NUMDCD = 5. |C A Bonneville Power Administration program2 I; h0 U9 ^% c- D5 e0 G7 @
Comment card. NUMDCD = 6. |C Programmed by H. K. H鴌dalen at SEfAS - NORWAY 1994-2005 * B. ~1 i' g6 E$ |) tComment card. NUMDCD = 7. |C -------------------------------------------------------- 0 d" A) I4 N- Z8 p/ y" yComment card. NUMDCD = 8. |C dT >< Tmax >< Xopt >< Copt >8 ^! f* G! o% S3 \# I* D- ^) R
Misc. data. 1.000E-07 1.000E-01 0.000E+00 | 1.E-7 .17 Q5 j7 ?8 d0 t1 X6 E' J8 u: K/ V
Misc. data. 500 1 1 1 1 0 0 1 0 0 | 500 1 1 1 1 0 0 1 0$ V" {6 q' m& E! _0 J4 w0 O( [) [
Electric network, too. But TACS data first ... |TACS HYBRID 7 T: J% f+ ~. Y$ a, m. F" S7 ITACS source. 0.000E+00 0.000E+00 0.000E+00 |91XX0003 1.E3 4 s( o+ Q& f( f4 G( vFree-format TACS supplemental variable defined. |98XX0005 = ABS( XX0003 )7 _! d A: f X' y0 f+ E
Free-format TACS supplemental variable defined. |98XX0007 = XX0005 / XX0006" {2 y3 q# P3 z \5 u. y
Free-format TACS supplemental variable defined. |98XX0006 =2100.- z% `* [1 T8 o
Free-format TACS supplemental variable defined. |98XX0008 = XX0007 - XX0025. Q8 `- X) C2 x8 d. L
Free-format TACS supplemental variable defined. |98XX0010 = XX0008 / XX0009 , }3 _! }/ z9 MFree-format TACS supplemental variable defined. |98XX0009 =3.79E-4! o$ m" k6 n1 ^1 e
TACS device type 58: Controlled integrator. |98XX002458 +XX0010 1. 1.XX0005XX0015 7 M% Q/ i3 g' N$ v/ bFree-format TACS supplemental variable defined. |98XX0023 = XX0016 / XX0024 1 k( V9 \, n3 g x, _: _3 K6 f v; vFree-format TACS supplemental variable defined. |98XX0016 =1. C o( q0 x) v# ^
TACS device type 58: Controlled integrator. |98XX002558 +XX0024 1. 1.+ l% Q _5 L5 N0 z/ @, p$ ]2 k0 } V" t
Free-format TACS supplemental variable defined. |98XX0015 =0 2 Y) ~8 ~$ t. k2 CNames of TACS variables for output vector. |33XX0023* b9 j! o8 ]: G' E: M$ @! K
Comment card. NUMDCD = 25. |C 1 2 3 4 5 6 7 8, q0 q6 e6 x: f& j5 @
Comment card. NUMDCD = 26. |C 345678901234567890123456789012345678901234567890123456789012345678901234567890 + f3 A2 R: f, J8 g9 uBlank card terminating all TACS data cards. |BLANK TACS1 R- d* N+ v% d: F: k7 R5 A
$ q7 `9 K2 u# G8 X+ ~------------------------------------------------------------------------------------------------------------------------------------ 4 Q% k6 f6 o j$ O9 ?ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/) r, f' O9 f$ N9 H) i3 O& p. t
ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/$ ?' Z! H8 |9 `4 Q1 j) K2 W1 D
------------------------------------------------------------------------------------------------------------------------------------ ' ]+ I- {: J4 d! Q5 rYou lose, fella. The EMTP logic has detected an error condition, and is now going to terminate program execution. The following _) k$ ~. O' n; s! R7 Q+ r
message summarizes the circumstances leading to this situation. Where an otherwise-unidentified data card is referred to, or where" [1 b" Y4 \4 A+ K
the "last" card is mentioned, it is the most recently read card of the input data that is meant. The 80-column image of this card4 e/ C5 f8 u# F
is generally the last one printed out prior to this termination message. But possibly this last-read card has not yet been* v* P D5 |, {4 v7 v( u9 ~
displayed, so a copy follows:3 t/ b2 T; o- y' _/ g
" " ! v4 I. t+ J, ~! a9 S" \1 u KILL code number Overlay number Nearby statement number ) W" L0 M- B. \0 w9 D" B5 A0 s! L- U 36 2 22546 E) u3 k) v- T( L5 _
KILL = 36. Loops in TACS supplemental variables or devices have been observed for this data case, and they are illegal. A. h6 Z( U" D6 d
tabulation of such looped blocks will be found immediately preceding the "/ERROR/ERROR/...." line that presaged the present error# N3 I! Q( M3 E3 Q. [& v4 K
text. The common remedy is to add one zero-th order s-block to break each such loop, thereby decoupling the nonlinearities. An+ G$ M3 i# H8 ~0 y4 c$ F: B
analogy can be made to the addition of distributed lines to decouple nonlinear elements.) I4 p4 G8 S8 r5 v! Z2 A% k
------------------------------------------------------------------------------------------------------------------------------------3 H% t/ I k4 E; R1 F; L) A4 B* c4 ]
ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ ( |- p0 q) O" a: O! b! {ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ L6 _" F* j, d0 q) X3 O5 o I------------------------------------------------------------------------------------------------------------------------------------ - O I0 q4 o) I$ c4 V/ R) m% k0 o" L6 t6 Y, G
- _( b6 q* @' g" g0 MMemory storage figures for the preceding, now-completed data case. ------------------------------- Present Program5 j& L6 t8 G7 R+ ~8 `2 W6 Z" D
A value of "-9999" indicates that no figure is available. 30-Mar-17 22:15:45 figure limit (name)$ A/ _" C; W$ L5 m9 \+ d
Size List 1. Number of electric network nodes. -9999 6000 (LBUS), x' G1 S9 n0 B. @6 J
Size List 2. Number of electric network branches. -9999 10000 (LBRNCH) U2 J# J# D* x" G' @
Size List 3. Number of data values in R, L, C tables. -9999 192000 (LDATA)! @+ v% t% V8 ~) B( N- D
Size List 4. Number of electric network sources. -9999 900 (LEXCT) ' j% X0 Y7 L3 y7 ^, M# k& w Size List 5. Storage for [Y] and triangularized [Y]. No. times = 0 Factors = 0 -9999 420000 (LYMAT). }1 D% [4 ?, X$ Z& B
Size List 6. Number of entries in switch table. No. flops = 0 -9999 1200 (LSWTCH)+ q. V. v9 L! H; l7 D* Z4 n
Size List 7. Number of distinct ALPHANUMERIC data names plus program SPY variables. -9999 15000 (LSIZE7) 1 e" U+ I% N6 Q$ E+ M0 w Size List 8. History points of distributed lines. -9999 120000 (LPAST)! i3 ]+ T* _* D$ \4 t9 w/ l: L' ~
Size List 9. Number of nonlinear elements. -9999 10000 (LNONL)! T4 a) ~3 c7 H
Size List 10. Points of nonlinear characteristics. -9999 20000 (LCHAR)3 M, k* T$ x& B* D. X. U
% G/ f0 B. e# T2 _
7 _) W$ a( P' x/ t- ~& P; Z
# Q1 T" E4 M A) c8 o+ b这是什么错误啊?完全看不懂,我已经加了一个零阶方块连接了啊,还要怎么改 * q1 F5 Z0 [$ u) d! o% O + I# A& B/ Z% o2 ]
