发表于 2008-4-27 08:52:15
The TLINE program is used to calculate parameters of traveling wave lines. , f) T' F# b) Q7 X: e! Y
For different model, the algorithm are different. 3 F! X) F5 t& v% b' g
For example the most often used Bergron line,
% b$ @$ u- W4 G0 b8 c$ D: cThe results will be traveling time, surge impedance,Resistor and transformation matrix.5 A/ o6 T6 l1 e- q, L1 s
The 230KV, 60Hz, 100MVA is default value display on the program.
$ j' R7 v. k8 }; DYou can change those anyway.
/ ?# Z! K: F# d8 A. L# q- yHowever, those three are not used in the program at all.
) m7 i& @2 y; uTherefore, whatever you type, just for yourself reference, tline.exe doesn't use it.
- ^& o" T- }6 uYou don't need to worry about it at all.# S t. A6 _ X) Z' \' W# X
There is some description of tline algorithm in chapter 4 of EMTP theory book.0 ^* M! A/ _8 h9 R
Notice that tline.exe is written by EMTDC people, it may not be exactly the same as EMTP./ t1 b! Z1 Q- g% _6 Q
However, basic theory would be the same. |
