查看: 4475|回复: 0
IEC standards (International Electrotechnical Commission)
发表于 2008-8-7 15:16:46 | 显示全部楼层 |阅读模式
标准规范
标准规范名称: IEC standards (International Electrotechnical Commission)
标准编号: IEC standards (International Electrotechnical Commission)
发布单位:
内容简介: 60364-3 Electrical Installations of Buildings.pdf
IEC 60044-1 Instrument Transformers Part-1 Current Transformers.pdf
IEC 60071-1 Insulation Co-Ordination - Definitions, principles and rules.pdf
IEC 60071-2 Insulation Co-Ordination - Application guide.pdf
IEC 60071-4 Insulation Co-Ordination - Computational guide to insulation co-ordination and modell.pdf
IEC 60076-1 Power transformers - General.pdf
IEC 60076-10 Power transformers - Determination of sound levels.pdf
IEC 60076-2 Power transformers - Temperature rise.pdf
IEC 60076-3 Power transformers - Insulation levels, dielectric tests and external clearances in a.pdf
IEC 60076-4 Power transformers - Guide to the lightning impulse and switching impulse testing.pdf
IEC 60076-5 Power transformers - Ability to withstand short circuit.pdf
IEC 60076-8 Power transformers - Application guide.pdf
IEC 60079-1 Electrical apparatus for explosive gas atmospheres - Flameproof enclosures 'd'.pdf
IEC 60079-10 Electrical apparatus for explosive gas atmospheres - Classification of hazardous areas.pdf
IEC 60079-11 Electrical apparatus for explosive gas atmospheres - Intrinsic safety 'i'.pdf
IEC 60079-14 Electrical apparatus for explosive gas atmospheres - Electrical installations in hazardous areas.pdf
IEC 60079-15 Electrical apparatus for explosive gas atmospheres - Construction, test and marking of type of protection n electrical apparatus.pdf
IEC 60079-2 Electrical apparatus for explosive gas atmospheres - Pressurized enclosures 'p'P.pdf
IEC 60079-27 Fieldbus intrinsically safe concept (FISCO) and Fieldbus non-incendive concept (FNICO).pdf
IEC 60079-4 Method of test for ignition temperature.pdf
IEC 60079-5 Electrical apparatus for explosive gas atmospheres - Powder Filling 'q'.pdf
IEC 60079-6 Electrical apparatus for explosive gas atmospheres - Oil-immersion 'o'.pdf
IEC 60079-7 Electrical apparatus for explosive gas atmospheres - Increased safety 'e'.pdf
IEC 60092-350 Elecetrical Installations in Ship.pdf
IEC 60092-352 Choice & Installation of Cables for Low Voltage Power Systems.pdf
IEC 60092-375 Ship board telecommunication cables and radio-frequency cables - General instrumentation, control and communication cables.pdf
IEC 60092_375 General Instrumentation, Control & Communication Cables.pdf
IEC 60092_376 Cable for Control & Instrumentation Circuits.pdf
IEC 60228 Conductors of Insluated Cables.PDF
IEC 60245-3 Rubber Insulated Cables.pdf
IEC 60255-13 Electrical relays - Biased (percentage) differential relays.pdf
IEC 60255-22-5 Electrical relays - Electrical disturbance tests for measuring relays and protecti.pdf
IEC 60255-23 Electrical Relays - Contact Performance.pdf
IEC 60255-24 Electrical relays - Common format for transient data exchange (COMTRADE) for power s.pdf
IEC 60255-3 Electrical relays - Single input energizing quantity measuring relays with dependent .pdf
IEC 60255-5 Electrical relays - Insulation coordination for measuring relays and protection equip.pdf
IEC 60255-6 Electrical relays - Measuring relays and protection equipment.pdf
IEC 60255-8 Electrical relays - Thermal electrical relays.pdf
IEC 60269-1 Low-voltage fuses - General requirements.pdf
IEC 60269-2 Low-voltage fuses - Supplementary requirements for fuses for use by authorized person.pdf
IEC 60269-2-1 Low-voltage fuses - Supplemetary Requirements for Fuses for use by authorized perso.pdf
