查看: 2314|回复: 2
两个MOV避雷器并联会提示错误
    2016-4-26 21:17
  • 签到天数: 11 天
    累计签到:11 天
    发表于 2016-4-26 21:21:53 | 显示全部楼层 |阅读模式
    工程上不是可以将避雷器并联降低电流。' h1 }7 A1 A6 X
    但是仿真两个MOV避雷器会提示错误7 g  C3 d( C5 t5 u+ L
    怎么处理?
    3 w: D: c% h8 S  C- u) W2 XYou lose, fella.   The EMTP logic has detected an error condition, and is now going to terminate program execution.  The following3 ^0 a  n0 t8 ]$ t3 E% g8 J
    message summarizes the circumstances leading to this situation.  Where an otherwise-unidentified data card is referred to, or where+ M& o2 R1 B3 {9 g; E. K" a" ~) Y
    the "last" card is mentioned, it is the most recently read card of the input data that is meant.  The 80-column image of this card) b; C: d$ j- p
    is generally the last one printed out prior to this termination message.  But possibly this last-read card has not yet been3 @; I4 C; h" p2 i
    displayed, so a copy follows:
    ) S8 c- J2 c: G. [, f% M) J "        "
    1 v6 H' p9 l3 H; U: e* A              KILL code number                Overlay number               Nearby statement number
    ! ~' d4 o: |7 C; J* C                        209                         18                               3501
    6 v% b4 {/ t! Z& |- E% c  }KILL = 209.   ZnO solution by Newton`s method of  6   coupled arresters has failed due to singularity of the Jacobian matrix.  This
    . A" B9 ]! q# i' r( @- dis measured by tolerance EPSILN,  which is defined by the floating-point miscellaneous data card.   The iteration count is  3,   and/ {2 ?4 l& G) i, E5 {" T4 j
    the coupled group of arresters can be identified from the knowledge that the first (in order of input) connects bus  "S1A   "  with
    2 |/ y5 T* }. Dbus  "      ".   The simulation time is  T = 1.00000000E-06.$ ]/ j8 S2 j0 n: A, d  R
    - A* Q" n- q+ l
    [发帖际遇]: Cocktail2011打雪仗,雪地里捡了 学分1 点,赚了. 幸运榜 / 衰神榜
    2020-5-19 19:34
  • 签到天数: 235 天
    [LV.7]常住居民III
    累计签到:237 天
    发表于 2016-4-27 12:29:01 | 显示全部楼层
    仿真不收敛了,把避雷器里面的误差参数改大一下试一下
    [发帖际遇]: wangdc 发帖时在路边捡到威望1 点,偷偷放进了口袋. 幸运榜 / 衰神榜
    2021-3-30 19:49
  • 签到天数: 153 天
    [LV.7]常住居民III
    累计签到:153 天
    发表于 2019-12-31 09:59:10 | 显示全部楼层
    wangdc 发表于 2016-4-27 12:292 e1 O/ `. |! ~* T6 h2 X: I; j
    " X% W: }" r) ^, o, @这样会不会导致结果失真啊
    8 D) Y7 R: \- U; h" `
    # [7 A7 A- W6 N! k6 q3 |
    回复 推荐 踩下
    使用道具 举报
    GMT+8, 2026-11-21 13:08
