电力系统 power system 发电机 generator 励磁 excitation
: H' E$ ^& w! X) Y1 Z5 @励磁器 excitor 电压 voltage 电流 current $ ^/ r0 O. }) |' r* Q
升压变压器 step-up transformer 母线 bus 变压器 transformer + `" w! x( o: t- j3 r
空载损耗:no-load loss 铁损:iron loss 铜损:copper loss 6 B$ z- }8 Y6 l; @
空载电流:no-load current 无功损耗:reactive loss 有功损耗:active loss # N+ _1 F2 `7 f6 m5 T; _
输电系统 power transmission system , C7 {/ \$ F7 `+ w" O' a
高压侧 high side 输电线 transmission line
; ]" T1 {) T/ @0 {3 A5 {" v高压: high voltage 低压:low voltage 中压:middle voltage 4 \. D& G* m8 ~. [& }( F2 n: Q
功角稳定 angle stability 稳定 stability 电压稳定 voltage stability
& t" x- g3 X, ~$ A暂态稳定 transient stability 电厂 power plant 能量输送 power transfer
) N2 J( O1 _ X' r交流 AC 直流 DC 电网 power system
7 g( `- o: a+ T' s落点 drop point 开关站 switch station 调节 regulation
0 p! t' c/ r7 a9 d/ {' g高抗 high voltage shunt reactor 并列的:apposable 裕度 margin 4 U! c% Y# N2 _+ N* ^$ ?
故障 fault 三相故障 three phase fault 分接头:tap . {, R$ N5 z+ T* g$ L( ~3 ^
切机 generator triping 高顶值 high limited value 静态 static (state) ! E* T6 v8 S; W& a- e6 _ l. I
动态 dynamic (state) 机端电压控制 AVR 电抗 reactance + v2 q2 M8 F R% X/ i$ }" i6 q' q7 F
电阻 resistance 功角 power angle 有功(功率) active power
) W1 P5 B& Q3 R+ |8 x电容器:Capacitor 电抗器:Reactor 断路器:Breaker
* m0 g) z( R1 D' R( f% c电力专业英语( W: R6 e" M/ d% D1 j' D, N% y- F
(1) 元件设备
0 @ S& ~1 m; G2 d- p0 ~: G6 C三绕组变压器:three-column transformer ThrClnTrans
3 r1 D; a/ H/ y* Z% I8 L双绕组变压器:double-column transformer DblClmnTrans* [/ ~# r, ^; h/ _; G7 v7 c
电容器:Capacitor
% j2 h7 U8 }. V并联电容器:shunt capacitor" D2 B* D$ U, s) r% I0 M' |( E* W* Y0 @
电抗器:Reactor5 \: O3 \: J; B7 i% r
母线:Busbar
O0 \) v( x) f0 r( u. X1 y" B输电线:TransmissionLine
% U0 R% d8 ~7 k) H发电厂:power plant0 l8 r+ ]; G4 W8 @: H; E. ]
断路器:Breaker
( W) ~" ^! O. k2 Z刀闸(隔离开关):Isolator5 l5 ^" |) c. q/ X9 K) C7 o* F
分接头:tap
* S2 R" ^) q8 `6 z( u7 z5 m* E. |电动机:motor
# _- f) i: e; \9 a, r(2) 状态参数
' v; d' ~; ^6 t7 z9 g9 p有功:active power
K2 X! q( r. S1 D/ @& n& e无功:reactive power# _4 x5 T+ W) A! A
电流:current
) v. y& j- _, q容量:capacity7 L- D/ b: A( T W, \: j
电压:voltage
8 S8 h o! H$ ]3 Q, i6 F G2 o档位:tap position; F7 @" N4 G4 W' T% I& g4 \$ \8 e0 j
有功损耗:reactive loss4 V. k: N" z* o9 G' {
