文档文案
| 文档文件名称: |
| 内容简介: |
| 所属专业方向: |
电机 |
| 文件类型: |
| 来源: |
转 |
电机专业英语" e9 s/ U; z7 y+ m9 n
complete motor type||配带电机型号
! b0 x9 i* N* N9 C$ O5 [- R7 {. }9 T& ocompound motor||复励电动机/ L- Q8 x G7 L W2 m: ?
compound-wound motor||复激电动机; 复励电动机
6 u, L! I, h9 C/ C+ R' Kcompressed air motor||气动电动机, ^. u% X% C) O
concatenated motor||级联电动机; 链系电动机; 串级电动机
4 x( N) b4 F/ o* E: _concatenation motor||链系电动机; 串级电动机, z3 o1 P! H. H
condenser motor||电容式电动机, I' x! U5 I* l; i4 G. r
condenser run motor||电容起动电动机
, S8 G. E! U$ H& hcondenser shunt type induction motor||电容分相式感应电动机
; ~7 b0 A/ m" ^) [0 ?condenser start motor||电容起动电动机
1 z0 u S" V e4 J0 h: U4 }1 W) o. ^condenser-start induction motor||电容起动感应电动机
9 e1 M1 B! X# W$ m, A0 ?; W; `7 L/ hconnector motor magnet||回转电磁铁( I7 w4 [0 {/ L
consequent-poles motor||变极式双速电动机; 交替磁极式电动机 t4 c; t: n+ {* `
constant current motor||定流电动机
$ f, M; `6 `. D* U2 {constant displacement motor||定量马达
2 `9 W, N- I& X8 `3 l: tconstant field commutator motor||定激励整流式电动机
1 ?/ C4 i) A- g: j/ ]constant power motor||恒定功率电动机* p8 \; F. T+ j4 y' v. A7 `3 z4 f& Y
constant pressure motor||等压内燃机
' q, d" i2 v+ oconstant speed motor||等速电动机; 恒速电动机; 定速电动机
/ {6 f- n& j9 [3 fconstant torque asynchronous motor||恒力矩异步电动机3 P/ X% h1 [9 m2 O8 @2 ?; t
constant voltage motor||恒压电动机; 定电压电动机7 _, }! F/ X2 Y- C- W
constant voltage motor generator||恒压电动机发电机* R, s+ z# o$ H3 D, A+ r
constant-current motor||恒流电动机: u7 S3 b) q; M
constant-speed motor||等速马达' `+ a' g7 C0 U
constant-voltage motor||恒定电压电动机
6 T' n: `: A# y% I1 z" ~7 Lcontinuous-time-rated motor||连续运行电动机7 c0 R; l B( g, \7 r* P+ a
continuously rated motor||连续额定运行电动
. s4 p( z. U9 `3 b+ vconverter-fed motor||换流器供电电动机1 @6 Y$ p0 N! D2 [2 _ L4 r. {5 k
coolant pump motor||冷却液泵电动机. p9 w0 K0 k/ u
cooled motor||冷却式发动机% f4 ]% o5 \) M. l+ n
cortical motor area||皮层运动区
6 a! T, [' b& j* A$ d i' Kcortical motor areas||皮质运动区: V& o8 u( w4 Z9 t8 z! P8 X+ j
crane motor||吊车电动机. [9 _1 s& _+ b/ E: G0 q: Y- j
crawler-type motor grader||履带式自动平地机8 M6 o" H' { T+ |
crescent gear motor||内啮合齿轮马达6 h8 a1 f$ h! {" H, u
cross feed motor||交叉馈电式电动机, A2 R3 p8 M0 }
umulative compound motor||积复激电cup motor||杯形电机
9 }& z( e8 W8 k1 G4 M: W3 \' F( U6 d7 z6 [
current-displacement motor||深槽电动机; 深槽感应电动机8 N" Z y! W! ^1 b/ K# L/ J' b, Z
cutter motor||截煤机电动机+ h: Z" C' D9 A
cycloid gear hydraulic motor||摆线齿轮油液压马达
0 w% Q% C5 ]% s& b6 _( dcycloidal gear reducing motor||摆线齿轮减速电动机
1 _! V0 ^2 b C. ecycloidal needle wheel type motor||摆线针轮电动机, W' Y( s; g0 a8 N' p
DC electronic motor||离子式直流电动机
" z# w7 z/ F6 \/ J0 xDC series motor||串激直流电动机
/ i1 j$ f$ V1 E: Y" kdead motor||关闭的电动机- N! z4 ?4 L8 E6 T& z3 R
decompounded motor||差复励电动机+ K" O/ B" c, d1 H
- p1 K$ C) Q4 R& n( k
decussation motoria||运动交叉8 N. m, J+ z9 o$ c* R& ?
