查看: 3316|回复: 7
基于Simulink的发电厂接入大电网的仿真模型,求助各位帮忙
发表于 2014-12-21 21:06:44 | 显示全部楼层 |阅读模式
5 J9 B) ~: P. s5 E: c- j. O& G1 L1 F% |6 G; I
ShortCurrentFor300MW.rar (9.3 KB, 下载次数: 5) ; |; o' G' D* |. p" E: U
8 w, D" A9 d9 U$ U接线情况:模拟2台150MW,35kV的发电机分别接入2台分裂升压变压器,再由220kV接入大电网。在35kV母线接入3相短路模块,求解短路电流。模型见附件。参数设置可能不合理。仿真时Simulink提示错误信息为:4 b# p" w  W1 P5 C, V% p, W
( @" i9 |' z% g9 T
The following two blocks cannot be connected in series:% t" K  u1 D3 O5 C* `
- h; Z$ Y" T2 J) B. {Block 1: 'A: Simplified Synchronous Machine SI Units1'
5 T  c! a" a4 T( PBlock 2: 'transfo_1_winding_2: Split winding type transformer1', I3 z8 [% m! e, h' F
. E- g2 J- v& _5 \  X! y; @
The first block, modeled as a current source, cannot be connected in series with the inductive element of the second block.) \# X' M5 a( e5 i
Add a high-value resistance in parallel with one of the two block.
, g. F7 K; j- o2 z0 _You can also specify high-value resistive snubbers if the blocks have a snubber device.
6 e- ]8 _/ B2 d; ~, _
7 l9 v, B) Z! [" E意思是名字叫Simplified Synchronous Machine SI Units1的发电机是一个电流源,不能与感性元件(变压器,名字为transfo_1_winding_2: Split winding type transformer1)连接。需要与发电机并联一个高值电阻。请问大家我错在哪里?参数改如何设置。有好心人麻烦就自己理解修改这个模型的参数上传,万分感谢。
0 y8 C/ L! ]/ {$ V: [
3 l0 {+ k6 ?$ V- o& a0 R. ~
4 Q' D# z- k% m% k0 D9 y1 Q- b: z
300MW short current diagram
! o% @4 N# l- B$ @9 Y
    2017-6-26 16:16
    发表于 2014-12-22 00:29:21 | 显示全部楼层
    说得已经很清楚了,让你在发电机机端并联一个电阻。
    2019-4-9 22:02
  • 签到天数: 5 天
    累计签到:5 天
    发表于 2014-12-25 19:26:27 | 显示全部楼层
    我并了一个大电阻,没有数据啊。你们呢?
    2019-12-31 14:30
  • 签到天数: 9 天
    累计签到:9 天
    发表于 2014-12-26 08:24:49 | 显示全部楼层
    并联一个三相并联RLC负荷应该就可以了
     楼主| 发表于 2014-12-31 11:34:51 | 显示全部楼层
    本帖最后由 shanby 于 2014-12-31 11:45 编辑 ) N9 A7 o( [  V& y7 _
    7 ]: Y* l4 U  `5 M+ p$ Z
    / K: m9 g- Q1 ]2 c/ C$ @5 S# L5 J& |$ }& m9 A( C6 _! j/ c
       查看如下帮助文档:Assumptions
    ; Y7 h- d/ d$ X+ t7 P& }; C& S. eThe electrical system of the Simplified Synchronous Machineblock consists solely of a voltage source behind a synchronous reactanceand resistance. All the other self- and magnetizing inductances ofthe armature, field, and damping windings are neglected. The effectof damper windings is approximated by the damping factor Kd. The threevoltage sources and RL impedance branches are Y-connected (three wiresor four wires). The load might or might not be balanced.Limitations7 W- F# f7 D- b9 ]3 w+ U( H; F
    When you use Simplified Synchronous Machine blocks in discretesystems, you might have to use a small parasitic resistive load, connectedat the machine terminals, in order to avoid numerical oscillations.Large sample times require larger loads. The minimum resistive loadis proportional to the sample time. As a rule of thumb, remember thatwith a 25 μs time step on a 60 Hz system, the minimum load isapproximately 2.5% of the machine nominal power. For example, a 200MVA simplified synchronous machine in a power system discretized witha 50 μs sample time requires approximately 5% of resistive loador 10 MW. If the sample time is reduced to 20 μs, a resistive loadof 4 MW should be sufficient.: n# N9 w$ }7 H( I( c
    ! ~: K% z! l" T' h
    得出:! Q; y, u. H5 j$ b
    1.简单同步发电机模型采用带电阻和电抗、独立电压源,三相Y连接的电气模型;1 q% ^0 m& n) j2 `& w; A. i
    2.使用边界限制:如果是采用离散系统仿真,则需要在发电机端子连接寄生小电阻,其阻值或功率与离散系统的采样时间成比例(举例有计算实例)
    ! ^7 m' X# H: k. j8 R$ b0 T$ p8 U" f5 b
    试错结论:4 Y6 G. t0 W1 f6 a6 ~/ C( \
    1.错误提示说简单同步发电机是电流源,需要并联高值电阻。这与帮助文档电压源的说法不一致(尽管电压源和电流源和也互相变换)
    . ^) a5 W' [" e" _2.将powergui模块参数设置为continous,仿真报错与设置为discrete的报错信息一样。
    ) G# A, Y0 ]% F3.将powergui模块参数设置为discrete, 按错误提示边栏电阻,则仿真不报错(虽然结果不是预期)。( S/ s6 H% ]* T9 E* _+ b) W
    $ y0 ?3 Z$ ]- o4 i2 r6 U# e ShortCurrentFor300MW2.rar (9.71 KB, 下载次数: 1) * {" I$ T9 K" f' m5 o( g# g6 ^& K( X; D
    电压波形
    电压波形
    ) {' e+ P, p5 m' A: S4 N3 D
    : h' ~$ \9 k1 {1 ~4 E* |! o疑问:3 h, j& j; z* p4 D$ a6 S# `  m
    1.如何解释模型搭建、报错和试错结论?% f# _- y$ g" l# p. ^. Y
    2.Simulink仿真的逻辑?# \( z. p- r5 v) k( ~
    " v7 y& L2 c; ]" C+ D
    7 I6 U6 J) p: ~6 ]' n
    2021-6-12 00:00
  • 签到天数: 1657 天
    连续签到: 28 天
    [LV.Master]伴坛终老
    累计签到:3190 天
    发表于 2015-3-1 17:43:42 | 显示全部楼层
    为什么接两个transformer呢
    2021-6-12 00:00
  • 签到天数: 1657 天
    连续签到: 28 天
    [LV.Master]伴坛终老
    累计签到:3190 天
    发表于 2015-3-1 17:45:53 | 显示全部楼层
    而且还要从一个驱动器出来吗
    2016-1-7 09:12
    发表于 2015-7-20 16:43:06 | 显示全部楼层
    把变压器的电感设置为零,就可以解决了
    GMT+8, 2026-11-20 08:53