无功损耗:active loss: X: ]9 I& @1 u/ R$ M
功率因数:power-factor# b) A# Y( u8 r. Y+ }; |
功率:power
* Z; W7 C4 W) L! T4 U% D功角:power-angle9 Z$ \3 [! `8 @( A
电压等级:voltage grade
3 M+ i2 a2 Z! J5 ?+ e# A空载损耗:no-load loss0 Q6 W; m) f# g0 M
铁损:iron loss
) ]/ {" P6 v; y; V, f4 J铜损:copper loss5 o/ r+ e. T# N6 v! E Y3 R* M1 J
空载电流:no-load current ) m* f! A- Z0 V
, H& |& z9 P6 Q4 g1 d阻抗:impedance
* l! s2 r' E9 G; S; L8 `6 B- p正序阻抗:positive sequence impedance
# M h4 W$ ~( u0 F* |3 Q" ~* Q负序阻抗:negative sequence impedance6 w" N$ U" Q( g( u! a& I" e' E: {
零序阻抗:zero sequence impedance* V0 t8 o* K7 e! h2 r: I: o7 [) u6 P
电阻:resistor' X; t0 K! G2 w8 Y7 `3 l& W
电抗:reactance
2 }4 M3 O% M% Z电导:conductance) t! e$ G4 u% T2 U8 A/ [5 J" ]' E
电纳:susceptance- b# D3 j, r" p" ~
无功负载:reactive load 或者QLoad8 @4 L% Q$ s0 x ]4 M5 \1 L
有功负载: active load PLoad
2 V* L* K, O% ?' b2 Y遥测:YC(telemetering)
4 p6 S: v, _1 f0 w9 B遥信:YX
1 p/ Y, r* ?# t- H2 M5 k励磁电流(转子电流):magnetizing current
8 z$ `6 {' t- P- ]3 M5 {定子:stator
9 x% I4 H, w" H1 x, K功角:power-angle2 j9 |5 `& ]% a% U$ d0 b
上限:upper limit
* P4 y) a- w& ~5 n0 H) {下限:lower limit% r% n1 }+ {* _8 F7 R
并列的:apposable' j; ~" F, u7 S f
高压: high voltage
4 `, f3 a1 q0 B低压:low voltage
+ P6 ?, @, m3 X0 |. T中压:middle voltage6 i: I4 t, ^0 ^. X( B# g
" n6 J A! Z7 G# A电力系统 power system! E7 i# `. R: `) l2 F ~; U
发电机 generator* H3 o1 ?) A& C$ ^( m" z0 O4 o0 N
励磁 excitation
6 o4 r# t+ X [& Z0 H励磁器 excitor
! u; J% Q5 p0 S* H% m7 b电压 voltage& w: T- b- X. y z3 K5 j6 q! j! j
电流 current
% O* h5 O7 T9 M母线 bus5 \+ L1 ~: G( [$ w
变压器 transformer5 v2 P% r( e/ B2 w
- V# ]. ]( S& t; C7 I2 }8 \9 M高压侧 high side
' E/ |- ]) L: \! ~$ _* H输电系统 power transmission system7 o: A0 d; M0 W( Z
6 r+ {- x2 ^" w7 r+ [! Q; L; D固定串联电容补偿fixed series capacitor compensation7 A* ~* g# ]) _0 w' s
稳定 stability
. z) V$ g$ D& q6 @- C电压稳定 voltage stability v* c+ O! T+ c# E
" A1 `, W* [: t! X9 j n# ~暂态稳定 transient stability
" q" a: ^& t& c( Z! I' T2 S电厂 power plant* {& x! t9 ^3 r& m* a
能量输送 power transfer
7 Y) W8 C, C7 B交流 AC# ^9 q1 y4 o0 ?* Z. C6 w+ Z H$ ]
装机容量 installed capacity
/ D7 Q( D# V* U# I电网 power system/ l8 [$ C5 g6 k! v' ~, N# M
落点 drop point
5 X" T0 J6 l( L开关站tch station
