查看: 106468|回复: 10
常用电力专业英语
发表于 2007-3-25 20:49:46 | 显示全部楼层 |阅读模式
(1)        元件设备
# e* J+ `8 w6 [5 `4 a2 J9 \三绕组变压器:three-column transformer ThrClnTrans ! t+ _/ |# K; u4 A) Z
双绕组变压器:double-column transformer DblClmnTrans5 r* U& `1 }# i
电容器:Capacitor
/ v0 t) W- N7 b% [9 g并联电容器:shunt capacitor! j# K- @5 S7 \" Q" S& Q# \9 K
电抗器:Reactor% g' ^3 M" L9 H* ~) W
母线:Busbar
% x7 S( Q( ^; p8 h输电线:TransmissionLine
& k6 G0 L' {) x4 g5 @发电厂:power plant
5 X6 |/ y3 [0 a! Q1 Z断路器:Breaker. v) x+ G, Y6 [& H/ C
刀闸(隔离开关):Isolator6 i3 h! B3 ?: S  y3 r; R- s  Q( c$ Q
分接头:tap
, [- [: a5 X; o# J" D) k电动机:motor
* ^% ~7 _' O* p+ X+ U(2) 状态参数& X4 o  N8 y( {5 |' w! z( }
有功:active power% H/ c$ D" `9 y4 y3 Z7 }. ]
无功:reactive power% T7 O6 }8 \/ b; t0 K- [: ^; Z
电流:current
9 M. O5 S# H* I6 Q6 O! O. t容量:capacity
. T1 v. m$ c* g2 }3 t电压:voltage
8 O1 M: F, _1 v( x9 n& E* G档位:tap position
$ P$ c2 T. x. W; F$ B有功损耗:reactive loss
; ?& z5 [4 O8 Y4 T* o0 i无功损耗:active loss$ p4 K6 G' p, r% h8 T9 E
功率因数:power-factor7 X# }( N. |" ~' K
功率:power
1 }% b, J7 D8 q8 u: c1 t" {功角:power-angle
6 m& Q4 {7 j1 ?& k" D9 U电压等级:voltage grade1 ?9 U: d2 B% o  L& z
空载损耗:no-load loss
: d: F+ b4 v, f+ g- n3 f- m( v; H铁损:iron loss
0 S- o* O1 U* P$ B铜损:copper loss
9 s1 L" N  v( c9 h2 _空载电流:no-load current
0 a. q6 |+ H: G* m9 [阻抗:impedance
+ a* f0 ]# @2 i' e# H$ T正序阻抗:positive sequence impedance
1 N9 U2 k) K4 [! P; G负序阻抗:negative sequence impedance
! L8 Q5 K/ V! Y* u) @8 V零序阻抗:zero sequence impedance
# B. X5 o% K! A& m0 g7 V3 C电阻:resistor
* k% G6 s: u7 U3 _3 q3 {2 S: c电抗:reactance
2 q' V/ ^6 n3 v6 a+ B. n; P7 F: w电导:conductance# [9 f4 [! E/ I6 D, j+ b( d
电纳:susceptance5 q' ?6 j) i& ~5 M4 Z( e0 g3 J- G
无功负载:reactive load 或者QLoad& ?! l6 j4 D) n* m  J2 _; ~# [) g7 B
有功负载: active load PLoad# E# O) R+ n* B) q" u3 o/ r) T
遥测:YC(telemetering)
/ g# K8 V+ s& B  T( {4 N遥信:YX (1) 元件设备
- w8 i: _" i8 R  ~  G* @三绕组变压器:three-column transformer ThrClnTrans
! P6 ?; H! t, [双绕组变压器:double-column transformer DblClmnTrans$ Q% r# K: P  }" _
电容器:Capacitor/ |' E* ^, t; c( v
' R  V- w2 g- C: \2 t电抗器:Reactor
2 U, b4 m  P$ ~$ c母线:Busbar
; R1 m. B4 [! g8 y6 f& F) n% b输电线:TransmissionLine
) ~5 {! }" }% q# o! v# h# O, {发电厂:power plant9 O4 ?' @# ]  ~* t7 d( q7 a
断路器:Breaker$ a$ D. j, }1 O
刀闸(隔离开关):Isolator& w: Q" s1 e1 i4 {0 D5 b9 ?
