请教一下各位大神,我的AC8B自定义模型程序总是通不过编译报错END STATEMENT IS MISSING,Syntax error found identifier strtin when + p0 \) G3 ^& j
expecting one of the end of statement, 到底错在哪里啊,求助一下!!!!
& D) T( O* N! X3 P% Q程序如下0 Z; p7 I6 f* N5 p! W
SUBROUTINE AC8B(MC,ISLOT) 9 ~7 t, z# U+ D; i4 z
INTEGER MC,ISLOT % P ^% {' V4 Z' N
C
) m7 o' j6 g# J/ ~* kC MC =MACHINE ARRAY INDEX
9 ?3 Z/ B3 C2 I; D" LC ISLOT=ARRAY ALLOCATION TQABLE INDEX $ _' a) Y' ?8 M& y- b
C J =STRTIN(1,ISLOT) [USES CON(J) THROUGH CON(J+20) ] & t# s" S; i" q6 M- ?& d$ `
C K =STRTIN(2,ISLOT) [USES STATE(K) AND STATE(K+4) ]
2 h0 F5 K9 G; J$ BC
- I% i) e3 Z+ O $INSERT COMON4
1 a+ V% e# b5 SC 1 q7 ~% u; N4 Q5 `: n
INTRINSIC MAX, EXP, LOG
& o z" m5 Q7 z9 K0 h! r EXTERNAL BADMID - {6 p: \7 S- i) m
C 8 m: c1 C t: J9 W, V- c
INTEGER IB, J, K % Y6 J+ K6 g" S5 U h1 y3 E
REAL VERROR, VPID, SE, IN, FEX, VEMAX, A, B9 a: r' \5 U# U4 X3 n
REAL VE0, VR0, VPID0
/ _; _+ \5 r3 ?3 q7 Z( eC
L& f, a2 O& B" pC DO NOTHING IN ACTIVITIES 'DOCU' AND 'DYDA' FOR NOW - H. O% d& K: U" o- X! F9 O
C
- j+ i2 M! V4 T, H, o$ u6 U% X IF (MODE.GT.4) RETURN
. J2 F9 g5 P0 e; N2 @& w# j& q- MC , Y) }' A% u4 A* ^- M- y
C BUS SEQUENCS NUMBER NEGATIVE IF MACHINE $ X8 |% `7 z6 [8 |
C IS OFF LINE,SVS OR INDUCTION MACHINE & p9 [1 Z# K3 v5 |$ F: r
C
, p8 b# v ]) |9 z) J1 d IB=NUMTRM(MC)
+ b5 r4 i( f6 z! Q' I IF (IB.LE.0) RETURN ' {+ r& H, H+ O* O- V! c/ c6 a
C : Z8 M) j8 ?& c% F& J `
IF (MIDTRM) GO TO 900
, c [4 s7 s. \6 \; G2 V& qC 3 t; }6 Q/ R* L) N8 [# H
C GET STARTING 'CON' AND 'STATE' INDICES " ?6 r3 j y- Q
C 9 Y% l6 n4 E4 ]& g2 g4 M
J=STRTIN(1,ISLOT) 3 _9 o3 B% N" F$ k1 l3 i& I
K=STRTIN(2,ISLOT)( J3 k, p3 a! p7 \) }0 K$ Z
B=LOG(CON(J+20)/CON(J+18))/(CON(19)-CON(17)) " X# U2 r) l' [7 |5 r
A=CON(J+18)/EXP(B*CON(J+17))
) r4 W- G2 Q! ^" L9 O. jC
, L! P j9 R/ k$ U! ` GO TO (100,200,300,400),MODE
& N5 ~8 x8 O2 y# p0 t8 wC 8 r* Q# R4 V( I2 `& b. n$ E* ]
C MODE = 1 – INITIALIZE
7 t% p2 C& e2 ]: XC
R. Y4 Z+ f" \( d6 a100 STATE(K)=ECOMP(MC)
4 Q4 E9 F" x: u" h4 \ VREF(MC)=ECOMP(MC)-VUEL(MC)-VOEL(MC) 7 Q: ]1 A M9 n# }+ h9 X
STATE(K+2)=0
/ g1 S# _8 A- `; S' t6 a+ @+ h VE0=EFD(MC)+0.577*CON(J+11)*XADIFD(MC)2 T9 c. D, ?; g t1 |8 ^7 h% F1 G/ t
VR0=(A*EXP(B*VE0)+CON(J+13))*VE0+CON(J+12)*XADIFD(MC)
7 A7 E4 \0 H+ L9 O5 j& c- n- O VPID0=VR0/CON(J+7)* O/ N H+ G; }! h* B4 j# ~* G
STATE(K+4)=VE0
8 E2 o. |" N- ]4 |% v STATE(K+3)=VR0, h. j+ U1 g; Z; B2 r
STATE(K+2)=VPID05 n3 f- T1 ^! I4 g$ S7 L# s; B
VAR(L)=VPID0 s# X8 p, [' _8 Y f% d: H
VAR(L+1)=1-0.577*XADIFD(MC)/VE0# x/ Y1 e6 b+ T1 Z2 K( I" Z
VAR(L+2)=(CON(J+15)-CON(J+12)*XADIFD(MC))/(CON(J+13)+A*EXP(B*VE0))5 s/ V/ t3 Z/ w+ v9 Y9 L# m: N& u
IF (VR0.LT.CON(J+10).OR.VR0.GT.CON(J+9)) THEN * H* _. D# z. k. }$ p$ V; d
WRITE(LPDEV,307) NUMBUS(IB),MACHID(MC)
1 u: _. J e2 Q" a! ? ENDIF
