查看: 2861|回复: 2
防雷的仿真为什么加入避雷器以后会运行出错
    2016-10-25 19:07
  • 签到天数: 32 天
    累计签到:32 天
    发表于 2016-2-18 09:52:14 | 显示全部楼层 |阅读模式
    You lose, fella.   The EMTP logic has detected an error condition, and is now going to terminate program execution.  The following. w# A* n6 {3 @. T+ q: D
    message summarizes the circumstances leading to this situation.  Where an otherwise-unidentified data card is referred to, or where; ^: J1 ]4 W9 e; N. o/ G0 P
    the "last" card is mentioned, it is the most recently read card of the input data that is meant.  The 80-column image of this card# t2 L# ?0 B4 v1 l; E/ _2 F
    is generally the last one printed out prior to this termination message.  But possibly this last-read card has not yet been" x  q) u- g, y" K9 p! s
    displayed, so a copy follows:2 S( N3 {1 T4 D. P1 T
    "        ", v6 ]: a6 T; }1 x
                  KILL code number                Overlay number               Nearby statement number
      [% {& _0 X8 t5 }                        212                         18                               3522: p" V! `: f5 e
    KILL = 212.   A Newton solution for  1   coupled nonlinear elements has failed to converge within the iteration limit  MAXZNO = 50.
    7 K$ f7 @& o( V6 x: a$ U4 WThe current residual is  2.28977187E+06,  which exceeds the sloppy convergence tolerance  EPSTOP = 1.00000000E-01.   The first of6 F' m0 z: l- C
    the coupled, true, nonlinear elements (in order of data input) is located in row  1   of the nonlinear element table, and it
    6 n7 f  U9 n" p6 @& U$ O4 q& Jconnects node  "      "  with node  "XX0002".   The final coupled element is in row  1,   and the matrix rank is  1.   Finally, the
    : C3 `/ H, K! e" m  Ysimulation time is  T = 1.00000000E-06.   Possible corrective actions include a decrease in the time-step size  DELTAT,  an increase
    ) G- b# N; H8 Zin the iteration limit  MAXZNO,  an increase in the divergence tolerance  EPSTOP,  and artificial splitting of the subnetwork  in+ d2 B, }/ O( K9 t, [; [, H) _
    question by distributed-parameter lines (to reduce the number of coupled elements).   In addition, it is possible for the user to
    : p2 |5 Y* [" V7 Jmake a solution impossible by unrealistically limiting the Newton corrections.  The user should remember that there can be no/ S0 N8 c# F5 j( x
    solution if his bound on arrester voltage is less than the true solution voltage.  The bound has a default value of 1.5 per unit,
    " }9 W, G3 Q% u' `. T9 q$ qalthough it can be changed by a"ZINC OXIDE"  special request (columns 57-64, variable  ZLIN(2)).
    * Q$ d% m4 z$ t0 }. H. V' T/ b, M0 l# _1 Y
    以上去错误代码,有哪位大神能指点一下,避雷器模型哪里设置不对?% Z( W: ^2 W. R* U8 A6 o9 }
    , |+ B  I5 C) k* @& _5 H' ?. n, ^
    2018-1-10 21:46
  • 签到天数: 11 天
    累计签到:11 天
    发表于 2016-7-29 10:41:21 | 显示全部楼层
    我也出现过这个问题,你把参考电压重新设置一下看看
    2016-8-5 14:45
  • 签到天数: 6 天
    累计签到:6 天
    发表于 2016-7-30 16:47:48 | 显示全部楼层
    这样提问,有心帮你也没办法呀!' x/ `0 \$ K& |: J' R
    [发帖际遇]: guozh07上论坛勤快,奖励 学分1 点. 幸运榜 / 衰神榜
    GMT+8, 2026-11-19 06:41