deep-bar motor||深槽鼠笼式电动机" t" ]1 y3 I5 ^4 |
deep-slot induction motor||深槽感应电动机
8 [, d# P0 K7 C2 [ K2 ]( a! L4 [deep-slot motor||深槽感应电动机
0 Q7 O [7 B+ Sdeep-slot squirrel cage motor||深槽鼠笼式电动机. A8 O: k" C+ N) n# Y/ V0 P# T& X
definite-purpose motor||专用电动机- |5 C; |' N) @' ^
deluge proof motor||防水电动机6 M) L- V5 {9 q+ }% I
Denison motor||丹尼森液压电动机; 轴向回转柱塞式液压电动机
$ `6 e/ k% g8 mDeri motor||德里电动机
8 F$ {9 Z( ]0 A2 D; I- UDeri repulsion motor||德里推斥电动机
5 f9 |0 u0 O# |9 o' Pdespun motor||反旋转电动机; 反自转电动机5 n- b! h) M( j) i. l) B6 z5 _
diaphragm motor||膜片阀控制电动机; 光阑驱动电动机
9 X1 o7 f' R! Q. `$ Ndie-casting machine for motor rotor||电机转子压铸机: C( {6 J9 ~$ ]7 c) ^/ H, Y- p1 l
diesel motor||狄塞尔发动机
7 y" f5 Z( G* f) c' qdiesel motor roller||柴油碾压机; 柴油压路机( ~/ l2 ?. ?1 ^+ C% d% x% D
differential compound motor||差复激电动机; 差复励电动机; 差复励电视机; 差复绕电动机; 差绕复激电动机 r. n/ `4 g9 i4 m/ m
differential motor||差绕电动机. i$ n& b2 p f3 h/ y
differential selsyn motor||差动自动同步电机
) n, N4 r) e. ^6 }. H& Pdifferential shunt motor||差并励电动机8 R5 h$ O) d z1 _- Z8 [
differential wound motor||差励电动机) f1 @4 Z L# E5 F4 j
differential-field motor||他激差绕直流电动机
+ C; P8 x, c( L# W3 m7 @differential-field series motor||串激差绕直流电动机1 U- C b' [% r3 o. g6 S
differentially-compound wound motor||差复激电动机4 n. k. V9 o/ B, ?, k) ]
differentially-wound motor||差绕电动机
/ N1 ^/ m6 T) a! ?# b [direct motor drive||电动机直接传动: g& u {) `" c+ v2 g
direct motor driven||单电动机传动的
6 ~1 t: m1 D- r3 W( Adirect-connected motor||直连电动机2 e/ N6 E' C2 Y$ Q
direct-coupling motor converter||连轴电动换流机( L/ [: g; D9 B* L/ q- b+ _$ f; w; P( l
direct-current motor control||电动机电子控制
. y# F2 G) O6 c3 x t7 f( bdirect-motor-driven||单电动机传动9 g+ y9 G! B2 X" N7 ^5 N) q! l) l4 ]
disabled motor switch||电动机故障断路器
" U; k4 E7 O5 d8 l: F, i7 Xdither motor||高频振动电动机; 高频振动电机; 高频振动用电动机
3 O# F! f7 N I P' V# b; jdouble armature motor||双电枢电动机
$ k* I6 h# x6 s, X7 l% _double commutator motor||双整流子电动机; 双换向器电动机
1 b4 C4 T8 E0 l6 {2 n: J' [& Rdouble motor||双电动机. k) ^% F% H2 k/ Y# I/ E" k- D
double squirrelcage motor||双鼠笼电动机. I& [, K$ T6 g7 R. u6 _5 L5 U
double-casing motor||双层机壳式电机
9 @! q) X# y9 E% @( m8 ~, u3 Ydouble-fed repulsion motor||双馈推斥电动机
, A9 L/ J# a6 z7 hdouble-reduction motor||两级减速电动机- ] M7 J. R) k; B( h1 g
double-unit motor||双电动机机组
, t* W# g$ I/ F. s4 ?drag-cup induction motor||空心转子感应电动机8 V' j7 `7 q8 {4 m: F1 d* |, w
drag-cup motor||拖杯式电动机; 托杯形电动机" Z9 I$ }- B! o
drag-cup type rotor motor||空心转子电动机
J* B9 j* G& ~drill-motor rotor vane||钻孔转子叶片
5 A: g! Z! b! I& jdrip-proof motor||防滴式电动机
; a5 W+ ?6 ~$ v% d" J" Q, zdrip-proof type induction motor||防滴式感应电动机; r2 K9 M$ A/ R- D
drive motor||传动马达9 r5 M! K( t2 E5 Z2 r; a) _
driver motor||主驱动电动机/ \( T# J' h: \! p1 W
driving shaft motor||传动轴电机
2 Y# J6 R8 ?$ R; N/ ldrop-proof type motor||防滴水式电动机
8 E {. F( v. d9 V- h" T4 Adrum motor||鼓形电动机, J7 I" G9 o' {) U
dual-capacitor motor||双电容器式电动机
" k& \/ ^5 R2 `8 c; N! Hdual-frequency motor||双频率电动机+ P( _2 W5 b Q
dual-thrust motor||双推力发动机6 g$ Y( P. m; {" k; i8 S
duocentric motor||同心双转子电动机
$ }5 q; Q3 |5 p4 Y2 `$ [duplex power feed type A.C. commutator motor||并联馈电整流式交流电动机
5 f# z3 l5 _8 h D6 z( e0 {6 @1 Jdust-tight type motor||防尘式电动机5 V% j, e7 t1 ^; z: s
dynamoelectric motor||旋转换流机! q& _- b! Z. I. b3 y
E-P signal motor||电动气动信号机
, H `5 x# W+ T$ u# D+ P/ W( j9 ]eddy currents in attraction type motor||吸引型电动机中的涡流; _7 x2 m$ H. i/ { `
秋风 2007-12-22 12:46 |