/ [% e5 r$ z( s: k3 L8 X IF (VE0.LT.CON(J+16).OR.VE0.GT.VAR(L+2)) THEN ' W$ H# ]+ m1 C% k, C
WRITE(LPDEV,307) NUMBUS(IB),MACHID(MC); d: }5 U7 V. K+ n9 A4 s* t6 C3 g) v0 S0 R1 `
ENDIF
' X- |* v. J5 Z! h: y9 l8 Q5 m RETURN
G3 |( g: z o8 Q$ W) j) FC
7 ^' k: A0 D! Y/ X" F p( H9 rC MODE = 2 – CALCULATE DERIVATIVES
6 e0 i) A: u6 |. V- RC
3 g& z2 O. S: X6 d5 U200 DSTATE(K)=(ECOMP(MC)-STATE(K))/CON(J)
# k8 d$ c8 Z. D G4 x6 O VERROR=VREF(MC)+VOTHSG(MC)+VUEL(MC)+VOEL(MC)-STATE(K) 8 w% L8 y0 T/ J
DSTATE(K+1)=CON(J+2)*VERRROR3 {8 a# _$ A/ D
DSTATE(K+2)=(CON(J+3)/CON(J+4)*VERRROR-STATE(K+2))/CON(J+4)
! g7 C I( @2 k% E" e! _4 i, T VPID=STATE(K+1)-STATE(K+2)+(CON(J+1)+CON(J+3)/CON(J+4))*VERROR
7 s9 P. ?" E7 o2 {1 f2 h: j IF(VPID.GT.CON(J+5)) VPID=CON(J+5)
% G$ C" B/ c/ ?2 I0 U( y& K# g IF(VPID.LT.CON(J+6)) VPID=CON(J+6)
5 z4 u+ Q6 t( p& s+ p DSTATE(K+3)=(CON(J+7)*VPID-STATE(K+3))/CON(J+8)
/ b+ F. `' t) K: s W$ H5 e6 K+ V IF(STATE(K+3).GT.CON(J+9)) STATE(K+3)=CON(J+9)
8 [: M$ T2 w/ S7 l) d IF(STATE(K+3).LT.CON(J+10)) STATE(K+3)=CON(J+10)
+ E: c9 y; A6 Y SE=A*EXP(B*STATE(K+4))
3 Q w$ V: V" a# Z I2 W X! W DSTATE(K+4)=(STATE(K+3)-(SE+CON(13))*STATE(K+4)
, G( F0 S- P: a/ M6 z* H5 Y" H * -CON(J+12)*XADIFD(MC))/CON(J+14)1 d' Q4 m* h* Y; N# q3 h
VEMAX=(CON(J+15)-CON(J+12)*XADIFD(MC))/(CON(J+13)+SE)" x. Y9 z, ]+ q* u. [4 Z7 {
IF(STATE(K+4).GT.CON(J+9)) STATE(K+3)=CON(J+9)
9 f3 }) N, }# c9 N& \! S IF(STATE(K+4).LT.CON(J+16)) STATE(K+3)=CON(J+16)+ G0 [/ e6 n' M: o2 {( @
RETURN
- e4 G% q( I% u, R$ BC ) m x; x9 J5 Y. ^) F0 x
C MODE 3 – SET EFD + y0 m$ `" D# [2 F. U
C
" z( M: p3 n0 s300 IN=CON(J+11)*XADIFD(MC)/STATE(K+4)
/ Y7 b( T, V& Y2 n4 d; ?# D IF(IN.LE.0) THEN2 s( W* l; q: J0 E, ?
FEX=1
8 {" w1 m& m- d2 _2 c7 g* A9 M ELSEIF(IN.LE.0.433) THEN( j* |/ v% i" j. }9 e! a
FEX=1-0.577*IN
3 z5 F8 l- R2 A1 T9 w4 I ELSEIF(IN.LT.0.75) THEN
0 [4 k, N* S" a- T9 J2 m; [1 S$ K FEX=SQRT(0.75-IN*IN); \( z# n9 b% T* B) r- N0 g: _
ELSEIF(IN.LE.1) THEN
# d) a! q5 j; W& w2 ]3 B8 L7 r FEX=1.732*(1-IN) j4 O7 L5 [, {. w; g% @
ELSE
1 n6 a) ^8 u; F* C FEX=05 O- u {" M+ D& Z
ENDIF
9 L1 {( H8 @$ @5 ^$ E! s4 Z: A( o3 H3 [ EFD(I)=FEX*STATE(K+4)
6 w) w+ k8 u& e8 J! N$ r$ a RETURN
5 Y! n3 ~" t, o5 y- TC & [# s2 O$ e$ q1 d* b+ k! f! @ C: O
C MODE = 4 – SET NINTEG / L: b# z" p- [" K
C
# d3 D6 [5 U' r- _400 NINTEG=MAX(NINTEG,K+1) 3 b2 s8 l3 p( }
RETURN8 N' [2 g9 `6 Z2 `3 x/ E. E' i! l
C
) N& T& E0 q' }# [& w" l ?/ _+ SC MODEL NOT IMPLEMENTED FOR MSTR/MRUN
, t9 h) m4 F$ A( Y! x) [C
% s4 X$ c i: j6 k; g7 M! Z307 FORMAT('AC8B AT BUS',16,'MACHINE',A,3 j" e# b+ H* r) [+ O
* , 'INITIALIZED OUT OF LIMITS'), D0 g: a; d4 [6 N' n
C. n2 s( {- M& U- X9 u M1 s: W
900 CALL BADMID(MC,IB,'AC8B')1 H; R- k D* v7 ?5 p
RETURN
6 z& a8 m' j# U k$ x0 @9 a6 _C
( l: f5 @) S$ v) Y8 { END |