IEC 60269-4 Low-voltage fuses - Supplementary requirements for fuse-links for the protection of s.pdf
IEC 60269-4-1 Low-voltage fuses - Supplementary requirements for fuse-links for the protection of.pdf
IEC 60298 A.C. metal-enclosed switchgear and controlgear for rated voltages above 1 kV and up to .pdf
IEC 60331 Fire Resisting Charecteristics of Electric Cables.PDF
IEC 60331-11 Test on Electrical Cables Under Fire Condition.pdf
IEC 60331-12 Test on Electrical Cables Under Fire Condition.pdf
IEC 60331-31 Test on Electrical Cables Under Fire Condition.pdf
IEC 60332-1 Tests on electric cables under fire conditions - Test on a single vertical insulated .pdf
IEC 60332-1_1 Tests on electric and optical fibre cables Under Fire Condition.pdf
IEC 60332-1_2 Tests on electric and optical fibre cables Under Fire Condition.pdf
IEC 60332-1_3 Tests on electric and optical fibre cables Under Fire Condition.pdf
IEC 60332-2 Tests on electric cables under fire conditions - Test on a single small vertical insu.pdf
IEC 60332-2_1 Tests on electric and optical fibre cables Under Fire Condition.pdf
IEC 60332-2_2 Tests on electric and optical fibre cables Under Fire Condition.pdf
IEC 60332-3-10 Tests on electric cables under fire conditions - Test for vertical flame spread of.pdf
IEC 60332-3-21 Tests on electric cables under fire conditions - Test for vertical flame spread of.pdf
IEC 60332-3-22 Test on Electrical Cables Under Fire Condition.pdf
IEC 60332-3-22 Tests on electric cables under fire conditions - Test for vertical flame spread of.pdf
IEC 60332-3-23 Tests on electric cables under fire conditions - Test for vertical flame spread of.pdf
IEC 60332-3-24 Tests on electric cables under fire conditions - Test for vertical flame spread of.pdf
IEC 60332-3-25 Tests on electric cables under fire conditions - Test for vertical flame spread of.pdf
IEC 60364-1 Electrical installations of buildings - Fundamental principles, assessment of general.pdf
IEC 60364-5-52 Electrical installations of buildings - Selection and erection of electrical equip.pdf
IEC 60364-5-54 Electrical installations of buildings - Selection and erection of electrical equip.pdf
IEC 60364-5-548 Electrical installations of buildings - Selection and erection of electrical equi.pdf
IEC 60364-5-55 Electrical installations of buildings - Selection and erection of electrical equip.pdf
IEC 60364-5-56 Electrical installations of buildings - Selection and erection of electrical equip.pdf
IEC 60364-7-707 Electrical installations of buildings - Requirements for special installations or.pdf
IEC 60439-1 Low-voltage switchgear and controlgear assemblies - Type-tested and partially ty.pdf
IEC 60439-2 Low-voltage switchgear and controlgear assemblies - Particular requirements for busba.pdf
IEC 60439-3 Low-voltage switchgear and controlgear assemblies - Particular requirements for Iow-v.pdf
IEC 60439-4 Low-voltage switchgear and controlgear assemblies - Particular requirements for assem.pdf
IEC 60439-5 Low-voltage switchgear and controlgear assemblies - Particular requirements for assem.pdf
IEC 60502-1 Power cables with extruded insulation and their accessories for rated voltages.pdf
IEC 60502-2 Power cables with extruded insulation and their accessories for rated voltages.pdf
IEC 60502-4 Power cables with extruded insulation and their accessories for rated voltages.pdf
IEC 60529 Degrees of protection provided by enclosures (IP Code).pdf
IEC 60534-1 Industrial Process Control Valves - Terminology & General Considerations.pdf
IEC 60534-2_1 Industrial Process Control Valves - Flow capacity Equations.pdf
IEC 60534-2_3 Industrial Process Control Valves - Flow capacity Equations.pdf
IEC 60534-2_4 Industrial Process Control Valves - Flow capacity Equations.pdf