3 w* z5 @- F$ Y0 E4 Y双回同杆并架 double-circuit lines on the same tower$ V4 _% d$ c5 O% g
变电站 transformer substation* M$ B" ?# k' \- m1 ]; K1 s& ?: I
补偿度 degree of compensation
: a2 e) ~5 E) |1 {, i8 e3 ?0 o高抗 high voltage shunt reactor
: @# Q9 R- l4 P# C* Q8 J无功补偿 reactive power compensation- V* o" `; [. o
故障 fault
' T$ h2 D, _, Z8 E) e调节 regulation7 T7 P. q7 V1 N) d8 M0 L8 Y
裕度 magin5 @! f5 e& T& f
$ b7 N. z3 P* o& S* i& w故障切除时间 fault clearing time2 b' y/ M: j. Z1 O t* L ~3 q
极限切除时间 critical clearing time
2 R. q1 M K/ H# q% n, k% C切机 generator triping) L$ B0 E" d* Y. B1 k
/ J& m7 R' l* q强行励磁 reinforced excitation
4 j$ z& i' p8 K+ m1 L线路补偿器 LDC(line drop compensation)0 e( o0 y! Y- n4 ?% N
机端 generator terminal3 B- {3 U$ I$ e2 c8 z! Z
静态 static (state)) p- \9 @6 \- v$ z
动态 dynamic (state)
# m3 X0 p$ g) I: e单机无穷大系统 one machine - infinity bus system
7 F# O% T! K1 V# R( V; M机端电压控制 AVR6 K0 S4 Q4 z5 P7 J/ y! a/ ]; h
电抗 reactance
+ F4 i' y6 F% P& R) I; Z: @电阻 resistance
, ~6 I( K8 J( s; d0 W, j功角 power angle: D& A1 I! V7 U9 L* w3 N6 J$ z6 |# e
有功(功率) active power4 ^2 s* M, ?: C) z1 S
无功(功率) reactive power
E) C. Z! x9 d7 A. p. z; [功率因数 power factor; h+ H! @) q' y
无功电流 reactive current
" G- _: d4 i% L, r X下降特性 droop characteristics7 `! e7 |4 V1 A7 M. L: ]. F
斜率 slope
5 J6 H2 g( y' ?# f+ w额定 rating8 s* F% w5 v# y
变比 ratio/ N+ [: a y& L; Y* o5 D
参考值 reference value
( A: Q! [( x! Z' y电压互感器 PT
/ Q) Y# d0 A# T分接头 tap
" T& ~. ]4 D! J' y9 L N4 m下降率 droop rate
* @: ?) n4 P) Q* j! A1 l( u. S2 o仿真分析 simulation analysis
$ H6 _9 ]+ x) ~- `9 U传递函数 transfer function
$ J' s" G1 Q& O0 P1 u- U. Y7 @框图 block diagram
" x# m% E9 c2 y受端 receive-side4 l" F: o/ |. x! W' @
裕度 margin, M w, X: w, [9 a, _. s5 C" Z
同步 synchronization) B L, [7 q+ w
失去同步 loss of synchronization
6 {3 i8 ]/ v& \/ t4 B. N* ~5 U阻尼 damping
- _" R. f5 e' ?摇摆ng
* t- D/ `- Q" Y+ B: F V保护断路器 circuit breaker
o1 b) u7 X2 ] G# a+ q8 ^电阻:resistance
4 m( [8 h1 N" V9 X; K1 {3 ?电抗:reactance
. }: j/ n* S' G2 M阻抗:impedance, r4 _& _- S5 P% H7 J1 ?# `1 K' I
电导:conductance2 O3 N n w H- P
电纳:susceptance
7 D* z: I4 R) x/ C' j2 g导纳:admittance
$ v1 o# ~9 d- s: g$ M电感:inductance/ i" d( `/ S3 C# c1 b
电容: capacitance |
