查看: 9666|回复: 22
探讨一下,有人运行过EMTP-ATP 的 EXa_9.adp (雷电过电压仿真)吗?
 荐  火 [复制链接]
发表于 2007-12-29 15:42:32 | 显示全部楼层 |阅读模式
我运行的时候,怎么老是报错呢,其中报错的文件如下:
# a% Z6 Z. A& l, P+ |7 fYou lose, fella.   The EMTP logic has detected an error condition, and is now going to terminate program execution.  The following
& b2 l9 a! `. _8 umessage summarizes the circumstances leading to this situation.  Where an otherwise-unidentified data card is referred to, or where
3 g$ g6 n  G% ~$ o1 [the "last" card is mentioned, it is the most recently read card of the input data that is meant.  The 80-column image of this card
, t9 i" J% Z8 xis generally the last one printed out prior to this termination message.  But possibly this last-read card has not yet been# [: g( @0 d' S6 H
displayed, so a copy follows:
$ X' y& ?, r5 |0 E7 ^  u4 X "  LINE1ALINE1BLINE1CTWR4A TWR4B TWR4C TR400ATR400BTR400CPT1A  PT1B  PT1C        "/ g0 u& b  t. W) G) M4 W* p# S7 q
              KILL code number                Overlay number               Nearby statement number
4 B7 W* U" I( e  p6 r( @                          1                         12                               1537
- @; k. o( T/ Z9 w- s& fKILL = 1.   Storage exceeded for EMTP List Number 8.   See the dimensioned limit in the case-summary statistics below.  The problem
( J. t5 d% \1 U1 n  lis simply too big for the program as currently dimensioned.  If you are using Salford EMTP for Intel 386- or 486-based PCs,  you are4 G  n: Q1 G& [$ A
fortunate enough to have dynamic dimensioning as described in the Oct., 1993, newsletter.   In this case,  edit  LISTSIZE.DAT to
- g  u9 \, H# c7 ]! Oincrease table sizes,  and then try again.   Others need a compiler and linker plus the variable-dimensioning program  "VARDIM"  in
  U/ l6 Y- c- K0 korder to increase EMTP tables before trying again.   Sometimes the reason for EMTP table overflow is unclear, however,  and Program# E) A. s+ E9 s& e. z) A+ j/ m
Maintenance might wish to inspect the contents of the error interface vectors  LSTAT  and  FLSTAT.   These now follow.   First comes
# T2 H3 f9 H' w' |5 L& iLSTAT, using (12I10) encoding; then comes FLSTAT, using (8E15.6) encoding:5 V. a; k7 S* _( D6 g4 C
LSTAT =     -9999     -9999     -9999     -9999     -9999     -9999     -9999     -9999     -9999     -9999        11        296 I# }1 W! z* ~
LSTAT =       255        73     -9999         8       256      3100      1537     -9999       135       149       255         4' ~/ _9 Q1 K# }& `4 n$ [% l; c' U% p
FLSTAT =   2.810000E-01   2.810000E-01   2.810000E-01   2.810000E-01   0.000000E+00   0.000000E+00   0.000000E+00   0.000000E+00" q+ a. R+ `' `" W- X
FLSTAT =   0.000000E+00   0.000000E+00   0.000000E+00   0.000000E+00   5.000000E+01   0.000000E+00   0.000000E+00   0.000000E+00* m" B# k. j- f6 e
FLSTAT =   0.000000E+00   0.000000E+00   0.000000E+00   0.000000E+00   0.000000E+00   0.000000E+00   0.000000E+00   0.000000E+00
, Y3 X# P# h" B2 Y0 N0 R: L  fYet maybe the user would like some suggestions as to why the table in question  (List Number 8 )  has overflowed.   If such further
+ }$ k/ w9 r8 R- q' H  N# t( _information is available,  it will now follow immediately ....