分接头:tap; \7 Y; y+ v& I6 C: m! N1 G# {
电动机:motor
6 ?6 c3 N# v! c' v+ P  U(2) 状态参数
2 D& |, C1 b# r4 L1 h有功:active power1 r3 _! Y) v7 a0 _* V
无功:reactive power( y2 U: I2 E+ i+ T
电流:current
) s2 S1 \/ Y5 F8 s' {! {! ?容量:capacity* l( J2 y* m+ T+ p$ D; O
电压:voltage: p5 U3 M: z) @( ?5 a! ^
档位:tap position
7 ]  p& M4 o3 m" X3 j5 \' `2 e有功损耗:reactive loss2 R/ z& M) J% P9 p0 [
无功损耗:active loss
: H3 A3 L$ I- S6 O$ A! \- e, \功率因数:power-factor
% m1 H; a- M1 Y- k4 z1 \+ P$ W! V% B5 E4 S功率:power
$ _5 \- h! b; m& w, i, s4 Y功角:power-angle- R0 u6 R# \; X
电压等级:voltage grade
# D0 D* X- y/ Z1 o空载损耗:no-load loss
$ k, T& Z, E8 {8 s0 S铁损:iron loss* _! P% l/ f+ Z8 s# C9 D
铜损:copper loss2 F" V& t( C4 L4 e; o
% M' N3 ^: {! x! X1 G( C阻抗:impedance
; b& f0 D! H4 Z5 `& j* j- Z$ i- V正序阻抗:positive sequence impedance2 m7 F! I: {( L5 ]! X" M
负序阻抗:negative sequence impedance- `3 o- A" K$ W! `% A$ @3 U
零序阻抗:zero sequence impedance( e6 H9 b* ]* ?* j( e4 a) o' z6 n" G
电阻:resistor
  W# F( f' z) Y' a1 u& f2 M" |电抗:reactance
5 |9 Z) U8 w1 m( {0 |0 |电导:conductance
/ z6 Y; p: T! B  d5 H2 v电纳:susceptance
2 c+ H& k' g. c" h; ]6 N8 ]9 e( }无功负载:reactive load 或者QLoad
1 t" n+ {+ }" c$ z& Y有功负载: active load PLoad
  l% [7 [& I4 w' Y3 f5 [  S遥测:YC(telemetering)
. ?' b, r6 q# F9 R' `遥信:YX 3 P; f  [9 l! `  Y, g3 G  m0 W: n# D; s
励磁电流(转子电流):magnetizing current& O4 P$ E0 G6 w( F2 m
定子:stator3 H3 b7 h) @& E4 ^" N- n
功角:power-angle: @$ V6 k1 q1 T" M3 M" Y/ N" x6 I
上限:upper limit% H! ^; C  l) V8 E6 W
下限:lower limit
1 K2 S3 r5 F  a: R3 w; `  ^并列的:apposable) X) g8 D% s$ O  k. S# O
高压: high voltage/ S$ u5 U; `+ d5 K
低压:low voltage9 Q3 |7 T5 u$ ]) Q* Y+ h8 B& T' O- Y
中压:middle voltage
/ m; O( ]  M) ^' U3 P单位标准:
, L: r9 Q+ p7 b! k正确 错误
9 v) V8 j" U# }* C电能: 千瓦时 kW.h k,h小写W大写
* _1 H2 r( j& A! M4 ]) [2 M9 O有功功率 千瓦 kW k小写W大写) Y5 m. ]) b" G2 r& q
无功功率 千乏 kvar k,v,a,r均小写8 `4 d2 E* @0 u3 D6 x  _
视在功率 千伏安 kVA k小写V、A大写2 l9 H6 p! I1 o, Q# k
电压 千伏 kV k小写V大写; N  I1 V2 D  H7 y# x0 z3 c
长度 千米 km k,m均小写
- b" [- E/ ]( l9 [电流 安培 A A大写
# m8 R0 c- Z+ L$ i4 \" C3 {8 k电力系统 power system
2 ?" R) w6 I5 ]发电机 generator
& J. h$ H. v5 o. Q9 q# a5 c2 B励磁 excitation3 p7 C; I# ?5 [" u0 p( {
励磁器 excitor
0 O/ j) x% R+ ^% j+ W电压 voltage
