查看: 942|回复: 0
针对离线和实时仿真的通用高电平VSC-HVDC电网控制和测试系统
    2019-11-28 00:35
  • 签到天数: 21 天
    累计签到:22 天
    发表于 2014-10-30 11:44:22 | 显示全部楼层 |阅读模式
    论文文献
    标题: Generic High Level VSC-HVDC Grid Controls and Test Systems for Offline and Real Time Simulation
    作者: Md. Rokibul Hasan, Luigi Vanfretti, Senior Member, IEEE, Wei Li, Student Member, IEEE, and Naveed Ahmad Khan
    所属专业方向: 电力电子,高压输电,实时仿真
    摘要: Abstract—This article describes generic high level control models for VSC-HVDC grid systems. An average value model of the voltage source converter (VSC) is used; it includes the vector current control strategy. As an improvement to traditional conventional high-level control systems, this paper includes dc voltage, negative sequence current and dc voltage droop control loops. To validate the controller’s performances, two tests systems were developed: a point-to-point link and a four-terminal DC grid. Both offline and real-time simulations are carried out for several test scenarios. A methodology for calibrating controller parameters is presented and used to tune the controls of each test system considering the different scenarios presented. All simulation models were developed in SimPowerSystem/Simulink and prepared using the RT-LAB software from Opal-RT for real-time simulation; real-time simulation performance of the simulation models is also discussed.
    关键字: 电压源换流器,高压直流电网测试系统,实时仿真,高电平控制
    来源: http://www.opal-rt.com/sites/default/files/technical_papers/Generic%20High%20Level%20VSC-HVDC%20Grid%20Controls%20and%20test%20systems%20for%20offline%20and%20real%20time%20simulation.pdf
      d( l7 P# @5 ~2 A9 l% l针对离线和实时仿真的通用高电平VSC-HVDC电网控制和测试系统$ f# ?: v9 y5 N* y2 G5 p$ Q
    1 D5 B6 K; B: b; k
    * Q2 {/ E1 E1 N0 K, s2 k% ]; ?' M% r6 A" v& c, c
    Abstract—This article describes generic high level control models for VSC-HVDC grid systems. An average value model of the voltage source converter (VSC) is used; it includes the vector current control strategy. As an improvement to traditional conventional high-level control systems, this paper includes dc voltage, negative sequence current and dc voltage droop control loops. To validate the controller’s performances, two tests systems were developed: a point-to-point link and a four-terminal DC grid. Both offline and real-time simulations are carried out for several test scenarios. A methodology for calibrating controller parameters is presented and used to tune the controls of each test system considering the different scenarios presented. All simulation models were developed in SimPowerSystem/Simulink and prepared using the RT-LAB software from Opal-RT for real-time simulation; real-time simulation performance of the simulation models is also discussed., w% ?% G& w# X. I! N% `4 E9 V3 k
    摘要:这篇文章介绍了VSC-HVDC电网系统的通用高电平控制模型。文中用到了电压源换流器(VSC)的平均值模型;它包含矢量电流控制策略。作为对传统高电平控制系统的改进,这篇文章包含了直流电压,副序电流和直流电压垂降控制环。为验证控制器性能开发了两套测试系统:y一个点对点连接和一个四端点直流电网。针对数个测试方案进行了离线和实时仿真。文章提出了一种控制器校准参数方法,并被用来根据不同的方案调整每个测试系统的控制。所有仿真模型都是通过SimPowerSystem/Simulink生成的并可利用OPAL-RT的RT-LAB软件进行实时仿真;仿真模型的实时仿真性能也进行了探讨。
    . \& o: f5 X+ s& U, GIndex Terms—Voltage Source Converter, High-level control, HVDC grid test system, controller calibration, Real-time simulation.
      g: P/ u7 ^. x" B abbr_0e4ce7cd41c5a83d9f6ab578cc0ad690.rar (824.74 KB, 下载次数: 0)
    & n% [* p' d" P% c) N% A* z5 }. Ehttp://www.opal-rt.com/sites/default/files/technical_papers/Generic%20High%20Level%20VSC-HVDC%20Grid%20Controls%20and%20test%20systems%20for%20offline%20and%20real%20time%20simulation.pdf
    GMT+8, 2026-11-20 11:09
