本来想把电抗器重燃模型的model模块model用txt文件贴出来,好像不能上传txt文件,故在下面贴出了model的内容。/ R6 K6 v- Z3 n# v4 `& |
, F+ l; l) a3 J( {- z* S
MODEL breaker . z* J v5 K4 D$ X6 _8 u 2 I: n/ v" l9 b+ _COMMENT >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> ( O4 D2 o% ?- f: `- r5 N9 | O$ l3 W+ N- F w
1 w9 H0 A4 i( ]0 h. {& ~% r
The model of this example updates the present state of the 2 ~# P$ g$ W6 y4 p; ~' E4 l& Dcircuit breaker by taking into account the conditions - G6 `& W/ B0 k9 k0 K
controlling four represented state transitions: first opening, 3 @; w/ I: f, r7 c
reigniting, reopening, and full opening. % l& b O& v& k% T6 A; r) G ' }: N B5 A$ a9 D# Q' k# H, Q>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> ENDCOMMENT+ I! K& ~5 ~3 \( m: c
$ |8 C" S: G/ ?+ z$ J3 O' F, bDATA6 @! y0 n3 G4 q9 [
topen -- [s] earliest elec opening % B% ]5 |& a# y8 B5 |+ }- D8 j0 g2 J ich1 -- [A] chopping level at power frequency! W% A9 J# {" f( {& [. |1 s; g
slope -- [A/s] current slope + W) G& v k: l0 g! Q& D: t reopen_delay {dflt:2.5e-6} -- [s] reopening delay 7 t8 i: t- V8 o3 Z reignit_w {dflt:1e-2} -- [s] reignition window # s. I3 o" m/ f6 ~6 B$ W6 u6 l& o; P
INPUT + [6 [% C3 [! y+ p2 N3 \. u v1 -- voltage across breaker terminals2 D% r0 a8 n% B# g
v2 ! U( f v1 U6 U- s. T current -- current through breaker " S( j T$ b6 a" F& u( l2 A ! H' r4 ~' b. Y1 w4 h( u* \VAR: h% }( _7 _8 Q/ Z; y* L$ i9 B; Y
state -- 0= fully open 2 Z3 i5 [( s. g -- 1= normal closed' w# i6 z6 ?; P8 G c0 _8 [. X
-- 2= tentatively open - o/ p& k& L$ x4 d- C/ J! s `+ s -- 3= reignited + X+ L) T6 n; u: _" l, n first_opening -- transition from 1 to 2' ]5 j- ]4 p3 L4 o5 ]
reigniting -- transition from 2 to 3$ z2 ~: h2 O9 J, r; x( |- }& E: u
reopening -- transition from 3 to 2 # K! p8 x: N' k+ r8 i* @3 o6 @2 s/ ] fully_opening -- transition from 2 to 0 # q! b) u+ U c' Y j& }5 g% q reopen_clock -- state variable of 39 N8 g. u3 `# m; c# `5 L" ?
elapsed -- time elapsed since tbeg m3 f8 ^1 N3 E% g0 j+ e2 n+ V& U! ]/ ]
cbstatus -- open/close signal to switch ' t/ W9 p( L4 [ deltav ; U9 C5 Q1 e/ x T
ds 0 L; F8 |; d# }% g nds, W1 S! g$ ?+ o) X* m& K% F
tdelta 2 f9 ?; ^* s' B/ X1 u" O itopen& n5 h. ]0 t3 K3 _# g8 y: s
ich2! \* K- a, B: }. [
: x. u5 H6 _1 q+ lOUTPUT $ P D% l% Q8 v, Y9 I cbstatus ,ds,nds 3 k; B; d& h5 L- J' G) q' C `' M* y0 e% _ d
HISTORY) V" q2 ^8 v8 w7 h% k' D3 g
current {dflt: 0} # L$ ~% f& o' b V, x+ o% r" B( W- r9 V ' }6 R6 ?/ G1 GINIT, z+ q% K5 u( n( M2 S
state :=1 -- normal closed2 I. J7 y" S o6 D) L3 V0 f1 y8 A ~
cbstatus :=closed ; [! |) y' ^/ @( X% K8 j" y& i& W ds:=1 Z8 o- _" H! U: j/ j5 v3 V6 k
nds:=-1' Q" l' x; R" e% X- D5 L2 t
ENDINIT ; a3 s" u$ c1 `0 o5 ^ $ H* S1 W: g7 r. {: ?EXEC8 ]1 ]) n5 ?9 ]. O" d' H