9 g# i' B+ H3 K) B1 A8 J电流 current+ l. m( u1 {* V6 r$ K
母线 bus
( X1 {9 y2 t5 s0 F$ T" L; D变压器 transformer4 T2 |! X# h$ B+ t0 D
升压变压器 step-up transformer1 G2 ]3 x4 p0 O4 b3 I- }% d/ O' M1 J
高压侧 high side
$ P* t& [1 y4 w) M# x7 n输电系统 power transmission system, o/ z4 C/ w1 C, e5 n' a
输电线 transmission line
9 A( B8 C6 {' |, N6 I" J: c固定串联电容补偿fixed series capacitor compensation
. K4 ?; m2 T  P3 a稳定 stability( B+ u$ R, e' E/ j4 V
电压稳定 voltage stability
2 e/ E% }3 ^) l& I- V* e功角稳定 angle stability
7 ~, D% Q5 K7 V7 V1 E4 n暂态稳定 transient stability
$ e. x9 Z2 t, z2 S& V电厂 power plant, J% ^3 g4 ~6 V2 H, e
能量输送 power transfer
9 p! A8 |# H3 Y6 L! a* D+ |交流 AC
! J' z* Y& M0 b  }+ s3 e装机容量 installed capacity; p, ?! g6 I7 D3 O- G- Y6 o% |1 b5 i$ T
电网 power system
6 c2 t/ X) K% C. \3 ?5 j0 B落点 drop point3 h& {8 f% ]& u
开关站 switch station+ s2 T* g' O5 q" X& k
双回同杆并架 double-circuit lines on the same tower( ]; h; R6 J. b4 _6 C- @
变电站 transformer substation
& w5 `: r/ G8 @! Q- _4 U1 k补偿度 degree of compensation, }! u; V3 A! Q
高抗 high voltage shunt reactor
  e% W3 N) R  X) J1 T) }无功补偿 reactive power compensation0 k  G6 C. a3 ^4 S4 w
故障 fault
: U/ L7 x) w) J6 Y( x7 J' P调节 regulation3 \3 \" ]+ y' V4 ]
裕度 magin; ?2 t' p& n( P0 |5 N9 Q8 H0 c4 M
三相故障 three phase fault , y& D$ ?6 k8 W6 w
故障切除时间 fault clearing time9 z; C6 t; \4 t6 _6 B8 D
极限切除时间 critical clearing time
$ K. u7 \1 F5 ?' i2 E4 e0 Q切机 generator triping: q7 h5 t6 v* T$ o5 M, Z
高顶值 high limited value
9 `+ Y+ z. H8 y& i, B强行励磁 reinforced excitation
2 ?6 s6 j% d9 J/ ]线路补偿器 LDC(line drop compensation)
! x1 A. G4 ]9 K机端 generator terminal+ @! t2 |% H7 [5 g) e
静态 static (state)1 M  e: d- m, c" ~( D8 J# k
动态 dynamic (state): }  D% Q3 V, h# S! D
单机无穷大系统 one machine - infinity bus system
2 ]' e2 K4 [5 A机端电压控制 AVR( u  o* F/ T6 V
电抗 reactance( T- ]( i8 L  [! Y1 C
电阻 resistance
' J6 A" }+ n; c/ ^. t功角 power angle
+ }- N+ f( W/ G+ m0 R, C有功(功率) active power) h' w  N- G9 r. P. ^
无功(功率) reactive power
2 z0 J+ J$ J2 R5 |2 ~2 x$ t功率因数 power factor+ M! N( a. J  n2 a
无功电流 reactive current
3 C7 @/ t9 e' n% u下降特性 droop characteristics
4 u1 p$ j7 f( Q/ l斜率 slope
: c$ J) M* P4 k; l# r额定 rating
# Y7 ?/ H& F) L5 X( s变比 ratio
, q/ u8 u) G$ |+ ?4 N1 J参考值 reference value
