[img]file:///C:\Users\Administrator\Documents\Tencent Files\1075017590\Image\Group\@3Y03AR_08U~CUBS][{JM99.png[/img]我把电感去掉,再运行时就报错,下面是报错代码。帮忙分析一下非常感谢。 ( p& l; a% l2 {' N) s" nYou lose, fella. The EMTP logic has detected an error condition, and is now going to terminate program execution. The following ; v9 x4 Q4 `0 {3 o' k- n! g& |7 _/ Rmessage summarizes the circumstances leading to this situation. Where an otherwise-unidentified data card is referred to, or where3 c+ `9 {* ~; l' m
the "last" card is mentioned, it is the most recently read card of the input data that is meant. The 80-column image of this card * R) ?8 T1 p# d0 f% j" Lis generally the last one printed out prior to this termination message. But possibly this last-read card has not yet been # v) G. b; S" G- S; ~ hdisplayed, so a copy follows: , d- u, r: N) x- T* _" j& f " " : ]: Q" R# o* |% |+ A4 Y& q7 I KILL code number Overlay number Nearby statement number, q# K1 X% M$ X- k# [$ M
64 11 55252 F& b" n& ~9 v5 @6 @" b
KILL = 64. Switch connectivity error. SUBROUTINE SWITCH, which is used to make the logic changes associated with a modification , _$ \- [5 o6 v# R6 @" k4 p; o5 p- aof switch status, has just determined that an error is about to occur. A loop of closed switches is about to be created, touching k8 ^3 q' m0 T
node "......". Such closed switch loops make the network solution indeterminate, and are not allowed by the program. 3 j' [$ [, x% ^& Q$ F( Q7 H/ c " V- x, p. P+ O+ h& w 3 y; t+ A x8 |: ~
