+ C# t) _0 t9 j" H+ \5 y; c" lA. bt下载,地址如下:http://www.torrentdownloads.net/download/1651310411/ETAP+7+0+0+with+Serial+Activation+Full+Modules+iso $ K Q' A8 L) a. V: ?, Z: y # m& R- |6 b7 J }B.安装并石皮解,方法如下:7 E; O' l' d5 n- @; v! F/ ]& F
1. Downloaded etap-7 file is on iso format, so burn it on DVD or mount on POWERISO & save the setup on hard disk. 9 X" r( {/ ^/ v, D' ~. V3 E2. Download 石皮解 from "http://www.megaupload.com/?d=2JQLU4YB". THis is 石皮解 for ETAP 6.0. Its works ok for ETAP 7.0 also.: G3 |( k* V. Y5 {
2. Disable connection to internet: ?0 S' [) z2 t2 B+ ^& c
3. Disable antivirus software on your computer8 G7 m; U/ [# y$ b) W( ~8 m
4. Run Etap-7 installation from DVD/Harddisk. 1 v5 u3 G' u( u( {: y5. select install + license manager, just follow the instruction. & J6 [* U# N d
6. When finish installation, dont run the software. 6 x `0 ]8 E5 O; m! z8. Open folder LMSETUPSYSTEM32DRIVERS on etap DVD , S# e, U. I' h/ x* k& e8 H9. copy all files in the LMSETUPSYSTEM32DRIVERS ----- to ------ C:WindowsSystem32Drivers 0 M* H$ h1 c3 _2 |# t% e10. Extract 123.rar (石皮解, downloaded above) and place the exttracted files(etap6.exe) to ETAP 700 Folder. $ o' _' J. }" {( Q: S$ @1 c i11. Goto c:Program FilesOperation Inc. Technology ETAP Licence Manager and open the file ETAPKEY.exe. A window will keep running. Let it be running. ) N/ `0 Q- }9 s9 f2 Y12. Now Go to ETAP 700/Parche/ETAP6.exe" and run etap6.exe. This is the software to bypass license.( B2 S$ G3 f- u9 R r
this file is under DOS file, so you will see DOS application run. win7用户在此步骤需要“以管理员身份运行此程序”,不然石皮解会失败。) J; @) K1 l8 K: n" i
13. After finish installing ETAP6.exe, then Reboot your computer/laptop. ' Y+ D9 L) [; L5 g5 @14. Enable again your antivirus * t, V0 E" K- W& `5 A! z( ]/ ^15. Run ETAp 7 application.( W/ F6 f" U9 u1 y7 w* k- M
16. Will show up window for license , click OK, then software will ask for activation serial3 u1 u' E8 m7 i+ d! ^' c' f# F
Enter Activation serial : 9dp8kD6Ncc#Y8r5FBL+QEn3DHqDBKR<7Nc4/ 4 }2 u# p. @) f+ n" o6 Z8 R: Y! K$ y# X
C.享用免费etap7! , g& C$ B# u( h% V . N, u% x5 C0 b7 G注:以上软件和信息均收集与互联网