- L0 {# g* a8 R& \/ p/ Y电压互感器 PT1 f. f# `, g: N7 V: w6 B* u; E
分接头 tap" h. s5 p8 {* Q* C
下降率 droop rate9 j) k1 |6 k' \4 U0 ?7 X
仿真分析 simulation analysis# i/ g9 `2 L# Y/ g  L+ G6 y8 n
传递函数 transfer function
* Y) q/ B* Q7 A5 R+ d4 E6 W框图 block diagram1 b) \' [6 ^! J9 Z6 t# L$ E
受端 receive-side: }) B: ^# w4 [  D1 `
裕度 margin0 c+ i& @% |$ v7 U
同步 synchronization
7 W- q: ?; W8 K失去同步 loss of synchronization
0 l1 c+ d9 K( {+ O4 z3 B阻尼 damping
' h! t+ d, U4 q/ c6 q; I- D7 ^摇摆 swing7 j% F6 E1 p/ _& f; K% O7 Q4 i
保护断路器 circuit breaker
" L! Z( h5 G5 @- b电阻:resistance
* F$ D* ^' R) P+ S% `5 Y- t电抗:reactance
1 L% n) |* b! u2 u4 |2 G% `1 ?阻抗:impedance) O8 f6 v( Y. S8 N
电导:conductance
3 ~$ Y6 W4 y5 }( \4 _电纳:susceptance# o% j8 o  ?: A+ K7 d
导纳:admittance
4 B; o% I% U, y8 S8 z( r, P0 n电感:inductance0 r6 T# o7 t* B6 W
电容: capacitance 9 O( ~* t7 j# ~" d$ i9 O
热工自动化常用英文缩写词9 Y9 q8 \9 G& @! n9 }
ABC Automatic boiler control 锅炉自动控制. X) ]0 t" d0 S+ i, L# d# a9 i
AC Alternating current 交流(电)0 ?1 m: w8 h( x/ O( b
ACC Automatic combustion control 燃烧自动控制
. ~5 x( ~0 w9 ]  v) r" i9 A) o, \7 KACP Auxiliary control panel 辅助控制盘
% J3 [: g% g9 B6 ]2 v, fACS Automatic control system 自动控制系统( L& v6 N% J0 u- p2 h+ l
ACT actuator 执行机构
; x5 a! O- F1 d: X1 E0 L  TA/D Analog /digital(conversion) 模/数(转换)
  J$ ?& W! n- E. k9 n. k$ [* \, IADP Annunciation display panel 报警显示板
2 q/ R3 @" q8 M6 iAEH Analog electro- 模拟式电液调节
) u6 V7 w8 a; P" P1 t" n+ [AFC Air flow control `送风控制
0 l# R7 [, S/ u' K/ k) pAGC Automatic generation control 自动发电量控制$ [- W9 z3 X  r
AI Analog input 模拟量输入
/ ?& W8 k7 W* O6 }+ Y  n! O! B3 gA/M Automatic/manul 自动/手动
! r$ U9 [* p' m- p: N# l; a* J% kAO Analog output 模拟量输入+ d4 b3 s6 n: n" l) X
APC Automatic plant control 电厂自动控制
; y5 k+ R' o4 W" A1 AASS Automatic synchronized system 自动同期系统4 {8 X5 `- o; Z, G5 [7 i& D
ARP Auxiliary relay panel 辅助继电器盘
1 `; f) {) x/ P% @7 WATC Automatic turbine startup or shutdown control system 汽轮机自启停系统3 l9 u' }; d1 V
BCS Burner control system 燃烧器控制系统
8 |$ P/ I- t9 a% f: q) jBF Boiler follow 锅炉跟踪
: S% j9 F5 A5 Z5 f" a4 U" gBFC Boiler fuel control 锅炉燃料控制
& ?5 l! T8 j. }# q- T* a( EBPS By-pass control system 旁路控制系统% v# l! O" ?6 ?
