查看: 1081|回复: 1
来个大神看看哪里出了问题,谢谢啦
发表于 2015-7-19 21:00:23 | 显示全部楼层 |阅读模式
You lose, fella.   The EMTP logic has detected an error condition, and is now going to terminate program execution.  The following
6 w1 y+ |' W. _$ S5 lmessage summarizes the circumstances leading to this situation.  Where an otherwise-unidentified data card is referred to, or where$ ?8 y. Q- k+ C
the "last" card is mentioned, it is the most recently read card of the input data that is meant.  The 80-column image of this card
: S: M0 s$ d1 Z! q# |% c- Ais generally the last one printed out prior to this termination message.  But possibly this last-read card has not yet been
) J9 L/ Q0 ~, a) j! G7 W  N( Udisplayed, so a copy follows:: g2 p. @# o" W! i% ?1 B! [' o
"14X0184A 0     2.2E5       50.                                     -1.        1."
6 P: K$ O9 K) @$ O              KILL code number                Overlay number               Nearby statement number5 r" S4 |  @- U9 z2 Q1 E3 z& K6 V5 I
                         12                          5                               4246
3 b7 ]! _$ y$ S8 }4 k- GKILL = 12.   The bus name that was read from columns 3-8 of the last source card is unrecognizable, not having been previously
5 s) L- o- ?5 T- k- Z7 Ddefined by a branch card or a switch card.  The name read from the data card is  "X0184A".   The user is not allowed to connect6 ~0 ~/ n# t$ D" W
sources to network nodes that are not a part of the network that was previously defined by branch and switch cards of this data* z5 u: _$ H! r7 a1 m2 n1 R
case.  Any such new node would be completely disconnected from the network, so could not affect the solution.  Most probably, one or
2 c; C  Q0 z9 Y0 qmore spelling errors (including the positioning of imbedded blanks) have been made in the keying of one or more node names on EMTP data cards.
    2020-12-28 15:16
  • 签到天数: 12 天
    累计签到:12 天
    发表于 2015-8-4 14:56:48 | 显示全部楼层
    回复 1# yhwang ( r& J$ Y: t3 y  b" I5 L7 j- _
    % e2 C* z8 p8 f" k4 @6 F错误提示写的比较清楚了。节点X0184A加电源,但是这个节点在前面的网架里没有出现。如果用的是atpdraw图形界面,需要检查一下电源是不是没接到其它元件上。
    GMT+8, 2026-11-20 09:21