IEC 60534-2_5 Industrial Process Control Valves - Flow capacity Equations.pdf
IEC 60534-3 Industrial Process Control Valves - Dimensions.pdf
IEC 60534-3_1 Industrial Process Control Valves - Dimensions.pdf
IEC 60534-3_2 Industrial Process Control Valves - Dimensions.pdf
IEC 60534-3_3 Industrial Process Control Valves - Dimensions.pdf
IEC 60534-4 Industrial Process Control Valves - Inspection & Routine Testing.pdf
IEC 60534-5 Industrial Process Control Valves - Marking.pdf
IEC 60534-6 Industrial Process Control Valves - Mounting details for attachment of positioners.pdf
IEC 60534-6_1 Industrial Process Control Valves - Mounting details for attachment of positioners.pdf
IEC 60534-6_2 Industrial Process Control Valves - Mounting details for attachment of positioners.pdf
IEC 60534-7 Industrial Process Control Valves - Data Sheet.pdf
IEC 60534-8_1 Industrial Process Control Valves - Noise Considerations.pdf
IEC 60534-8_2 Industrial Process Control Valves - Noise Considerations.pdf
IEC 60534-8_3 Control valve aerodynamic noise prediction method.pdf
IEC 60534-8_4 Industrial Process Control Valves - Noise Considerations.pdf
IEC 60584-1 Thermocouples - Reference tables.pdf
IEC 60584-2 Thermocouples - Tolerances.pdf
IEC 60584-3 Thermocouples - Extension and compensating cables.pdf
IEC 60694 Common specifications for high -voltage switchgear and controlgear standards.pdf
IEC 60726 Dry Type Power Transmformers.PDF
IEC 60751 Industrial platinum resistance thermometer Sensors.pdf
IEC 60793-1-44 Optical fibres - Measurement methods and test procedures - Cut-off wavelength.pdf
IEC 60874-14-4 Connectors for optical fibres and cables - Detail specification for fibre optic adaptor (simplex) type SC for multimode fibre.pdf
IEC 60909-0 Short-circuit currents in three-phase a.c. systems - Calculation of currents.pdf
IEC 60909-1 Short-circuit currents in three-phase a.c. systems - Factors for the calculation of s.pdf
IEC 60909-2 Electrical equipment - Data for short-circuit current calculations.pdf
IEC 60909-3 Short-circuit currents in three-phase a.c. systems - Currents during two separate sim.pdf
IEC 60909-4 Short-circuit currents in three-phase a.c. systems - Examples for the calculation of .pdf
IEC 60947-1 Low-voltage switchgear and controlgear - General rules.pdf
IEC 60947-1-2004 Low-voltage switchgear and controlgear - General rules.pdf
IEC 60947-2 Low-voltage switchgear and controlgear - Circuit Breakers.pdf
IEC 60947-3 Low-voltage switchgear and controlgear - Switches, disconnectors, switch-disconnector.pdf
IEC 60947-4-1 Low-voltage switchgear and controlgear - Contactors and Motor Starters - Electromec.pdf
IEC 60947-4-2 Low-voltage switchgear and controlgear - Contactors and Motor Starters - AC Semicon.pdf
IEC 60947-4-3 Low-voltage switchgear and controlgear - Contactors and motor-starters - AC semicon.pdf
IEC 60947-6-1 Low-voltage switchgear and controlgear - Multiple function equipment - Automatic tr.pdf
IEC 60947-6-2 Low-voltage switchgear and controlgear - Multiple function equipment - Control and .pdf
IEC 60947-7-1 Low-voltage switchgear and controlgear - Ancillary equipment - Terminal blocks for .pdf
IEC 61131-1 Programmable controllers - General information.pdf
IEC 61131-2 Programmable controllers - Equipment Requirements and Tests.pdf
IEC 61131-3 Programmable controllers - Programming languages.pdf
IEC 61131-4 Programmable controllers - User guidelines.pdf
IEC 61131-5 Programmable controllers - Communications.pdf
IEC 61131-7 Programmable controllers - Fuzzy control programming.pdf
IEC 61131-8 Programmable controllers - Guidelines for the application and implementation of programming languages.pdf