BTG Boiler turbinegenerator(panel) 锅炉、汽轮机、发电机(控制盘)
6 h5 B5 q+ @/ h' a3 s1 ZCCR Central control room 单元(中央)控制室3 q* l0 D! ^0 N7 K5 z9 m1 I
CHS Coal handing system 输煤控制系统% `3 ~, _5 j* W  C
CJC Cold junction compensator 冷端补偿器
! L+ @' M, V: O* o( @CPU Central processing unit 中央处理器
' E5 T7 C5 j$ w" T4 d  q/ l$ `) CCRT Cathode-ray tube 阴极射线管屏幕显示器4 N  E0 T6 e; L, M- y
D/A Digtal/analog(conversion) 数/模(转换)' Y- O6 `2 ~3 }
DAS Data acquisition system 计算机监视系统或数据采集系统
  d& y0 K2 ~$ l6 X+ s' `! |DC Direct current 直流(电)) a! m4 @' M, z
DCE Data circuit-terminating equipment 数据电路终端设备
" c+ }4 @0 k- V9 l# j5 [) u! }DCS Distributed control system 分散控制系统
) T" Y) Q( J* o" ?. r8 wDDC Direct digital control 直接数字控制/ h5 }- s) G$ y
DDP Distributed datd processing 分散数据处理
/ K$ W4 N, e6 _6 V7 e; C. uDEH Digital electro-hydraulic control system 数字式电液控制系统* ^6 P  D5 c/ D3 }
DI Digital input 数字量输入, J0 }# n2 @; S; u, V
DMP Damper 挡板、风门$ D  v+ N' |( T/ ]: {% p
DO Digital output 数字量输出
( c1 t4 C* a0 N! BDSB Distributed switch-board 配电盘6 ~) I" W" {$ H! z
DTE Data terminal equipment 数据中端设备
; X: J% H7 C* m/ H( E4 wEEPROM Electrically-erasable programmable read only mrmory 电可擦写只读存储器4 C6 E# |% D- U
E/P Electro/pneumatic(converter) 电/气(转换器)# {% z1 P. W$ j
EPROM Electrically programmable read only memory 电可编程只读存储器
" d  M" [* f/ X* \9 L; tES Expert system 专家系统
7 L% b4 n5 h/ t+ cETS Emergency trip system 紧急停机系统' C/ O! r5 }0 D  m) u5 E2 L" c
EWS Engineer wok station 工程师工作站1 A* N' [! m3 k4 y5 I' M2 N3 d
FA Full arc 全周进汽
# K6 [5 I8 H3 Y9 LFB Field bus 现场总线
3 m0 q9 Q' W: w% lFCB Fast cut back (机组)快速甩负荷
  d- u- ]. V' Y8 B& D& I/ zFDC Furnace draft control 炉膛压力控制3 `7 p0 S: V  X" R. t% i
FSS Furnace safety system 炉膛安全系统
0 ~' O$ Q8 E4 q, Z" H: pFSSS Furnace safeguard supervisory system 锅炉炉膛安全监控系统
$ o2 P) |" Q  g! t$ z0 [) l3 @1 w" o5 F) \/ xGV Governor valve 调节阀门, ~& a; m* Q$ }& c" b% k: ?' r
HBP High-pressure by-pass valve 高压旁路
$ }7 {% M2 n$ C4 }I&C Instrumentation &control 仪表与控制
: I* C0 N, H& YINT Interlock 连锁* i6 q2 j2 R! f; P9 Z, |
I/O Input/output 输入/输出  I1 R: }( u2 ~# d* H$ _- f
IDP Integrated data processing 集中数据处理5 S2 `) @: k- H$ H* z8 g- [
KB Keyboard 键盘. c5 o; p; {+ G. L/ B
LBP Low-pressure by-pass valve 低压旁路) F; k9 K0 Q0 N$ K% _  i
LCD Liquid-crystal display 液晶显示器
/ x6 a( r0 f; W4 P& kLED Light emitting diode 发光二极管
0 J6 p3 ^- X; Z$ ]. g3 a( x2 GLS Limit switch 限位开关
2 B# U& w+ b, c3 a0 K! f( _* kLS Level switch 液位开关5 j1 T* V( h# w# E
M/A Manual/automatic 手动/自动
' n3 ~' F6 S1 O, y1 }, LMAX Maximum 最大值
/ v3 U3 f, w- A6 E8 }. dMCC Motor control center 电动机控制中心
" L1 i0 x$ ~5 I* t: ~MCR Maximum continuous rating 最大连续运行负荷
3 I5 h$ [$ s8 w. D+ X+ o* O) tMCS Modulating control system 模拟量控制系统
