利用ATP做大型电网仿真 一直出现如下错误 8 c7 P0 S. `; d- U" j: I* b; N" P) q Y# m* b* s
++++ Type-59 S.M. number 44 begins operation on segments 0 and 0. ; j( {3 q- g; K( l2 {% ^- | REDUCT. M, N, J, IJ = 0 3 3 6 ! g" T6 I8 h' ^1 F & i; I% n+ t/ O: V4 _: J5 D------------------------------------------------------------------------------------------------------------------------------------$ {; j7 q. p" ]% Y
ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/' A8 r7 ~5 y' E) a8 @" M
ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ " j1 d4 z6 M( { s------------------------------------------------------------------------------------------------------------------------------------" w7 \" D' y( p( X& y4 U/ i
You lose, fella. The EMTP logic has detected an error condition, and is now going to terminate program execution. The following ! ^: Z$ L# t7 v3 Kmessage summarizes the circumstances leading to this situation. Where an otherwise-unidentified data card is referred to, or where 9 i* \* ^- A6 Qthe "last" card is mentioned, it is the most recently read card of the input data that is meant. The 80-column image of this card f+ S( t4 j0 e& V$ x4 ^3 P
is generally the last one printed out prior to this termination message. But possibly this last-read card has not yet been" c* v1 r9 y# c. G" g e
displayed, so a copy follows: 4 A. ]& R( u% X' N8 a3 x6 o " "( q6 K8 X+ x o8 L+ H; P
KILL code number Overlay number Nearby statement number; p& E( G: x& N ~) w" Z7 Q
86 13 42332 x5 G% w3 }( v+ g7 Q
KILL = 86. Singularity has been detected within SUBROUTINE REDUCT, which does Gaussian elimination. The diagonal element for4 A$ @: @" \( Z- S
row 3 is equal to -1.#IND0000E+000, which is less than the tolerance EPSILN of the floating-point miscellaneous data card.& t: ^' a" x2 S T! {
Other local variables that might be valuable to Program Maintenance in interpreting the trouble are as follows : N = 3 M = 0 $ O9 H2 f3 w$ }/ ?/ E/ t.0 e+ m) z" \; d8 g7 O
这是哪里的问题???