/ e3 @6 b$ ~8 d7 [8 zList 7 stores past history points for distributed-parameter transmission circuits (lines or cables) in modal form.   Each
. Y% A0 I: S: Cpropagation mode requires storage, and there are as many modes as there are coupled conductors or phases (e.g., a double-circuit8 o' H8 [, _5 Z/ g7 v
line will normally have 6 modes).  Each mode requires TAU / DELTAT  entries,  where TAU is the modal travel time of the line,
% f" h$ }: v0 {( BDELTAT is the time-step size,  and the division involves integer truncation followed by the addition of unity.
' O) B2 s! g- ~- a) T& @$ n3 EIn order to effectively trade memory space among the different EMTP tables (EMTP List Sizes), the user must know how many arrays$ `% c: M9 G$ t6 Q" B' b: j
(columns) there are in each table.  The following tabulation shows the effective multiplicities that are associated with each
6 d: }* D: Z" K8 {  D, i: \; Lindependent EMTP List Size (those lists whose lengths are under user control by means of the EMTP variable-dimensioning program& s4 h! c( R8 V# s( c/ F+ a
"VARDIM").-%-83643-%-
相关帖子
    2018-5-7 14:01
  • 签到天数: 22 天
    累计签到:22 天
    发表于 2017-5-12 14:55:22 | 显示全部楼层
    ziwaichengxiang 发表于 2016-12-20 16:17
      o! x- `4 \+ v; V$ `4 P我运行了,没问题啊!
    # N- f/ y) {3 q. }) K请问那个例九是中文手册上的么 我怎么没有找到 我的ATP版本很老了?求解答
    " t( ^0 y  f6 z  ~2 j( ^: v# a2 Q
    [发帖际遇]: 一个袋子砸在了 Dianlichong 头上,Dianlichong 赚了 学分1 点. 幸运榜 / 衰神榜
    回复 推荐 踩下
    使用道具 举报
    2016-2-18 13:37
    发表于 2016-2-18 13:59:14 | 显示全部楼层
    新手入门,ATP Launcher都找不到,烦请指导一下。
    2021-6-12 15:29
  • 签到天数: 102 天
    累计签到:102 天
    发表于 2016-12-20 16:17:51 | 显示全部楼层
    我运行了,没问题啊!
    点评
    请问那个例九是中文手册上的么 我怎么没有找到 我的ATP版本很老了?求解答  详情 回复 发表于 2017-5-12 14:55
    [发帖际遇]: 带头手机上上研学论坛,奖励ziwaichengxiang学分4 点,赶上移动互联网大潮. 幸运榜 / 衰神榜
    回复 推荐 踩下
    使用道具 举报
    发表于 2008-7-7 08:41:26 | 显示全部楼层
    我运行过。没这个问题。
    发表于 2008-7-7 10:21:22 | 显示全部楼层
    可以运行阿,呵呵,不知道
    2016-8-5 14:45
  • 签到天数: 6 天
    累计签到:6 天
    发表于 2008-7-13 21:53:28 | 显示全部楼层
    请查一下,计算步长设置是否合适?
    发表于 2009-3-9 19:31:59 | 显示全部楼层
    我也经常遇到这种问题,不知如何解决啊
    发表于 2009-7-1 10:26:53 | 显示全部楼层
    不是有提示吗 EMTP List Number 8超出,你把他改大一点就可以了
    难过
    2021-1-9 03:12
  • 签到天数: 4 天
    累计签到:4 天
    发表于 2009-7-1 14:39:25 | 显示全部楼层
    zhangwin618现在应该是ATP处理大系统问题的绝对高手了!
    发表于 2009-7-2 09:24:31 | 显示全部楼层
    版主过奖了,我又遇到问题了呢。。。
    + j7 I' Y0 n2 D' ]8 s  Q不过针对楼主的这个问题,我想只要改一下listsize里面的第8个数字,把它改大一些应该就可以了
    发表于 2010-4-29 20:29:22 | 显示全部楼层
    俺的没问题
    发表于 2010-5-3 14:14:42 | 显示全部楼层
    设置问题,重新设一下
    GMT+8, 2026-11-5 03:43