% D5 g. r; _, [& F0 {MEH (BFTP)micro-electro-hydraulic control system (锅炉给水泵汽轮机)电液控制系统
' y% T& b- L- k* E+ v# aMFT Master fuel trip 总燃料跳闸" ?' E# w5 c9 w1 k+ Z* o
MHC Mechanicial hydraulic control 机械液压式控制; Q2 h% P" n' C9 t% `1 b$ E
MIN Minimum 最小值- A- r4 R" S: Z# F) x
MIS Management information syrtem 管理信息系统
/ r8 Y+ P- V, qMTBF Mean time between failures 平均无故障工作时间4 k* z: v. p+ f- I0 M& w3 j
MTTF Mean time to failure 失效(故障)前平均工作时间0 k. \7 X$ P4 ~- r  F' O
MTTR Mean time to repair 平均故障修复时间# Q+ R1 U$ q7 Q
NC Normally Closed 常闭
. N3 s) }4 d% J/ DNO Normally open 常开, W+ B% r, c; E. r8 x
OCS On-off control system 开关量控制系统1 S% G- l$ R" a3 Q0 c1 B6 R
OEI Optic electric interface 光电接口9 [  T! R5 i! ?: O4 i9 ?6 h
OFT Oil fuel trip 燃油跳闸- ^6 q! R; j( A/ Q
OPC Overspeed protection CONTROL 超速保护控制
8 L3 m& L0 H- R9 V$ Q1 fOS Operator station 操作员站: {2 C* z; l$ r1 R5 F( k7 P: p
PA Partial arc 部分进汽
  F6 u3 G9 ]- G7 X; g) b$ I+ HPC Programmable controller 可编程控制器) M: I2 J% `' n6 W8 F
PCS Pulverizer control system 磨煤机控制系统' K9 g! x7 {1 |( C1 g% h+ V
PI Purse input 脉冲量输入
+ k5 l2 g* @  J. E  XPID Proportional integral derivative 比例-积分-微分
% h% K. w1 X4 d6 c. H1 hPLC Programmable logic controller 可编程序逻辑控制器
: m& U( u3 N, f" w8 `PO Pulse output 脉冲量输出, R: r/ e. I! v3 f2 d: d! }
RAM Random access memory 随机存取存储器
9 n& l; C) \& e( R5 yRB Run back (辅机故障)快速甩负荷
% F5 ?3 W4 u" v1 S/ ~) O/ {4 FROM Read only memory 只读存储器3 }- b, _( m8 D' b* S
RTC Reheat steam temperature control 再热气温控制! y. Y; z) x  m1 }6 K
SBC Soot blower control system 吹灰控制系统
" O, j2 ~9 h& `# w7 @  W2 ]SCM Single chip microcomputer 单片机
& }) }/ |) B% Z* U7 A) {) G- v+ }+ S. ISCS Sequence control system 顺序控制系统
- f) `  j3 Z7 H. Q8 m* i) JSER Sequence events recorder 事件顺序记录仪: z4 E' D& Y( g1 h
SOE Sequence of events 事件顺序记录$ s/ o. l0 J+ p$ d  F2 ^2 f# @
ST Smart transmitter 智能变送器1 f: M/ w5 G: H+ o9 L' y6 ^
STC Superheated steam temperature control 过热气温控制
% B# F: P$ A  mTAS Turbine automatic system 汽轮机自动控制系统
+ ?1 w1 d  ], g  ~TBP Tuibine by-pass system 汽轮机旁路系统# f3 Z0 t/ h3 N. G3 c1 T
TCS Turbine control system 汽轮机控制系统) @; e" A3 ^% m6 L6 y
TF Turbine follow 汽轮机跟踪2 M1 F% @2 `0 V$ X3 Z
TSI Turbine supervisory instrument 汽轮机监视仪表
' b5 G; _5 u2 I% JUCC Unit coordinated control 机组协调控制
. A0 x0 W: f: E5 m1 rULD Unit load demand(command) 机组负荷指令, p2 {* Y- b  F+ p# D
UPS Uninterrupted power system 不间断电源
发表于 2007-4-4 11:38:41 | 显示全部楼层
谢谢哝
::41:: 谢谢
发表于 2007-4-13 15:05:26 | 显示全部楼层
好!不错啊!
发表于 2007-4-17 17:24:28 | 显示全部楼层
很有用的资料 收下了  感谢楼主分享
发表于 2007-4-19 11:52:22 | 显示全部楼层
晕,找不到
发表于 2007-4-20 11:38:31 | 显示全部楼层
太好了,多谢!
发表于 2007-4-30 14:47:45 | 显示全部楼层
xiexie
发表于 2007-4-30 14:51:11 | 显示全部楼层
::46::  shouxia
发表于 2007-5-9 21:25:10 | 显示全部楼层
太好了!谢谢楼主。很有用啊!
发表于 2008-3-4 21:07:26 | 显示全部楼层
好
继续上传
GMT+8, 2026-11-27 20:02