deltav:=v1-v2 " L* h- `: K2 @4 J% ] IF t>=topen THEN -- otherwise do nothing* a, q* k- g7 h6 t5 A
tdelta:=(t-topen)*10007 U$ v. l9 }6 x! H {
IF tdelta<=0.44 8 u. K$ d5 v7 @* M: W THEN ds:=(38.5*tdelta**1.5)*1000! L$ k. @6 i3 ~( v% T& Z
ELSIF tdelta>0.44 AND tdelta<=5.00, ]$ g% R- t# r( c
THEN ds:=55.1*tdelta**0.55*1000 2 R8 z" P( e7 `: H ENDIF % C$ E" t, o0 R * [& H8 m F- [) ]. A nds:=-ds2 L' K ?" @ S" Y* O
itopen:=abs(current)* H- Q' W* g3 ~3 H, H8 k6 M( N& `
ich2:=(2*pi*50*14.3*itopen*6.3*exp(-16))**((1-14.3)**(-1)) 6 w/ u L2 V6 c. A+ A6 t6 h6 I7 y) R6 E' D
first_opening :=false; fully_opening :=false8 }5 h1 g, L+ Y+ B t
reopening :=false; reigniting :=false 1 Z3 P* f3 ~ G+ L0 e% p# ` 3 S( F# X4 w4 a/ @ IF state=1 -- was normal closed+ F, o. I* k; | f3 s
AND (abs(current) <ich1; F: @; g! O- l1 u; X/ `
OR current*prevval(current)<0) v* b: v6 g/ @' a
THEN first_opening :=true" w+ F) W3 `( U4 B% Y) T
elapsed:=t-topen $ |( c0 T% {. `& `. k7 u# Q N, o3 s# }) W1 b ELSIF state=2 THEN -- was tentatively open . L+ [' `- |9 S5 P. S* h' [) w
9 H n6 z! J, L6 c3 z
IF elapsed>reignit_w THEN , h3 K5 T0 ]. G( K; ]5 { fully_opening :=true( @( {/ s. m" T& r
ELSIF abs(deltav) > ds) Z5 s4 _+ w+ D1 ~ q( e! o
THEN reigniting:=true) m( ^1 @. Z: {1 o' I" X, d+ h
ENDIF' S2 Z$ f5 D4 y; q4 d, m8 T+ u
; a, j8 p: g1 m i/ f
ELSIF state=3 THEN -- was reignited1 [$ s+ O) b2 D' Z9 a8 N
4 f/ t+ W$ |' w
reopen_clock :=reopen_clock +timestep + _ m* Q3 M# t - a% n% K$ ~, T' R/ C6 x/ H- h" | r IF reopen_clock >=reopen_delay - Z; _$ |( i2 a. I9 D AND (abs(current) <ich1+ r4 K6 T, N6 z! a3 P
OR current*prevval(current)<0) ! r8 }) \. a/ Z1 g* P1 A
AND abs(deriv(current))<slope5 G- x1 i: r7 j {1 V3 ?/ Q9 y
THEN reopening:=true6 c/ ~4 g9 e( ^! b6 K
ENDIF ( K: S: [( n4 C. \. R; j0 A! K; k- L
ELSIF state=0 THEN -- was fully open' y: m/ r; N8 G0 i
ENDIF + C% Y; @: f/ @+ k3 m- n! S" R8 z1 w 0 m. x* n' I- A# O- A. x IF first_opening OR reopening THEN 6 S! M4 [0 |& @7 O9 C state :=2 -- becomes tentatively open+ @# e7 R9 K$ | p
5 T# f0 \9 k! H$ [2 e2 T
ELSIF reigniting THEN7 R( w1 z; k0 g) [# u
reopen_clock :=03 f7 }( v7 f. M- A2 u
state :=3 -- becomes reignited/ Z4 s R% E2 p7 y" d) c) j
ELSIF fully_opening THEN, D% l: q' [4 }! h) R* ^
state :=0 -- becomes fully open3 O; p% ]( G2 M* ]( Y8 c. n, L
ENDIF; r) `% v, Q. [3 @' F2 x2 _
3 D' C. N* f5 j1 |% r* | IF state = 2 OR state = 0 -- is now open , A& E/ Y$ ~) p& e THEN cbstatus :=open 2 u" G" A2 ?$ J9 w+ ~$ c% I ELSE cbstatus :=closed 3 u) d9 `% N+ Z$ k ENDIF / ^5 t% {7 g" U9 V) @ ' O' D& V, [7 p. V2 R/ M8 c: x3 n a; S! V
ENDIF. n& V( a. ^ ~' O" E. P- [0 E$ U
% S/ ~# z/ I9 ^% s% J! u. M0 ]
ENDEXEC% u9 X, n$ s( y! R; O
ENDMODEL / {6 ~4 b# W; e+ `" S8 q; U& x k# f) U