IEC 61158-1 Overview and guidance for the IEC 61158 series.pdf
IEC 61158-2 Physical layer specification and service definition.pdf
IEC 61158-3 Data link service definition.pdf
IEC 61508 Part 1 - General Requirements.pdf
IEC 61508 Part 1 Addenda.pdf
IEC 61508 Part 2 - Requirements for Electrical - Electronic programmable electronic safety-related systems.pdf
IEC 61508 Part 3 - Software Requirements.pdf
IEC 61508 Part 3 Addenda.pdf
IEC 61508 Part 4 - Definitions and Abbreviations.pdf
IEC 61508 Part 4 Addenda.pdf
IEC 61508 Part 5 - Examples of Methods for the determination of safety integrity levels.pdf
IEC 61508 Part 5 Addenda.pdf
IEC 61508 Part 6 - Guidelines on the application of parts 2 and 3.pdf
IEC 61508 Part 7 Overview of Techniques & Measures.pdf
IEC 61511 Part-1 Framework, definitions, system, hardware and software requirements.pdf
IEC 61511 Part-2 Guidelines in the application of IEC 61511-1 - Informative.pdf
IEC 61511 Part-3 Guidance for the determination of safety integrity levels - informative.pdf
IEC 61537 Cable tray systems and cable ladder systems.pdf 73d4eed8
IEC 61831 On-line analyser systems - Guide to design and installation.pdf
IEC 61832 Analyser systems - Guide to technical enquiry & Bid Evaluation.pdf
IEC 61892-6 Mobile and fixed offshore units - Electrical installations.pdf
IEC 62086-1 Electrical apparatus for explosive gas atmospheres - Electrical resistance trace he.pdf
IEC 62271-100 High-voltage switchgear and controlgear - High-voltage alternating-current circuit-.pdf
IEC 62271-102 High-voltage switchgear and controlgear - High-voltage alternating-current Disconne.pdf
IEC 62271-105 High-voltage switchgear and controlgear - Alternating-current Switch Fuse Combinati.pdf
IEC 62271-200 High-voltage switchgear and controlgear - AC metal-enclosed switchgear and controlg.pdf
IEC 62271-203 High-voltage switchgear and controlgear - Gas-insulated metal-enclosed swithgear.pdf
IEC 62271-308 High-voltage switchgear and controlgear - Guide to Asymetrical shoet circuit breaki.pdf
IEC PAS 62030 Real-Time Publish-Subscribe (RTPS) Wire Protocol Specification Version 1.0.pdf
IEC TR 62095 Electric cables - Calculations for current ratings - Finite element method.pdf
IEC TR 62271-310 High-voltage switchgear and controlgear - Electrical endurance testing for circu.pdf
所属专业方向: electrotechnology
发布日期:
实施日期:
来源:
采用或替代关系:
标准状态:
The IEC is the world's leading organization that prepares and publishes International Standards for all electrical, electronic and related technologies — collectively known as
1 Q1 m" \1 i  t6 X) }! j"electrotechnology". The World of the IEC  ?# E% }4 i3 R% ~. s$ \/ |+ @, F
+ ~  p$ }0 ]0 g; qSpend a few minutes to see IEC Standards and
  I' d: T0 F3 X, rConformity Assessment in the world around you.
' d8 V- o3 q1 V
0 }5 R9 B, K8 [8 uWherever you find electricity and electronics, you find the IEC supporting safety and performance, the environment, electrical energy efficiency and renewable energies.
3 @7 V% N* y3 Q, C- b2 O( r4 n3 E) {* Y  G3 G
The IEC also manages conformity assessment schemes that certify that equipment, systems or components conform to its International Standards.$ W  K- A8 i: p5 M) A
0 ^5 l' m/ P- B7 B3 K9 X1 p
http://rapidshare.com/files/109007501/IECstandards.part1.rar
% Y8 U, g" ~  C4 e9 V9 m8 mhttp://rapidshare.com/files/109015565/IECstandards.part2.rar
" u8 q# H* F/ ^, D7 Khttp://rapidshare.com/files/109022214/IECstandards.part3.rar
9 u, a" x+ V* Q, F. u# Jhttp://rapidshare.com/files/108998436/IECstandards.part4.rar/ ^& j8 q4 o+ s9 y! k6 ?" C' P
2 T- l2 d1 d8 w( b9 r[ 本帖最后由 zhangwh 于 2008-8-7 15:18 编辑 ]
GMT+8, 2026-10-29 23:16
